| [ Total Views: 27115 | Total Replies: 299 | Thread Id: 59579 ] |
| Pages: 1 .. 3 4 5 6 7 .. 10 |
Volksaddict
Threads: 102
Mood: hooked
| posted on April 15th, 2007 at 08:04 PM |
Wow ...little did i know my little baby would get so much TLC ....new i shouldnt have sold it!!!
Great work and look forward to seeing it finished
Cheers&Beers
Ray V
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on April 15th, 2007 at 08:16 PM |
G'day Ray - wow another owner pops up!
Whereabouts in the time line do you fit in? I know Bruce from Byron owned it before Damo (in Noosa), and before Bruce, a girl named Alice owned it (in
NSW somewhere).
It is cool to get some history.
Although I will never be restoring this old girl to stock condition (that is not my "thing"), hopefully you'll know I won't destroy her either
(although purists may not like me too much). I say (not just to previous owners!), read along if you like as progress continues, but if you don't
like what you see.....it's as simple as not clicking on the thread!
Alan :kiss
beerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
| posted on April 15th, 2007 at 09:14 PM |
"It is not going to be perfect (esp since I don't have access to flow bench etc), but I am using this entire engine as a learning process so I am
not expecting perfection!"
YE Right AL
You dont know how to do it any other way :beer
Hows self employment??
[ Edited on 15-4-2007 by beerdoc ]
Cheers Doc
reVOLKS at Fyansford Geelong
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on April 15th, 2007 at 09:27 PM |
| Quote: | Originally
posted by beerdoc
Ask me in another 6 months and you'll get a different answer!
To date, a lot more stressful than I ever imagined, even with a conservative business plan/cash flow forecasts prior to setting up....the sleepless
nights are becoming far less nowadays :P
Luckily I have VWs (and surfing of course) to keep sane/de-stressed outside of work!
PS How is Daryl?
Volksaddict
Threads: 102
Mood: hooked
| posted on April 16th, 2007 at 05:48 PM |
Alan ..I bought it of Bruce ..stored it in ipswich in my mothers garage ...tinkered with it on visits ...getting it running and rolling ..brakes
where locked up when i picked it up ..had to skull drag the poor thing onto the trailer...themn Damo advertised a splitty D/cab , couldnt resist and
the rest is history as they say ...I owned it for about ayear .
Cheers&Beers
Ray V
555bug
WRX Bug Boy
Threads: 79
Theme: UltimaBB Vintage
Mood: turbo charged
| posted on April 17th, 2007 at 09:49 PM |
Alan, why not make your own flow bench? looks pretty easy, i've put together a injector cleaner from similar plans that worked a treat.
Best of luck Stephen |
byronbus
dsk
Threads: 119
Mood: dsk founder
| posted on April 17th, 2007 at 11:19 PM |
Good to see her getting the attention she deserves...I would have liked to keep it being a 54, but just dont have the time, dollars or space...
Ray did a good job on the front lawn getting her out, should have helped i guess...
fullnoise
Threads: 103
Mood: Middle of the road.
| posted on April 18th, 2007 at 09:40 AM |
Hi Alan,
I saw your old ride in Fast Fours yesterday. It looks hot, well done.
It wouldn't surprise me if your oval ends up in there too.
Regards
esratrams
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on April 18th, 2007 at 10:59 AM |
Cheers CT - hopefully this one might run some decent numbers one day so the ricers might have to pay a bit more attention to our lowly old veedubs!
Cheers for the history of the car as well guys - looks like it must have passed through quite a few hands over the years. Fortunately there were no
'major' bodge jobs to haunt me
Stephen I guess anything is possible (re. flow bench), but I am not sure if a home made job would be accurate enough to provide useful info? Even so,
I guess I am probably not going to be doing enough heads to warrant spending the time/money to set one up (but who knows down the track!).
Alan
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on April 22nd, 2007 at 08:35 PM |
After a few delays (had to get a decent pair of circlip pliars), the rest of the engine was torn down...here is the "big block" of vw engines:
Most of these bits will be reused after clean and inspection. All cylinders sealed well (no head leaks) and piston rings held up well:
Crank and rods will stay....cam will go (dual pattern with symmetrical lift, around 6 degrees of split duration favouring the exhaust...and approx
0.500 lift, 242 duration @ 0.50 - haven't got exact specs yet, but this is close to the mark). Maybe straight cuts but not sure yet (depends if I
change the oil pump as well):
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on April 22nd, 2007 at 08:43 PM |
Thanks to Dave for the phone call - nice to pick such a "great brain" when issues pop up (turns out the lower half of the case sealed really well
and didn't want to split - after some more coaxing it came apart).
Also my sway-a-way 1200 length axles arrived along with the super diff and heavy duty side cover from Rod (Penrose).
Now just have to work out how to get some money before purchasing the Albins gear set - if I can scrape together enough cashola, I'll go full custom
1st to 4th as follows:
1st 3.333
2nd 2.08
3rd 1.44
4th 1.04
3.88 r&p - all selected to optimise the turbo application.
If $ runs short I'll go 1st and 2nd above, but will run kombi 3rd (1.26) and 4th (0.89)....if only money grew on trees
Alan
reub
VWRX is gone...
| posted on April 22nd, 2007 at 08:45 PM |
This all is great to see mate....thanks for sharing the buildup with us all.
Look forward to seeing the car at Warrick.
Reub
humpty
Threads: 139
Mood: Totally boosted!
| posted on April 22nd, 2007 at 11:45 PM |
What Reuben said....
66deluxe
Threads: 139
| posted on April 23rd, 2007 at 09:47 PM |
Alan you want your case super cleaned, can do this for you at work will make assembly a nicer experience. Also do you have the oil gallery plugs
drilled and tapped, can help you out there too mate. Cheers Damo.
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on April 24th, 2007 at 08:10 AM |
Hey Damo - the cleaning would certainly help out a lot! I will have to check re. the oil gallery plugs - I am not 100% sure if they were done on the
first rebuild (as I didn't assemble the block myself).....if not, will definitely take you up on the offer and will reimburse you for your time. I
might debur the case in a few areas (amazing how many little casting imperfections just break off with a little persuasion).
once that is done I'll see if I can get the case up to you!
Hopefully will be ordering the RAT cam and lifters (plus some other bits and pieces) soon - let me know if you need anything in case you want to
combine the order.
Alan
66deluxe
Threads: 139
| posted on April 24th, 2007 at 09:42 AM |
No worries Alan, I actually have a CJ series 2 litre case here all cleaned, drilled, tapped and DTM ready, all dimesions/tolerances are stock, I was
going to use it for my build then i scored a 1700 W case, which ihas checked out perfect for my build. If you want a possible swap of cases, then no
down time for you, just a thought. Also let us know when you are going to order your cam as i want to get a set of KB 96mm pistons and a solid rocker
spacer kit from TIV store. Cheers Damo.
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on April 24th, 2007 at 10:03 AM |
Shall do mate - hopefully will order the bits over the next few weeks.
I'll probably hang onto the case for now as I am reusing the bearings (all spot on)....saves worrying about slight variations in bearing tolerances
etc. I appreciate the offer though - I'm sure you'll be able to throw together another type IV using that case in no time! Should be able to sell it
and recover some of your costs.
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on April 29th, 2007 at 12:22 PM |
Case was deburred of casting marks including the really rough sump inlet (looks like something has broken through!)
After a quick cleanup. Didn't take any pics of internal cleanup areas (nothing too exciting!).
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on May 12th, 2007 at 08:03 PM |
Due to a lack of funds, progress has been kinda slow.
So I decided I may as well do something that doesn't require a bit outlay of $....only time. There have been a few areas of rust (mainly surface) and
blemishes that have been annoying me for a while. So I decided to sand them back to check what was underneath (rust but not major).
Had to do a few bits of welding where there were cracks in the bonnet, and all 4 guards plus a few holes in the passenger door (inside handle which I
no longer wanted). Finished up tonight with a skim of filler but since I am out practice I didn't add enough hardener so had to scrape most of it
off, so called it a night! Ah well, learn from mistakes I guess
For now I'll just leave it in patches after a bit of primer and rattle can colour....pending time, I might give the oval a full respray (not back to
bare metal though) soon.
beerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
| posted on May 14th, 2007 at 10:01 PM |
I am glad that some one else does the old not enough hardner #$%^ up
Leave the spots exposed or clear coat looks kind of cool or dare I say it Ratty:beer
Cheers Doc
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on May 15th, 2007 at 10:04 PM |
beerdoc - it is one the few things that makes me swear and carry on like a pork-chop.....I wasted about 3 hours because of one simple mistake!
Fortunately it was incident free after that...a few more coats of skim filler, more sanding then a bit of rattle can primer and rattle can cream
colour paint....finished.
It will stay patchy for now until I get around to fixing the remaining dents and imperfections and actually strip it down to do a proper repaint (not
bare metal though, I already found a few bubbly surprises so if I dig too deep it will end up taking me 2 years again to finish it!)
bond
Threads: 166
| posted on May 16th, 2007 at 03:20 PM |
suprisingly nice job. well done
nick
66deluxe
Threads: 139
| posted on May 21st, 2007 at 06:43 PM |
Alan, your case is drilled and tapped and clean sir. From this to this. Damo.
LUFTMEISTER
Threads: 119
| posted on May 21st, 2007 at 06:56 PM |
it's amazing what a toothbrush and a bit of Jiff can do.
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on May 21st, 2007 at 07:54 PM |
Damn Damo that looks super sweet! I really appreciate the assistance - as I said before just let me know what you want for your time, be it cash or
labour which I'm happy to provide where you need help....we'll work something out!
Now I just have to pull together that cash for the RAT cam, lifters and valve train components....then it can start to go back together! Of course I
have to do the headwork as well though - the list is endless.
Cheers again Damo.
bond
Threads: 166
| posted on May 21st, 2007 at 08:33 PM |
alan - are you going to get a turbo cam from raby? or is that the same cam as the rat?
nick
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on May 21st, 2007 at 09:24 PM |
Yeah Nick, I will be going turbo cam from RAT - I think I refer to some numbers on a previous post (haven't got exact specs yet).
76bug
Threads: 20
| posted on June 26th, 2007 at 10:54 AM |
hows the car coming along?????
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on June 26th, 2007 at 08:19 PM |
| Quote: | Originally
posted by 76bug
Well, no money = no progress. But I have been slowly accumulating parts so hopefully over the next month or so I will have my new albins gears
installed into the IRS case (converted to swinger), along with the new super diff and side plate etc etc.
In the interim I have disassembled the heads and will start some unshrouding of the ports etc. The order from the US will hopefully be on the way soon
(new cam, lifters, rockers, valve springs etc).
I'd like to have it in naturally aspirated form for warwick, but will depend on funds and time - I'll be doing my best!
Alan
Will post pics when there is something of interest to look at
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on June 26th, 2007 at 08:27 PM |
how did you get the case so clean............................c'mon tell us the secret !!!
