| [ Total Views: 9097 | Total Replies: 211 | Thread Id: 78253 ] |
| Pages: 1 .. 3 4 5 6 7 8 |
Dirtbag
What the hell does standard mean?
Threads: 22
Mood: boobtastic
| posted on September 7th, 2009 at 09:25 PM |
It looks bad at the moment because I haven't fatigued the paint yet, but trust me, I'll have it looking old and tattered in no time.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 7th, 2009 at 09:27 PM |
More blue.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 7th, 2009 at 09:29 PM |
Here's Sid with the front cut off getting the approval of my daughter, who has adopted Sid as her own.
| Error |
DaveCarter
Threads: 16
Mood: has the super bug
| posted on September 7th, 2009 at 09:56 PM |
coming along nice man
gsa2at
Threads: 25
Mood: busy
| posted on September 9th, 2009 at 05:18 PM |
looking good timbo
can;t wait to see the beam extension on and those hot wheels
jack the beetle rides again !!!
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 9th, 2009 at 06:23 PM |
Here's a close up of the paint in the wheel well.
It's just the same trick I did on the head lights.
Once the front beam extension is in and I've trimmed the front sheetmetal properly I'll be able to have a look at it side on to see exactly how I
want the rear cut to look. That's why the cut still looks so bad. : )
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 9th, 2009 at 06:49 PM |
Today Sid got his ass dumped : ) Thanks to everyone who posted info on how to lower the rear as I've never done it before. I don't know if it was
beginners luck but the whole job took less than an hour. I guess having the guards off already helped.
I expected the spring plate to be really hard to get over it's "stop" but I used this thin jimmy bar and it just slid straight over the stop. I
also used the same bar to lever the plates off the splines. Slid straight off. I have no idea of the history of this car, but it certainly didn't
look like any of it had been undone for a very long time.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 9th, 2009 at 06:52 PM |
You can see the line scribed into the metal behind the spring plate. I scribed that at the very start when Sid was still on the ground so there was
full tension on the rear suspension. Now, after rotating the plate 2 inner splines, the plate is higher than it was when it was fully loaded, only in
this photo it has no load on it at all. This thing is going to be LOW!!!!!! : )
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 9th, 2009 at 06:57 PM |
Tada!! I wasn't going to fit the proper wheels but I felt I had to as I wasn't 100% sure the tall profile tyres wouldn't hit the body with all the
negative camber. Luckily they don't. I don't really like the negative camber look, but hey, it's a swing arm, what can you do? : ) I just knew I
wanted the tyre right up near the edge where the guard used to bolt on, and that's where it is and I like it. It's come down about 4 1/2 inches. I
can't wait to do the front now!!!!!
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 9th, 2009 at 07:01 PM |
He's starting to show a bit of volksrod attitude now.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 9th, 2009 at 07:02 PM |
I love how close the tyre now is to the body. I thought 2 splines would be too much, but alas, it was perfect : )
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 9th, 2009 at 07:04 PM |
I can't finish a job until it's been given the once over by my daughter. I think she likes it.
| Error |
DaveCarter
Threads: 16
| posted on September 10th, 2009 at 10:17 AM |
That looks badass. Perfect height on the back. This is going to be such a cool car
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 10th, 2009 at 12:14 PM |
Thanks Dave. It's starting to show it's true colours now. I've just started pulling the front apart to clean up, fit adjusters and the beam
extension. I just wish I didn't have to wire wheel it all : ( I'm tempted to just throw him together and do the paint on the suspension later.
alien8
Threads: 84
Theme: UltimaBB Powder
| posted on September 10th, 2009 at 06:14 PM |
Just gotta say DB that the W lid you made is F'in cool as shit mate.
You just need a Barbie Doll hanging from a noose from the rear vision mirror
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 10th, 2009 at 08:20 PM |
Thanks alien8. Barbie ornament would be funny : )
I thought it was time I started on the front of Sid, so here he is with the body section removed but all the grease and grime still in tact.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 10th, 2009 at 08:24 PM |
I yanked the whole front end out in one piece so I could give it a bit of a bath before I pull it apart. I don't want to get my nails too dirty : )
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 10th, 2009 at 08:25 PM |
I also gave the area under the petrol tank a good clean as well as it will be getting a coat of shiny black too.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 10th, 2009 at 08:28 PM |
After a lot of cleaning you can actually see the seal where the swing arm goes into the beam. There's still more cleaning to do though, then I can
strip the beam and fit the adjusters. I hope to get some work done this weekend, but now I've said that, I probably wont get a chance : (
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 12th, 2009 at 05:51 PM |
Here's the front section painted and the beam extender painted and fitted. This is what I've been waiting for : )
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 12th, 2009 at 05:53 PM |
I stripped the trailing arms and stubs off the beam, but left the steering box and arms on as I'm only adding adjusters. I did undo the steering
damper from the top beam to allow room to get the grinder in to cut the beams.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 12th, 2009 at 05:56 PM |
Unfortunately one of the grub screws that holds the trailing arm on was stripped inside where the allen key goes. It was buggered, so I ended up just
drilling it out until I could just see the teeth of the thread then used a tap to remove the rest of it. Bloody thing. Took be half an hour just to
get this one screw out. Could have been a lot worse though, it could have happened to all of them.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 12th, 2009 at 05:58 PM |
This is only the second beam I've modified, and I have to say, just fitting the adjusters and not narrowing the beam is so much easier. It took
around an hour to do the adjusters. I'm sure people who know more than me (not hard) would be better at it, but I'm new at this so it's still all
exciting and interesting : )
Being able to just do one adjuster at a time and having the other beam keep everything in line sure was a big help too.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 12th, 2009 at 06:02 PM |
Last night my daughter and I fitted these funny billet hinges. I thought they'd be good to go against everything a rat rod beetle stands for. I like
to mix things up a bit : )
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 12th, 2009 at 06:04 PM |
Well, there's still a good sized list of things to do, but here's the general concept. Personally, I like it, and I know others will hate it, but
it's not my fault others have no taste : )
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 12th, 2009 at 06:08 PM |
He still needs head lights and tail lights fitted, indicators fitted, steering shaft and brake lines extended, fuel tank put back in(once steering and
brakes are done), front seats de-headrested and trimmed, cool looking but cheap exhaust, stripe painted on decklid and bonnet and decklid latches
fitted. I'm sure there's more to do but that's a start.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 12th, 2009 at 06:09 PM |
It took a bit of modifying to the door frame but I got the peep mirrors on today as well.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 12th, 2009 at 06:11 PM |
Here's just a few more pics purely because I like it and want to make you all look at it too.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 12th, 2009 at 06:12 PM |
I had to notch a bit out of the bonnet for the steering box.
| Error |
Dirtbag
Threads: 22
Mood: boobtastic
| posted on September 12th, 2009 at 06:14 PM |
Not sure when I'll get a chance to do the jobs on the list, but at least he's looking pretty funny and cool for the time being.
| Error |
