[ Total Views: 12149 | Total Replies: 193 | Thread Id: 83581 ]
 Pages:  1  ..  4  5  6  7
Author: Subject:  Photos of my rusty baja and the work update Jan 15 2014
Membernils
Threads: 65
posted on July 9th, 2013 at 07:46 PM
Great to see you back at it mate
Quit calling rust patina
Memberbaghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
posted on July 11th, 2013 at 10:39 AM
Yep trying to get it done before valla. Really want to drive it up next year.
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
Memberbaghall
Threads: 131
posted on July 11th, 2013 at 11:10 PM
Well got some more work done today. Finished seam welding front shock towers and preped for welding on adjusters (just gotta find the bloody things now).
Also started working on shortening the springplates from swinger to IRS so that I can run with the shorter torsion bars. Will put up photos when the kids return my phone cable, buggers).
Memberbaghall
Threads: 131
posted on July 15th, 2013 at 08:51 PM
finally some more photos
Didn't find adjustors so I ended up modifying old spring plates.
1. Using template for marking out holes
2. pilot holes drilled
3. holes drilled to size
Memberbaghall
Threads: 131
posted on July 15th, 2013 at 08:55 PM
4. Cut to length
5. Shapping ends
6. Enlarging holes with second hole
Memberbaghall
Threads: 131
posted on July 15th, 2013 at 09:01 PM
7. Continue enlarging holes
8. Finishing with a file
9. Test fit to see all lines up and whether enough movement available for wheel alignments.
:tu::tu:
Memberbaghall
Threads: 131
posted on July 15th, 2013 at 09:17 PM
10. Looks OK and can now use the shorter torsion bars.
11.Still looks OK
12. Thought I saw some rust
Memberbaghall
Threads: 131
posted on July 15th, 2013 at 09:22 PM
13. So I cut off these (Never used them anyway, car was too high to use jack safely)
14. Cut out the patch and found that they weren't rust holes but where the jacking point had bracken away underneath.
15. welded patch in and cleaned up.
MemberSmiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on July 15th, 2013 at 10:07 PM
Hey man. Make sure you trim your swinger spring plates down so they are the same width as the IRS ones should be. I think they are 12mm or so wider than the IRS ones so you have to trim 6mm off each side. Measure and check for sure cause I'm pulling these numbers out of memory and they are probably wrong.
If you don't do this you are limiting your down travel cause when it hits the bottom stop will be sooner than it normally does with the IRS plates.
Smiley :)
Memberbaghall
Threads: 131
posted on July 15th, 2013 at 10:16 PM
Yeah thanks Smiley I noticed that but wasn't going to worry about it as I am planning on notching the plates a little anyway and thought that the extra width wouldn't hurt too much.
Memberbaghall
Threads: 131
posted on July 16th, 2013 at 11:56 AM
Not very clear but here are 2 photos of the seam welded shock towers with welds ground smooth.
Membervduboy
Threads: 41
Mood: Dying to get more buggy building time..
posted on July 16th, 2013 at 07:59 PM
Hi mate liking your work so far! I also have my beam out and was wondering if it was worthwhile welding the seams up as well? I dont plan on jumping the car but fire trails, bush tracks will be the norm.. what do you think?
It will all be OK in the end, if it's not OK it's not the end!
Memberbaghall
Threads: 131
posted on July 17th, 2013 at 12:53 PM
Thanks vduboy.
Just helps strengthen them. The Baja and off road bible ( Baja Bugs and Buggies : for Off-Road Fun and Racing) talks about it if I remember correctly. Ran as a baja offroad a lot without them welded and no problems, but I decided to do it because I have the car off the road and well why not. Can't hurt.
Memberbaghall
Threads: 131
posted on July 30th, 2013 at 11:13 AM
Lift kit started
Started work on fabricating a 2" body lift on the weekend. Decided not to buy a ready made kit cause I have already spent way too much on parts for this bug and still have more to get.
Anyway, this shows how I bend curves without a tube bender,with a bit of welding.
1/ cutting and bending curve for side rail
2/ tack welded before welding completely. Can see that gas was not flowing properly. Indicator is the porosity of the welds.
3/ Welded up. Notice much smother welds when gas is working properly.
Memberbaghall
Threads: 131
posted on July 30th, 2013 at 11:17 AM
4-5/ show the welds all around
6/ shows both side rails in place temporarily
Memberbaghall
Threads: 131
posted on July 30th, 2013 at 11:38 AM
7/ Curve over rear inspection hole tacked up. This was done by cutting 20 holes spaced approx 15-20mm (can't remember exactly) apart but found curve was not enough so did another 20 cuts in between the others. All cuts done with 1mm cutting wheel. Curve was not quite enough but I felt that once welded it would tighten to what was needed, due to distortion.
8/ All welded and cleaned and it can be seen, if one looks hard enough, that the curve is almost exact.
Now need to work on the harder sections, but need to get more gas. Those small bottles of gas last no time at all. Think I will need to hire a bottle. Had to finish some of the welding with gasless wire. Hate using gasless.
Membervduboy
Threads: 41
posted on July 30th, 2013 at 11:46 AM
Awesome work mate! Are you welding in crush tubes or captive nuts to hold it all together?
Memberbaghall
Threads: 131
posted on July 30th, 2013 at 12:35 PM
Gonna use crush tubes and was recommended this by the mechanic.
Membervduboy
Threads: 41
posted on July 30th, 2013 at 12:49 PM
That sounds like the best option, probably a lot more dicking around but at least it'll be strong!
Memberbaghall
Threads: 131
posted on July 30th, 2013 at 01:59 PM
:tu:
Memberbaghall
Threads: 131
posted on August 23rd, 2013 at 10:24 PM
Liftkit update
Photos
1. Rear tacked up
2-3 templates for bending flatbar to shape for front of tunnel section.
Memberbaghall
Threads: 131
posted on August 23rd, 2013 at 10:50 PM
1. Marking midpoint of flatbar for even beding to fit over front of tunnel
2. bending flatbar to fit curves using rollers
3. both bars bent (note the difference between inside of curve to outside.)
Memberbaghall
Threads: 131
posted on August 23rd, 2013 at 10:55 PM
1-2. shows bars fitting over templates neat
Memberbaghall
Threads: 131
posted on August 23rd, 2013 at 11:00 PM
1-2 show a neat fit for the bars
3 shows I stuffed up and cut the top bar too short (measure twice cut once) so had to fab up another.
MemberBone
Threads: 43
posted on August 24th, 2013 at 09:23 AM
Looking good. As you probably already know is that the tunnel section lift changes size (not just 2' all the way down sides) so the strap/infill section welded in is a good way to go.
Memberbaghall
Threads: 131
posted on August 24th, 2013 at 10:02 AM
Yeeah wasn't sure how to do this but was told by Mike (CBB) to do it this way. A bit of mucking around but worked well.
Memberbaghall
Threads: 131
posted on August 24th, 2013 at 10:07 AM
1. not as neat but it works
2. tacked in
3. all tacked together now just got to fill in the straps
Memberbaghall
Threads: 131
posted on August 24th, 2013 at 10:10 AM
1. ran out of gas so had to weld in the the sides with gasless wire. I hate using it. Also got really bad welders flu, still getting over it.
2. Front needs to be made up in pieces.
Memberbaghall
Threads: 131
posted on September 7th, 2013 at 05:30 PM
Finally finished welding up the lift kit, but still need to clean up the welds and complete the crush tubes.
Memberbaghall
Threads: 131
posted on October 2nd, 2013 at 08:14 PM
Finally got lift kit finished.
Seems to fit body OK.
 Pages:  1  ..  4  5  6  7
[ Queries: 40 ] [ PHP: 16.5% - SQL: 83.5% ]
