[ Total Views: 9211 | Total Replies: 144 | Thread Id: 93336 ]
 Pages:  1  ..  3  4  5
Author: Subject:  sc ute resto start
posted on December 30th, 2011 at 09:58 PM
Originally posted by binner
^^^^ cheers bloke... still need to pick your brain though.
I went to bolt up the webers with those manifolds and F$%k me if the are too short!!! I'm about 40mm to low. If I try to mount the hex bar it fuggin hits the gennie!!....
Guess I'm milling up some spacers for the manifolds, glad I got a milling machine at work ;-) or if you got any easier/better ideas? :smilegrin:
What carb kit did you buy?
Maybe take a pic of manifolds, linkages and filters.
Memberbinner
Threads: 210
Mood: want more grunt
posted on December 30th, 2011 at 11:01 PM
mannies
Mr Berry, here are some pics, the high side of the man is about 155mm and lowside is about 130mm....
I tried to show the difference in height on the linkage but its not too good, I'm about 40mm short...
am I missing something here?
posted on December 30th, 2011 at 11:05 PM
Turn your linkage mounting plates up the right way and all will be good :)
The l on the r and visa versa too :)
Memberbinner
Threads: 210
posted on December 30th, 2011 at 11:09 PM
^^^^^^^.....arghhhh hahhhhhhhh I'm laughing out aloud. What a douch !!!! I swear after tomorrow no more sailor jerry and engine work.
Hope we all learnt a valuable lesson here. :lol:
cheers mate.
Membervassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on December 31st, 2011 at 09:27 AM
Too much fabbing and Tasmanian giggle juice:no:
Absolute bummer about the Vintage Speed. It was the one for the early bays Matt??
The part of the rear engine mount/bar that has the bends in it going to either side, is that part of the original bar that you bought?
If it is, it is certainly different to both the bars on our busses. Reason for the ?s is that we are saving up for a Vintage speed for the wife's Dormobile.
Here is a pic
http://i723.photobucket.com/albums/ww235/vassy66T1/Tricias%2071%20Dormobile/Enginemount.jpg
Marcus
Memberbinner
Threads: 210
posted on December 31st, 2011 at 05:39 PM
macguyver
did some cleaning up and adjusting to make everything neat today....
its new years eve and I'm finished for the day ...on to my wifes bitter and loving it
HAPPY NEW YEAR punks see you at the top !!!!
MemberKlaus
Threads: 100
Mood: Heavily modified
posted on January 1st, 2012 at 04:49 PM
wow lots of pipework , I've only ever tapped into one port and boosted brakes have always worked fine, big n small cammed engines , nice progress on the ute :)
Memberbinner
Threads: 210
posted on January 2nd, 2012 at 06:57 PM
^^^^^^^smoke the peace pipe, I love hoses all over the engine bay. I read about 1 port 2 port all ports and so many different conclusions so in the end I took Mr Berry's advice and went with all.
forgot about relocating the accelerator tube thru the fan housing and proceeded to drill thru the edge of my oil cooler. I think this thing is never going to get on the road :( ..... ordered a new cooler and I can't even sit back and have a beer to calm me because I made a heavy bet with my mate. No booze for 3 months as of Jan 1st. guddamit!!!
anyone know of a cheap type 3 wagon for sale......I'm not urgent on buying but just starting to look around.
MemberTheMiniMan
Threads: 162
Mood: swings
posted on January 4th, 2012 at 10:43 PM
http://forums.aussieveedubbers.com/viewtopic.php?tid=94547
Memberbinner
Threads: 210
posted on January 5th, 2012 at 07:31 PM
^^^^ too much cash .
Memberbinner
Threads: 210
posted on January 9th, 2012 at 09:13 PM
smashed it in
finally got the donk in this weekend, had some dramas with accelerator tube posi and pipes... ohhhh all those pipes :lol:
After fabbing up some parts thru the build I have decided to make my own tinware. Can't seem to find the stuff that fits anywhere.
posted on January 9th, 2012 at 10:30 PM
Look'n good Ian. :tu::tu:
MemberTheMiniMan
Threads: 162
Mood: swings
posted on January 9th, 2012 at 11:47 PM
yee haaa,,, chuck the boards in lets go to Byron :-)
Oh,,, maybe wait till after my cardio rehab then :-(
looking good bro :-)
Memberbinner
Threads: 210
posted on January 10th, 2012 at 08:25 AM
cheers fellas.....
Does anyone know where you can purchase thick rubber sheets from? I'm talking about 6-8mm thick, thinking about making a tinware blanket instead of all tin. I want it in one piece so I need a sheet size about 500mm X 600mm.i was thinking about industrial conveyer belt suppliers but it isn't that wide ....(i think)
cheers :D
EDIT- found some good stuff, I'm going against the grain and going to try 20mm *aerospace tile sheet, I just gotta hope I can mould it to shape.
* may not be actual aerospace tile :lol:
Memberbinner
Threads: 210
posted on January 16th, 2012 at 06:57 AM
so Matt, what should I have the valves adjusted at for a new engine?. 6 thou or 4 thou, what kind of driving do I do to ease the engine. Loving that V Speed short shifter but my hand seems to hit the handbrake going into first gear. Maybe it needs some adjusting.
I think it will be on the road by Friday if all goes to plan. Had to put on the original paint bumpers for now and wait till I get a cash injection to have them blasted and Pcoated.
posted on January 16th, 2012 at 07:48 AM
Valve clearances depend on what cam is installed. Did you build from scratch? If so cam card will tell you. If unknown, the next question is, how often do you intend to adj valves during the initial start up. My recommended sequence goes like this
Engine build-set valves .004"
Cam break in, 25 min engine time at 2000 to 2500 rpm (NO idling)-cooldown, change oil, adj valves .004"
Engine tune and test drive, full throttle max load asap(3rd gear on a steep hill for a few times is good to bed rings)-adj valves .004"
Drive.....for run in, DO NOT be a pussy- spin to redline occasionally but most important load it up and vary rpm and throttle position during cruise periods....adj valves at 500-1000km depending on how previous checks went .004", oil change and now should be cool for regular service interval.
If you want to be risky/lazy, open clearances and mileages to your descression.
My 2c
Memberbinner
Threads: 210
posted on January 16th, 2012 at 09:55 AM
My 2c
I always love your 2 cents worth Mr Berry
Cheers bloke.
Memberbinner
Threads: 210
posted on January 16th, 2012 at 09:41 PM
arghhhhhhhhhhhh, I just cracked my headlight glass reinstalling the headlights tonite. Anyone got a decent glass lying around to suit my bus?....need it for Fridays RWC. I cant believe I just did that.
posted on January 16th, 2012 at 10:33 PM
Mick should have them, if not give me a call.
Memberbinner
Threads: 210
posted on January 17th, 2012 at 08:56 PM
found one ...... Lee came to the rescue.
Memberbinner
Threads: 210
posted on January 20th, 2012 at 07:02 PM
on road
its finally on the road and for sale now.......... :)
Membertar76
Threads: 95
posted on January 20th, 2012 at 07:28 PM
Loving this thread! For sale hey, í'll let my mate know he could be interested
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
Memberbinner
Threads: 210
posted on January 20th, 2012 at 08:16 PM
yup,for sale already .............. just found something I really want
Memberbinner
Threads: 210
posted on January 27th, 2012 at 06:37 PM
.just converted to a brand new alternator today.....
wiring diagram available anywhere?... what goes where?
Memberbinner
Threads: 210
posted on January 27th, 2012 at 06:40 PM
buy and sell
bought the DC so lets sell this single cab :cool:
 Pages:  1  ..  3  4  5
[ Queries: 40 ] [ PHP: 18.2% - SQL: 81.8% ]
