| [ Total Views: 32705 | Total Replies: 563 | Thread Id: 101171 ] |
| Pages: 1 .. 3 4 5 6 7 .. 19 |
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on April 14th, 2013 at 08:47 PM |
But the question is Stanely.......did it take an instant or a while to produce those chips?
Stanley
Threads: 270
| posted on April 14th, 2013 at 08:50 PM |
Lets just say I can find better ways to spend a weekend.
hellbugged
A.k.a.: Daimo Pell
| posted on April 14th, 2013 at 08:55 PM |
.........as long as it wasn't any of the internals getting
together to do one of the instant jobs. (kah-bang!)
Stanley
Threads: 270
| posted on April 14th, 2013 at 09:12 PM |
No worries Daimo...this was purely a planned modification.
h
| posted on April 14th, 2013 at 09:27 PM |
score!
was wippying some long long long grass today, like 5+ foot long grass , prolly due to over 1400mm of rain sice February totally over it
anyways was weed wacking away and discovered a full set of tinware inc doghouse and tappet covers under the undergrowth
don't ask, as I won't tell.. was like finding the treasure under X marks the spot
hrastovica
Threads: 43
Mood: Cruisin
| posted on April 14th, 2013 at 09:50 PM |
Went to Jambo and checked out some cool rides.
Sides
A.k.a.: Dave Sidery
| posted on April 15th, 2013 at 07:54 AM |
Fitted up some GoPro's and raced it.
Discovered its slowly turning into a rocket ship.... final run at Mt Cotton was only 2/100'ths behind my best ever, and that's with having to back
off for water on the track !!!
My toys
mactaylor
Mood: even my dog is german
| posted on April 15th, 2013 at 05:00 PM |
| Quote: | Originally
posted by Sides
nice!
EVERLAST CONCRETE TANKS
1800 552 123
Super1302
| posted on April 18th, 2013 at 08:09 PM |
Well I made an exhaust setup so I could tuck it up just below the rocker cover, just got to put a tab on it to secure to a strap from the car, then
some pot belly paint will do, then it should be good for a blue slip I hope.
hellbugged
A.k.a.: Daimo Pell
| posted on April 21st, 2013 at 01:06 PM |
Missus has become a little addicted to driving the stocka, but the inconsistent starter was a problem.
Sooo added a relay to it today, Awsome now!
sander288
"Bolt-on Master"
Threads: 183
| posted on April 21st, 2013 at 03:23 PM |
washed it and drove it for a couple of hours after replacing the 8 year old battery (which finally wouldn't take a charge)
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
| posted on April 21st, 2013 at 06:15 PM |
My accelerator cable was a little stiff, so I took it apart, cleaned out the cable tube, and re-assembled it all. It is great now.
From your ole' mate Jeff
matberry
| posted on April 21st, 2013 at 06:53 PM |
Washed and drove Bluey today, a few jet changes too
matberry
| posted on April 21st, 2013 at 06:58 PM |
Oh, and yesterday I repaired a broken throttle pedal, checked the tyres and took the baja for a blast.
Consequently, today I needed to pressure clean the mud off.
DakDak67
Threads: 15
| posted on April 21st, 2013 at 06:59 PM |
I took a solo drive up to the Sunny coast in the bus, perfect weather, lots of nice girls to look at ... Perfect!!
hellbugged
A.k.a.: Daimo Pell
| posted on April 21st, 2013 at 07:22 PM |
Where are the bluey vids matty?
Got bored after lunch and started refurb of wood slats of me ole roof rack
matberry
| posted on April 21st, 2013 at 07:30 PM |
| Quote: | Originally
posted by hellbugged
| Yeah, been slack, need to find my mates long driveway as it pegs the speedo pretty quickly
65standard
Threads: 47
Mood: Only when I'm in it.
| posted on May 2nd, 2013 at 09:07 PM |
Changed the clutch cable and Bowden tube. 4 hours of "F" factors doing the job solo, but got it done.
Had to adjust the clutch pedal freeplay every couple of weeks. Thought I'd change the cable. Glad I did as the picture shows. This was in the Bowden
tube. Compared the old cable to the new. There was about a 5mm difference in length. Cable was obviously stretching ready to break.
| Error |
[size=4]If it ain't broke, fix it till it is![/size]
hrastovica
Threads: 43
Mood: Cruisin
| posted on May 3rd, 2013 at 12:23 AM |
Ross came over and installed the 4" narrowed beam. Perfect fit with the shock towers fitting snuggly. The leafs will be ready in a couple days, and
we can start assembling this baby. I imagine there wouldnt be too many 4" narrowed beams with needle bearings floating around... hopefully it will be
worth all the effort.
DubbyDo
A.k.a.: Dave
Threads: 45
Mood: need more compreshunn!
| posted on May 3rd, 2013 at 10:31 PM |
Pulled the LH head and barrels to clean foam out from fins, guess I'm still in the honeymoon phase but I'm lovin not having to disconnect a billion
sensors, EGR, pipework and 24 + headbolts! Bores are a little bit glazed but plenty of life left, think I dodged a bullet here
matberry
| posted on May 3rd, 2013 at 10:34 PM |
| Quote: | Originally
posted by DubbyDo
Awesome
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
| posted on May 4th, 2013 at 10:39 AM |
Nah, not honeymoon, that shit never gets old.
Camo
A.k.a.: Kev
Threads: 209
| posted on May 4th, 2013 at 11:03 AM |
Replace the steering box yesterday with a new one of a good quality, TRW. Will test drive today and then can comment on Frosties post.
Also fitted 2 new longer seat belt stalks and today am playing with the passengers door opening rod as the circlip has obviously fallen off
Kev
hellbugged
A.k.a.: Daimo Pell
| posted on May 4th, 2013 at 02:07 PM |
Coolio!
Cant believe how many hours this took with 4 sanding sessions and 5 coats of marine varnish but well chuffed with the results
rockin on the stocka
Today I've got the hotty beetle out for a run. Had been a while. Speed and power .....
Sides
A.k.a.: Dave Sidery
| posted on May 4th, 2013 at 04:06 PM |
Primed the two replacement doors I have for Jezzi... if the weather holds may even get some colour on 'em tomorrow !!!
My toys
1916baja
Threads: 176
| posted on May 4th, 2013 at 04:55 PM |
Not coming to the show Dave??
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
| posted on May 4th, 2013 at 08:24 PM |
Generator light came on in the beetle, and I spent 10 minutes taking a set of brushes out of a second hand generator I had, and fitting them to our
ride.
All good, running fine. 10 minutes well spent.
matberry
| posted on May 4th, 2013 at 09:05 PM |
Finally got a chance to give Bluey a wash and polish and a quick resync of the IDA's, ready for the trip to the show tomorrow.
h
| posted on May 4th, 2013 at 09:27 PM |
good.. hope to see you n it there
pete wood
| posted on May 4th, 2013 at 09:37 PM |
Took the oval to my son's footy game and then to pic up a new toy... needless to say, my spokesmodel and his siblings were pretty excited about it
all.
| Error |
