| [ Total Views: 19742 | Total Replies: 164 | Thread Id: 78992 ] |
| Pages: 1 .. 4 5 6 |
13b type 3
Threads: 3
Mood: happy
| posted on September 11th, 2011 at 07:30 PM |
yes it sounds great, smells sweet but burns my eyes
( E85 fuel )
pigman
Threads: 2
| posted on September 13th, 2011 at 08:29 AM |
me no you piker not turning up to my partie because you was croock from fumes
Stanley
Threads: 270
| posted on October 18th, 2011 at 10:45 AM |
Aaron....this might help inspire you
http://www.youtube.com/watch?v=JN4_MfQxU7M
5lam
A.k.a.: Dave
AKA: BlackBug
Threads: 38
Mood: Slammed
| posted on October 24th, 2011 at 01:42 PM |
Craziness!
It was good to meet you the other day too. Fuel tank is temporarily fixed lol
20bkombi
Threads: 26
| posted on September 20th, 2012 at 07:52 PM |
Nearly 1 year since I've posted anything on the bus so this is what's happened in that time.
After breaking the input shaft at Warwick last year I pulled down the porsche box again to put the new shaft in which comes with 1st and 2nd gear
$$$$. While it was apart I replaced the pinion retainer studs, grade 8.8( 8mm), with 10mm 12.9 grade and longer as well. The old studs had stretched
and left the nuts loose.
And I now have a $1290 clutch alingnment tool
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on September 20th, 2012 at 08:06 PM |
WOW
Stanley
Threads: 270
| posted on September 20th, 2012 at 08:12 PM |
As much as I'm keen to see the notch still love to see the kombi...hope it all goes to plan and we see big wheels up launches.
20bkombi
Threads: 26
| posted on September 20th, 2012 at 08:17 PM |
After using E85 ( 76%) fron the local caltex, this is what can happen to the fuel after sitting for 4 months.
I then cleaned the whole fuel system out, got the injectors cleaned and flowed. Also I saw the fuel tank had surface rust in it. I put some old fuel
in it with some big washers and sloshed it around replacing the fuel until it came out clean. Then used a tank liner to seal it.
Red Kote.
While the lower half of the intake manifold was off I ported it to suit the engine, about 3mm to come off each port.
Ph 0402 233 027
20bkombi
Threads: 26
| posted on September 20th, 2012 at 08:30 PM |
Thanks guys
I also machined plates on the lower manifold to cover where the exhaust was used to heat up the intake air.
Also machined the turbo cover, just cause for fun.
Ph 0402 233 027
20bkombi
Threads: 26
| posted on September 20th, 2012 at 08:45 PM |
I noticed the rear hub nut was a bit loose because of the huge offset rims (63) caused the hub to ware out. The problem is that there is no support on
the inner, where the spline stops, so I made a brass bush that fits firm.
This is the E 85 form Warwick united petrol station that I'm running this year it's 88%
Ph 0402 233 027
20bkombi
Threads: 26
| posted on September 20th, 2012 at 09:10 PM |
Had the bus on the dyno the other night, because I changed a few things but only got 6 runs, on the last run we just got rid of a miss. It turns out
it was missing from to much fuel 10.9 A/f, with a small change down to 11.3 A/F gained an extra 52hp with lots more to go!!
I'll tune it more at the track.
As we were heading in the right direction a tyre let go at 8500 rpm 4th gear, THATS 303KPH!!!! F... N bang!!
You can see the tread at the back of the dyno room where it landed.
Lucky we weren't hurt.
And some quater damage, it was worse than it looks. But I got it looking ok.
The bus is now ready to race once again
Ph 0402 233 027
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on September 20th, 2012 at 09:22 PM |
Awesome, can't wait to see the wheels up again
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Flintstones
Threads: 69
| posted on September 21st, 2012 at 12:08 AM |
I'm guessing those tyres weren't "Y" rated....
D
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on September 21st, 2012 at 05:40 PM |
Good to see Scott isnt the only one ripping tyres to bits on the dyno LOL
Somehow I think you might be making just a tiny bit more power thatn he did!!
What sort of numbers did you end up with?
humpty
Threads: 139
Mood: Totally boosted!
| posted on September 21st, 2012 at 08:18 PM |
Mad man.....
| Pages: 1 .. 4 5 6 |
