| [ Total Views: 293808 | Total Replies: 905 | Thread Id: 36521 ] |
| Pages: 1 .. 4 5 6 7 8 .. 31 |
AdrianH
Threads: 20
Mood: rebuilding again
| posted on May 7th, 2005 at 02:39 PM |
How is extracting every last horsepower out of an engine cheating ? I would call it smart.
pete wood
| posted on May 7th, 2005 at 06:53 PM |
stop using logic Adrian, it just confuses people...:P
Flintstones
Threads: 69
| posted on May 7th, 2005 at 08:32 PM |
| Quote: | Originally
posted by VWCOOL
| Quote: | Originally
posted by hypo-vw
| Quote: | Originally
posted by Turbo54
Hi Wayne,
Are you going to have a ice bucket somewhere for the intercooler?
Looking good,
T54
After each run on the 1/4 mile some of the coolant will be dumped & a quantity of ice added to keep the intercooler temp. down.
I know it's common practice, but that's kinda cheating. It'd be nice to see what the CAR can do, not tricks... IYKWIM
But wow, what a car! Very impressive
[Edited on 7/5/2005 by VWCOOL]
That would be like saying to all the rotary racers not to take out your drivers side headlights to get a cool charge to the turbo!!
Let's be realistic here, at the end of the day your chasing a number, to get the lowest 1/4 mile time and where else are you going to do it
anyway.
You've got to use every opportuntity to your advantage
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on May 8th, 2005 at 11:37 AM |
GEARSHIFT REPAIRS
as previously mentioned the gearshift bracket had to be removed from the tunnel as the hole for the tunnel bush was flogged out . pic shows the
bracket removed from the tunnel
| Error |
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 8th, 2005 at 11:38 AM |
just have a look at how flogged out the old bracket was compared to a new one
| Error |
Team
VWCOOL
Threads: 235
Mood: happy to help
| posted on May 8th, 2005 at 11:56 AM |
| Quote: | Originally
posted by Flintstones
| Quote: | Originally
posted by VWCOOL
| Quote: | Originally
posted by hypo-vw
| Quote: | Originally
posted by Turbo54
Hi Wayne,
Looking good,
T54
anyway.
Yeah... but I'm a great believer in running cars in 'true' street trim. No seats or panels removed, no funny fuel, no 'cheating'. Straight off
the street, as driven everyday. Just my opinion and I have far more respect for people who do it that way (although not many do!)
Pay your debts, CxxT
jakjones
Threads: 3
Mood: Settled
| posted on May 8th, 2005 at 12:57 PM |
you know you don't have to cut a hole in the tunnel to do that repair, you just drill out the spot welds..
[Edited on 9/5/2005 by jakjones]
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 8th, 2005 at 05:35 PM |
| Quote: | Originally
posted by jakjones
you know you don't have to hack a hole in the tunnel to do that repair, you just drill out the spot welds...
you would think a vw specialist would know that
after sanding the tunnel area around the gearshift hole there were no evident spot welds . on further inspection and feeling around in the opening it
was found that the internal bracket had been welded in several places around the edge . I am aware that they are normally spot welded but I had no
choice as to the approach that I took to this repair .
FROM A VW SPECIALIST !!
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 8th, 2005 at 05:37 PM |
the new bracket is welded into the tunnel
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 8th, 2005 at 05:39 PM |
the Gene Berg right-hand drive shifter is installed and adjusted . the gear change now works perfectly !!
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 8th, 2005 at 05:41 PM |
INTERCOOLER INSTALLATION
the intercooler has been thoroughly washed out and fitted with some of the plumbing that I manufactured yesterday .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 8th, 2005 at 05:43 PM |
after installing the intercooler I then started on the electric water pump and hoses .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 8th, 2005 at 05:47 PM |
as previously mentioned , after each run down the strip some of the coolant will be dumped and ice added to cool down the intercooler temperature .
pic shows the coolant drain hose that exits down through the pan via a golf heater tap . this makes it very quick and easy to dump off the coolant
when not on the track .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 8th, 2005 at 05:51 PM |
BODY ASSEMBLY
we have aready fitted door locks , handles , mouldings , headlamps , front bumper , front bonnet lock/cable & handle .
pics show the progress on the body .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 8th, 2005 at 05:52 PM |
front/side view of the body
| Error |
Team
2443TT
A.k.a.: Ian
Threads: 69
| posted on May 8th, 2005 at 06:04 PM |
Nice buildup... its been a while since i've read the forums and its great to see an awesome build up in progress.
Got a couple of questions ... with the decompression spacers how much deck height did you end up running?
Which engine management are you going to run? I'd live to see someone dare to run an autronic and be the first in australia to have traction control
on a 350 RWHP VW!
Got a kaffier brace? a berg traction bar just aint going to cut it when your looking to turn about the 350 hp mark.. there are some good 5 link
systems showed on the germanlook forums and now's the time to fit it... Otherwise your going to snap that tranny like a twig, regardless of the berg
bits.
When it comes to getting the car to hook up on the 1/4, there is some good info on setting up K+L + swing axel combinations on mufflermikes website.
Front and rear suspension tuning. He's running in the 11.90 class with a pull thru 2332 turbo.
About your intercooling, just having a nice sized resivour is enough to keep the air charge cool for the 1/4. Mine is about 6 litres (not counting
whats in the lines. I haven't run ice yet, but havn't needed to. 22 degrees ignition at 17lb boost on 98 octane, no detonation.
Now its winter in cairns, I see air temps around the 25 degree mark at full boost. Having an over rated intercooler means that regardless of boost I
see very little change in air temps. You should see simular performance considering the size of your core. I'd imagine its even better down south
where its cooler.
bajachris88
A.k.a.: Chris Leete
Threads: 534
| posted on May 8th, 2005 at 06:05 PM |
That beetle is no longer gonna be a lil' cute bug anymore. Its gonna be a freakin' beasty monster bug!!! (like off the movie 'Star ship
troopers')
keep it going mate, i gotta see the final product for sure.
[Edited on 8/5/2005 by mynameischris88]
(ô_!_/ô) (ô_!_/ô)
69' baja: kombi box, thing spindles, irs, disc front, type 3 rear drums, 2 inch lift kit, 31x10 rears.
Golde60
Threads: 73
| posted on May 8th, 2005 at 09:12 PM |
g'day wayne.
congratulations on an awesome build up and thanks for sharing the process and details with us on here.
i met you when you were in melbourne for day of the volkswagen last year, we were talking about the exhaust options for t4 engined bugs....
looks like its coming along very well, mate.
i too am having some engineering dilema's with mine, maybe i will give you a ring to have a chat as you seem to have alot of experience with type 4s
going into beetles.
anyhow, keep up the good work and the pictures
pete wood
| posted on May 8th, 2005 at 10:10 PM |
tops wayne, can't wait to see it finished.
pete wood
| posted on May 8th, 2005 at 10:11 PM |
malcolm
Threads: 102
Mood: where did he go!!!!!!
| posted on May 8th, 2005 at 10:36 PM |
wayne are you using the engine iol system to cool the turbo,s bearings or a seperate system.when I was looking at turbo charging the type 4 I found
some porsche,s were using a cnc machined pump to have a seperate oil circuit mainly with the porsches their turbos are mounted low as well and had
trouble with the oil back to the motor.its good to see the end is near when doing a major job.
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 9th, 2005 at 11:58 PM |
| Quote: | Originally
posted by iswinkels
the deck height ended up at 7.5mm . I am running a microtec fuel & ignition management system . yes I do have a rear engine brace ( will post pics
later ) . I know that using the reservoir is sufficient for 1/4 mile drags , my intensions are to use the ice between runs to get the coolant
temperature back down , however I dont think it will get very hot all . great to hear that your system is working so well .:P
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 10th, 2005 at 12:00 AM |
| Quote: | Originally
posted by malcolm
I am using the engine oil system to lubricate and cool the turbo . the oil will return into the L/H/S rocker cover at this stage .
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 10th, 2005 at 12:03 AM |
PEDALS SERVICED
today I removed the pedal cluster to replace the clutch cable and inspect the clutch pedal hook . as suspected the clutch pedal hook was so badly worn
that it was about to snap-off .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 10th, 2005 at 12:05 AM |
I rewelded and remachined the clutch pedal hook to strengthen it so as it doesn't break when pulling the kennedy 3000lb pressure plate .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 10th, 2005 at 12:07 AM |
the accelerator pedal was also welded at the back of the pivots to stop from spreading apart .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 10th, 2005 at 12:09 AM |
both the clutch cable and accelerator cable have now been fitted / lubricated and adjusted .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 10th, 2005 at 12:11 AM |
PLENIN PLUMBING COMPLETED
the plumbing from the intercooler to the plenims has now been completed with all clamps fitted and the blow-off valve installed .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 10th, 2005 at 12:14 AM |
view from inside the oval of the completed intake plumbing . the oval is booked in tomorrow with Lincoln at Teds muffler service Dapto to have the
exhaust plumbing manufactured to the turbo .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 10th, 2005 at 12:17 AM |
BODY ASSEMBLY
tonight the rear apron assembly was fitted along with the rear guards , white guard beadings , rear bumper & brackets.
| Error |
Team
