[ Total Views: 505397 | Total Replies: 178 | Thread Id: 6283 ]
 Pages:  1  ..  4  5  6
Author: Subject:  56 oval rag
Super ModeratorBUGBOY
Chief Toy Dude / Head Cruiser
Threads: 403
Mood: A wise German once said
posted on September 20th, 2007 at 12:22 PM
Big thanks
Big thanks goes out to George Folchi and the judson register for all the help on this one.
Check out the register as its got lots of good info etc.
http://vwjudsonregister.tripod.com/
Everything 36HP !
6-12volt semaphores
Find us on Facebook
MemberGrey 57
A.k.a.: Dean
Old Grey Cruiser
Threads: 355
Mood: (OoVoO) (OVO).
posted on September 20th, 2007 at 12:39 PM
Looking sweet nath. Nice old skool combo. Cant wait to go for ride in this one. When that blower kicks in and the 36horses are unleashed , time will stand still whoo hoo!!!:bounce:bounce
Threads: 403
posted on September 26th, 2007 at 07:18 PM
Stuff
It amazing how much stuff you collect over the years.
been digging though boxes of stuff for the engine build.
Been picking out tinware thats in good order and engine parts.
I worked it out I've collected early beetle stuff for 19 years!
Starting to show my age. :duh
I'm just glad I got a bit of 36hp stuff as most people have just chucked it out over the years.
Everything 36HP !
6-12volt semaphores
Find us on Facebook
MemberVWFREAK
A.k.a.: Peter / Bones
VWFREAK
Threads: 264
Mood: FREAKY
posted on September 26th, 2007 at 07:29 PM
I know the feeling only too well. Great to see another example of the high quality work you put out. I'm sure the little one will love this for there 16th. lol
Threads: 403
posted on October 8th, 2007 at 09:41 PM
engine add ons
Got all the tinware ready for cleaning and also dug out some heater boxes, exhaust and collected some NOS pistons etc at a swapmeet.
Will get all the tinware acid dipped.
Everything 36HP !
6-12volt semaphores
Find us on Facebook
Threads: 403
posted on October 10th, 2007 at 05:59 PM
well after reading the judson forum from front to back or is that screen to screen! LOL
It looks like I need to get myself an oil cooler from a 356.
the 356 oil cooler has more surface area and judsons tend to make motors run hot from what I read.
So this seems to be the method of fixing.
Time to ring around. LOL
[ Edited on 10-10-2007 by BUGBOY ]
Everything 36HP !
6-12volt semaphores
Find us on Facebook
MemberPHAT BUG
Dave says Bini's a fool
Threads: 192
Mood: Drippin
posted on October 10th, 2007 at 09:48 PM
Good luck with the search Nath:thumb
Can't wait to see this thing evolve, top work mate!!
Membervwlfiend
A.k.a.: Chip
Threads: 14
Mood: happy when flat4's are humming
posted on October 12th, 2007 at 03:30 PM
Judson Blower
Bugboy, can you tell me what type of paint was used on your charger housing? I've got to go down the same road as you with getting charger stripped down, vane slop checked etc
54 Beetle..parts
56 Judson Beetle
56 Beetle
Threads: 403
posted on October 17th, 2007 at 08:47 PM
wrinkle black or semi-gloss black paint was the original stuff also.
Best to pop into you local body shop supplier etc
Everything 36HP !
6-12volt semaphores
Find us on Facebook
MemberGASBNR
Threads: 120
Mood: mellow
posted on October 18th, 2007 at 09:40 AM
LOOKS GREAT NATHAN, top job.
SORRY BOUT THAT!
Membervwlfiend
A.k.a.: Chip
Threads: 14
posted on October 18th, 2007 at 08:36 PM
Bugboy, i originally had my blower put straight onto my 36hp, as away alot with drilling i don't get the time to tinker and time to learn
how to do it myself. I should originally had the engine stripped down, end result was i blew a hole in the No 3 piston. Daryll Yates who
was the original owner of Volksmod did the rebuild, bigger oil cooler etc, he did some work on the heads to keep temperature down (not sure what ), but have
had 10,000 miles on it until blower seized, my fault. Make sure idler jet is locktite on as had that suck through, happens a bit. Exhaust was changed to reduce heat but according to Judson forum its better to keep standard as has a effect on Blower vaccum. Have talked to John Moxon about
ceramic coat blower housing bit he's said that most of the heat is generated by compression and not friction. I can get Daryl Yate's number if you want.
Regards Chip
54 Beetle..parts
56 Judson Beetle
56 Beetle
Threads: 403
posted on October 19th, 2007 at 09:58 AM
Thanks for the info chip.
I'm only building the engine stock but with a better oil cooler, nothing else. I knew of the stock exhaust was the best for back pressure.
I think if you look back the unit was made and sold as an upgrade to a stock engine and not really as a high performance unit.
I think this is where people try to get more out of it and in return they get problems.
I'll be building my motor and running it in first and them fitting the kit and run in the blower etc.
Something i'm looking forward to.
Everything 36HP !
6-12volt semaphores
Find us on Facebook
Threads: 403
posted on November 8th, 2007 at 12:20 PM
looking
Well its proving hard to find all the parts to build a 36hp engine, or maybe I'm just not looking or asking in the right places?
I have all the tinware sorted out and ready to be cleaned and painted.
Biggest thing is finding a case thats good in the cam tunnel as they never had bearings here and just ran in the case.
I have a few engines I can pull down but some of them a running fine but once just pulled down you just carn't put it back together if its worn and use it as it was.
If anyone has any 36hp stuff you think i might need feel free to send me a u2u. LOL
So far I have:
77mm pistons sets in a few over sizes.
pushrods
values
cam
Everything 36HP !
6-12volt semaphores
Find us on Facebook
Threads: 403
posted on November 18th, 2007 at 08:53 AM
engines
Still pulling down engines to find parts and cases suitable for rebuilding.
Will be cleaning and crack testing cases and checking cam tunnels on cases next.
I hoping to find a good case straight away and not pull to many apart.
Have collect up a full set of tinware now and are going to get it all cleaned.
I hate dirty engines YUK! :lol:
Everything 36HP !
6-12volt semaphores
Find us on Facebook
posted on November 18th, 2007 at 10:05 AM
looks good Nathan
Threads: 403
posted on December 2nd, 2007 at 06:00 PM
open close case
Well the case is open.
The cam tunnel is fine and very little sign of wear.
But get a load of the cam.
Seem the hardening on the lifter has gone! LOL
Check out the wear also on the cam.
Everything 36HP !
6-12volt semaphores
Find us on Facebook
Threads: 403
posted on December 2nd, 2007 at 06:06 PM
lifters
For those not in the know, the lifter should not have a concave surface on the cam follower.
The one on the right is ok but the one on the left is stuffed.
All will be replace with new parts later.
The one still in the other half of the engine has worn right though and you can now see a hole. LOL
Everything 36HP !
6-12volt semaphores
Find us on Facebook
Threads: 403
posted on December 13th, 2007 at 12:51 PM
Tinware
Well all the tinware has been collected and acid dipped.
Just need to wash it all down and straighten ready for powder coating.
Everything 36HP !
6-12volt semaphores
Find us on Facebook
MemberNevada51
Threads: 41
posted on December 13th, 2007 at 09:10 PM
Good to see the pieces coming together - are you going to go with satin or gloss finish?
Threads: 403
posted on January 30th, 2008 at 08:17 PM
New year new idea?
Well Over Christmas I thought that I should finish the car in 2008. LOL
So I arranged about getting it painted at Delux in Dandy.
Having no idea really about painting a car I thought I'd find out a bit from someone that's built heaps of great cars etc.
So the first thing was finish off a few little bits of welding here and there and strip the car back to bare metal again ready for the paint.
First I stripped the under side and painted it all with POR15.
Sprayed inside all the heater channels etc.
http://i62.photobucket.com/albums/h92/BUGBOY1976/phonepictures067.jpg
Then all the sides and roof where taken back to bare metal.
De-oxidised and etch primed.
http://i62.photobucket.com/albums/h92/BUGBOY1976/phonepictures070.jpg
Everything 36HP !
6-12volt semaphores
Find us on Facebook
Threads: 403
posted on January 30th, 2008 at 08:28 PM
paint
With most of the body now in primer it will be ready to find and repair any little marks and dents etc no picked up before.
Here is a few shots of Sasha putting on some primer.
http://i62.photobucket.com/albums/h92/BUGBOY1976/phonepictures071.jpg
http://i62.photobucket.com/albums/h92/BUGBOY1976/phonepictures018.jpg
http://i62.photobucket.com/albums/h92/BUGBOY1976/phonepictures074.jpg
http://i62.photobucket.com/albums/h92/BUGBOY1976/phonepictures073.jpg
http://i62.photobucket.com/albums/h92/BUGBOY1976/phonepictures072.jpg
Everything 36HP !
6-12volt semaphores
Find us on Facebook
Threads: 403
posted on January 30th, 2008 at 08:41 PM
paint
Still have all the inside to rub down and paint as well as all the guards.
At this stage the next step with the out side of the body will be to block it back to be ready for paint.
http://i62.photobucket.com/albums/h92/BUGBOY1976/phonepictures075-1.jpg
Everything 36HP !
6-12volt semaphores
Find us on Facebook
Membernbturbo
Threads: 89
Theme: UltimaBB Powder
posted on January 30th, 2008 at 09:55 PM
Oh the memories-all good.It's coming along really well.
MemberTurbo54
Mood: Boost'n
posted on January 31st, 2008 at 07:41 AM
Fantastic job, I cant wait to be up to this stage.
Also I love the rotisserie. If it is straight enough, go black.
T54
C'mon kids gather round,
Threads: 403
posted on May 14th, 2008 at 10:22 PM
Starting again
Well everything came to a grinding holt.
I have had a big clean out of some of my stuff,off loaded both my micro busses, twin cab ute even sold the 56 oval that i thought i'd never sell.
:crazy::crazy::crazy::crazy::crazy::crazy::crazy::crazy::crazy:
And now have added another car to my collection.
Some of you my know this car, its been around for some time now.
It in fact was the first ever split beetle that i had ever seen.
The chance to own it was just to hard to knock back!
Work will start on the rag roof oval again soon.
As the sheds bare I have some more room to get to it.
Everything 36HP !
6-12volt semaphores
Find us on Facebook
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on May 15th, 2008 at 09:54 AM
You gunna stick a rag top in it?!
Pay your debts, CxxT
Memberlunar_c
Threads: 16
Mood: Excellent
posted on May 15th, 2008 at 12:17 PM
It's almost a shame to paint over all of that brilliant lead wiping work! You are quite masterful with metal matey, I love the build, especially your choice of the 36hp with the old school blower.
Should be an amazing car to drive!
Regards,
Ben
6 Dubs in and counting..
1966 1300 Deluxe Beetle in polar white.
Memberreub
VWRX is gone...
posted on May 16th, 2008 at 08:35 AM
I'll make sure Sam takes good care of the oval up here dude :tu:
Reub
Membershaven
Threads: 67
posted on May 11th, 2009 at 11:58 PM
bump nath:kiss:
"When the character of a man is not clear to you, look at his friends"
 Pages:  1  ..  4  5  6
[ Queries: 40 ] [ PHP: 11.3% - SQL: 88.7% ]
