[ Total Views: 32709 | Total Replies: 563 | Thread Id: 101171 ]
 Pages:  1  ..  4  5  6  7  8  ..  19
Author: Subject:  What did you do on your VW today ???
MemberDubbyDo
A.k.a.: Dave
Threads: 45
Mood: need more compreshunn!
posted on May 5th, 2013 at 01:58 PM
Pulled the RH head and found different numbers cast in it compared to the LH head, don't know if it makes much difference, same size valves and all. More concerned about the fact that the LH head had the shoulder where the barrel butts up machined off and the RH still has the shoulder, maybe that's why it kept pulling to the right:crazy:
MemberTOPCAT69
Threads: 19
Mood: HAPPY DAYS
posted on May 5th, 2013 at 03:56 PM
Well I stuck on another cool sticker
neat huh
You got nothing I want - COLD CHISEL :no:
thread killer :ninja:
MemberSides
A.k.a.: Dave Sidery
posted on May 5th, 2013 at 05:00 PM
Originally posted by 1916baja
Not coming to the show Dave??
Nah man - other stuff had to do this morning unfortunately.
And the weather didn't hold so didn't get any colour on the doors either.
Instead replaced the door speakers in gf's New Beetle, and since they're not designed to be replaced meant had to modify/fab up some mounts which meant a simple job took way longer than it should have.
Why do modern Volkswagen's need to have everything sooooo different compared to "normal" cars ???
:dork:
My toys
MemberDoug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet :)
posted on May 5th, 2013 at 09:04 PM
Picked it up from the panel beater today :)
posted on May 5th, 2013 at 09:53 PM
Took her to a show
Memberesevwbits
Threads: 143
Mood: alive!!
posted on May 6th, 2013 at 09:01 AM
lookin hot matty
Member65standard
Threads: 47
Mood: Only when I'm in it.
posted on May 6th, 2013 at 07:01 PM
Renewed the brake hose between the reservoir and metal line. Not good when you see a puddle at the front of the car. Didn't have to bleed the brakes luckily.
Also changed the horn. The old one was intermittent in operation.
[size=4]If it ain't broke, fix it till it is![/size]
Membernils
Threads: 65
posted on May 7th, 2013 at 05:17 PM
Finished up my rear disc brake conversion, smiley style
http://i275.photobucket.com/albums/jj298/baja53/2013/IMG172_zps146dae9c.jpg
Quit calling rust patina
Member65standard
Threads: 47
posted on May 8th, 2013 at 04:42 PM
Renewed left headlight globe. Blew this morning on the way to work.
Membertar76
Threads: 95
posted on May 8th, 2013 at 07:02 PM
Finished cleaning the muck and crap from the bottom of the beetle's case. Gave it a good clean with some degreaser and tooth brush. then gave it a good coat with the last of my gibbs penetrate.
Luv the sticker Topcat :yes:
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
MemberSmiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on May 8th, 2013 at 07:20 PM
:tu::tu::tu::tu::tu::tu::tu::tu::tu::tu::tu:
Where is the 'like' button?
Smiley :)
Memberbinner
Threads: 210
Mood: want more grunt
posted on May 8th, 2013 at 07:35 PM
i did this
j pipe clamps suck ass, so I really showed it who is boss.....
Memberhrastovica
Threads: 43
Mood: Cruisin
posted on May 9th, 2013 at 03:05 PM
Ross from Skinned Knuckles fixed me a gate from VW parts hahaha :)
The gate is working for the first time in 5 years, the beam is now in the car, the torsion leaves are in and the trailing arms are ready to rumble. Im guessing tomorrow night we should be ready to install everything and hopefully shorten the tierods and im "Rollin rollin rollin".
http://oi42.tinypic.com/28ip76f.jpg
Membergrogy
Threads: 344
posted on May 10th, 2013 at 10:36 PM
i jus sync my webers, cut out paper template to make tin to go around motor and drove it up n down my street, i think my neighbours will b ringing the cops next time, its louder than i would have liked, n goes like stink [ fast that is]
Memberbinner
Threads: 210
posted on May 11th, 2013 at 06:55 AM
call the fuzz
bahh haaaah, Iv'e done that a few times in my street, lucky though my neighbours like me and love seeing the ute out in the street......
nothing like flat reving in yr street at 9pm at night or on the weekend.... :lol:
Membertar76
Threads: 95
posted on May 11th, 2013 at 07:02 AM
going grease the splits front end and jack up and general check over today
"Obey your Dreams"!
62 Std beetle.
Memberdangerous
Mood: 591
posted on May 11th, 2013 at 08:39 AM
How is it now Greg?
You will get arrested in that 11 second beast!
Originally posted by westi
That's mad Alan.
Membergrogy
Threads: 344
posted on May 11th, 2013 at 11:10 PM
hahah dave, i get afreeholiday fun..not. finished cutting up the colorbond for around the motor, took it out for a drive was runnin ok then went off,, took it home took out idle jets ,then moved onto the ghia and adjusted the ghias front suspension to raise it a bit
Memberbuzzbug
A.k.a.: Mr X
Praise the lowered
Threads: 182
posted on May 12th, 2013 at 12:51 PM
Bit the bullet and jumped into painting the floor pan with KBS coatings.
Spent yesterday doing all the prep work and did the painting this morning.
http://i.imgur.com/Fs7ORMN.jpg
http://i.imgur.com/0zKQhRe.jpg
http://i.imgur.com/rpAclVh.jpg
http://i.imgur.com/JdptzUo.jpg
some people are like slinky's
they have no useful purpose
but they are fun to watch
Membernils
Threads: 65
posted on May 12th, 2013 at 06:56 PM
Pretty slick buzzbug:cool:
Memberian.mezz
Threads: 280
posted on May 12th, 2013 at 07:37 PM
set the boost :blush:
:lol::crazy::lol::crazy::lol:
Memberwhathaveidone
Threads: 98
Mood: Heading for 10.99
posted on May 12th, 2013 at 07:47 PM
Helped out a couple driving a bug they just bought in melbourne to the goldcoast. Got a SOS call at 1:30. they bought it over and i had to replace both front wheel bearings. 2 ball joints and make up a steering rod. Got them going about 6. Nice couple. hope they make it home safe!!!!!
Member1916baja
Threads: 176
posted on May 12th, 2013 at 07:54 PM
Nice work Ben!
http://i432.photobucket.com/albums/qq43/1916baja/BigAssWing22.jpg
Memberwhathaveidone
Threads: 98
posted on May 12th, 2013 at 07:58 PM
Robbed some parts off the dragbug!!! Looks a bit sorry at the moment!!!:lol::lol::lol:
Member1916baja
Threads: 176
posted on May 12th, 2013 at 08:02 PM
Hey dude,we did the good deed of dropping an old lady home the other day, 2 weeks later bam! Won the $500 das resto haus raffle! Start putting in lotto tickets mate and remember who told you to do it! ;)
Membershokwave2
A.k.a.: Matt Hamilton
Threads: 28
posted on May 12th, 2013 at 08:05 PM
Now I know who to call when I couldn't be bothered doing it myself :cool:
Today I installed a set of 44 Webers, but now have constant backfiring from the exhaust! It's too dark to be chasing an intake leak, blocked idle jet, or other issue so ill leave it for tomorrow.
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on May 12th, 2013 at 08:08 PM
NICE!
MemberSuper1302
posted on May 14th, 2013 at 08:18 AM
Made a alloy bracket for a accessories jack fitted up under the steering column bolt. And fitting new P seal to rear deck lid. Now to change spark plugs and re-adjust lash on valves.
Memberhrastovica
Threads: 43
Mood: Cruisin
posted on May 14th, 2013 at 08:52 PM
Took the day off to get the king-pins re-reamed, heaps tighter now. Picked up a few missing bits n pieces all going on early tomorrow morning. Hopefully everything is there now, cant wait to see this thing with new stance and wheels :) :)
Memberlou0060
Threads: 30
posted on May 15th, 2013 at 10:12 PM
fitted new discs and pads to the T5 as the warning light has been on for about 4 weeks now. Also did an oil and filter change on the weekend and hitching upo the trailer tomorrow and heading south to Goulburn for the VW Nat sprints. (yes I know I'm a week early...)
1971 karmann ghia Cabrio - Cruising :yes:
1963 beetle Sunroof - gathering dust :fakesniff:
1968 race beetle - twin turbo Subaru - stress relief :smilegrin:
1960 beetle - old school low & slow :smirk:
