| [ Total Views: 22963 | Total Replies: 310 | Thread Id: 90915 ] |
| Pages: 1 .. 3 4 5 6 7 .. 11 |
cjbolt051
Threads: 4
| posted on September 19th, 2011 at 10:13 PM |
more goodies for my drag bug
| Error |
| Error |
| Error |
| Error |
| Error |
Winner best engineered vehicle 2011 @ Warwick & 2012 sydney
1/8 6.71 @ 100.9 mph Warwick 2011
1/4 10.17 @ 137 mph WSID
nbturbo
Threads: 89
Theme: UltimaBB Powder
| posted on September 19th, 2011 at 10:15 PM |
Good work there Chris-will be doing a bit of stalking of your car in Warwick looking for good tips.
cjbolt051
Threads: 4
| posted on September 19th, 2011 at 11:07 PM |
Thanks, look forward to catching up with you in Warwick. I am very happy with car thus far . although the wiring did my head in more than a couple of
times (Thanks again Wayne for your guidance)
venFun10
Threads: 0
| posted on September 20th, 2011 at 01:19 PM |
hey mate it doesnt look like you will get any time for testing does it?
will you tune it on a dyno at least?
cjbolt051
Threads: 4
| posted on September 20th, 2011 at 03:03 PM |
Common sense says that it is a new car so it will take a bit to get it track ready . and as for the dyno ...If it did not go on the dyno it would not
be going to Warwick. Do you think that just because we are in Australia we dont know anything . The Quality of the Australian Drag cars are equal to
that in any other country (even yours).I would appreciate it if you did not leave any more comments on this post if they are either negative or just
plain stupid
essex
| posted on September 20th, 2011 at 03:42 PM |
Good luck with finishing the car, look forward to seeing yours, the Penrose team cars & everyone elses for that matter at Warwick.
spl65t
Threads: 2
| posted on September 20th, 2011 at 06:00 PM |
Hey Chris Man,
Thought I'd finally chime in. Fark you fellas have done well, Pat on the backs for all you Penrose boys. Talk about showing how it's done !! Top
Stuff. Make sure the video's rolling when the car gets intial fire up.
Look forward to catching up with you fellas soon.
Cheers Linz
cjbolt051
Threads: 4
| posted on September 21st, 2011 at 02:32 PM |
Baldy ...Thanks. How you been ? alot of hours put into the cars this year and alot more to come. but it will be worth it .definately we will catch up
soon
cjbolt051
Threads: 4
| posted on September 25th, 2011 at 09:55 AM |
more engine progress
| Error |
| Error |
| Error |
| Error |
| Error |
cjbolt051
Threads: 4
| posted on September 25th, 2011 at 09:59 AM |
more progress on my beetle . battery fitted , all electrics fitted/tested and working
| Error |
| Error |
| Error |
| Error |
| Error |
cjbolt051
Threads: 4
| posted on September 25th, 2011 at 10:05 AM |
more progress . staging brake fitted with staging limiter button for the MSD ignition
| Error |
| Error |
| Error |
| Error |
| Error |
cjbolt051
Threads: 4
| posted on September 25th, 2011 at 10:09 AM |
windows fitted and engine finished ready for fitting . exhaust has been heat wrapped
| Error |
| Error |
| Error |
| Error |
| Error |
cjbolt051
Threads: 4
| posted on September 25th, 2011 at 10:14 AM |
Gearbox being built today . Motor and box will go in this afternoon ready for dyno tomorrow evening.
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on September 25th, 2011 at 11:00 AM |
Nice one mate!! Looks like it is all going to plan!! Hope everything goes well at the dyno for you and Wayne tomorrow!
humpty
Threads: 139
Mood: Totally boosted!
| posted on September 25th, 2011 at 12:57 PM |
Interesting idea running the fuel line through the channel.... Is it braided the whole length?..... Obviously your fitting grommets at either end, but
does the line need to be tied down in there at all?
Fantastic progress Chris... I have total respect for your efforts, and I'm so glad you didn't paint the car orange!
cjbolt051
Threads: 4
| posted on September 25th, 2011 at 01:31 PM |
| Quote: | Originally
posted by humpty
| yes grommets are at both ends and the fuel line is braided all the way to the rear . And with the braid it wont need to be tied
down
whathaveidone
Threads: 98
Mood: Heading for 10.99
| posted on September 25th, 2011 at 01:46 PM |
C'MONn Simon!!!!!!!!!!!!!!!!!!!! Enough with the Orange jokes!!!!!
Would have looked awesome if it was but!!!!
Orange cars rule!!!!!!!!!!!!!!!!
humpty
Threads: 139
| posted on September 25th, 2011 at 09:31 PM |
| Quote: | Originally
posted by whathaveidone
Hahahahahahaha..... I thought you'd pick that one up Ben!
cjbolt051
Threads: 4
| posted on September 27th, 2011 at 09:24 AM |
transmission assembly . setting up the ring & pinion . the 3.44 ring gear is fitted to the billet aluminum spool and the pinion is fitted with a
Gene Berg heavy duty pinion bearing retainer
| Error |
| Error |
| Error |
| Error |
| Error |
cjbolt051
Threads: 4
| posted on September 27th, 2011 at 09:29 AM |
transmission assembly of the gear train . ratios are 3.0 / 2.0 / 1.59 / 1.30 . The gear carrier housing required substantial clearancing for the 4th
gear set , reverse gear required substantial clearancing for the much larger 2nd gear set and the Berg pinion bearing plate required substantial
clearancing for the very wide and much larger 1st gear set
| Error |
| Error |
| Error |
| Error |
| Error |
cjbolt051
Threads: 4
| posted on September 27th, 2011 at 09:34 AM |
transmission assembled and now the chromoly axles , axle tubes and rear brakes are fitted . The original transmission is removed and tranny forks /
rear end is cleaned and painted .
The transmission is then fitted
| Error |
| Error |
| Error |
| Error |
| Error |
cjbolt051
Threads: 4
| posted on September 27th, 2011 at 09:39 AM |
flywheel end float is set , flywheel and clutch fitted , deep sump fitted and CSP relief cover for the oil pump .
The 45DCOE weber is then modified for methanol with a 3.75mm needle valve , larger accelerator pump nozzles , larger main jets , larger low speed jets
and inlet fuel galleries enlarged massively
| Error |
| Error |
| Error |
| Error |
| Error |
humpty
Threads: 139
| posted on September 27th, 2011 at 09:42 AM |
I'm feeling it.... I'm feeling it!.... Getting a bit 'Big Kev' abot this Chris.... The car has come together so well... Next stop, the dyno!
cjbolt051
Threads: 4
| posted on September 27th, 2011 at 09:46 AM |
engine is ready to be fitted today and will be on the dyno this afternoon
| Error |
| Error |
| Error |
| posted on September 27th, 2011 at 09:49 AM |
A credit to you guys how well this is coming together!! Can't wait to see it run!!
cjbolt051
Threads: 4
| posted on September 28th, 2011 at 12:04 PM |
stickers on , engine fitted and fired-up . All sounds great and on the dyno this afternoon for a tune
| Error |
| Error |
| Error |
| Error |
| Error |
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on September 28th, 2011 at 07:46 PM |
Awesome Chris and crew.
I am loving the new colour.
A weber draw through ... cool.
cjbolt051
Threads: 4
| posted on September 28th, 2011 at 08:10 PM |
we put my bug on the dyno @ South Coast Rotary this afternoon and my 2387ml type-1 turbo engine produced 238bhp and 1245lbs of tractive effort after
Wayne from WPVW tuned the weber carburettor and the MSD ignition
I am very happy with the results and my bug will be ready for warwick after we fit the new wheelie bars tonight
| Error |
whathaveidone
Threads: 98
| posted on September 28th, 2011 at 08:19 PM |
Nice one mate.
| posted on October 2nd, 2011 at 08:40 PM |
Did you get your brake issue sorted chris?
Car performed very nicely for it's First Outing!!
