[ Total Views: 53171 | Total Replies: 909 | Thread Id: 91039 ]
 Pages:  1  ..  4  5  6  7  8  ..  31
Author: Subject:  Zelda the '73 1303S
MemberSebastienPeek
Threads: 89
posted on July 18th, 2011 at 10:58 PM
Ahaha thanks Ryan!
Had a look at your thread, seems you had a few issues starting off too, hope all is well now!
The sold one, '73 VW 1303 - Zelda
The project, '74 VW 1303 - Gretl
posted on July 18th, 2011 at 11:10 PM
Inside your air box should look more like this one. Give yours a good clean to find all the rust.
http://i375.photobucket.com/albums/oo199/mattberry-photo/Brads%20L%20Bug%20Racer/10122010165.jpg
MemberSebastienPeek
Threads: 89
posted on July 18th, 2011 at 11:21 PM
Alright, looks like I have a job to do on Wednesday! :D
Same colour too!
posted on July 19th, 2011 at 07:26 AM
That little rust hole to the right of the drain is where the water is getting in.
THat;s what fecking with your indicators, the water is getting into the flasher relay.
Also make sure the drain pipe is nice and clear, they block up with dirt and leaves
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0317.jpg
MemberSebastienPeek
Threads: 89
posted on July 19th, 2011 at 09:11 AM
Joel!
Yep, Mum picked that straight away as well, I am surprised I didn't see it to be honest with you, too busy taking happy snaps... Looks like I'll most likely have to get a new flasher relay?
Or, if I wipe down the current one, I'll have to rip it out anyway to see the damage, would that do?
May actually need to replace a lot of the electrics. Could either be a quick job, or very disastrous.
MemberSebastienPeek
Threads: 89
posted on July 19th, 2011 at 09:33 AM
While I'm at it though, I'll try my hand at fixing up the fan unit as well, most likely not even attached or if it is, then the fan might have, well, a lot of shit in it to be blunt.
What is the best practice for removing it? I would assume remove the bonnet, then get my hands dirty?
While the bonnet is removed, I might try and bang out the left over dents. Shouldn't take too much effort.
Zelda has definitely turned into a little project car, still, I drive her daily, to and from work and school!
Guess it goes to show though, with a little love, beetle's will last.
posted on July 19th, 2011 at 09:41 AM
Most Lbug dash fans are dead, the moisture in there kills them, they don't do a whole lot anyway, i barely used mine in the last 12 years before i ripped it out.
The flasher relay in old cars is mechanical so water getting in them rusts and sticks up all the moving parts.
You can fit newer solid state ones, I had one in mine when i had my LED indicators, i hated it, too quiet.
I was often doing the old fart trick of driving along with them on cos i couldnt hear it.
Mums new Peugeot actually plays the indicator click clack noise through the stereos front speakers, cos the relay itself makes no noise.
MemberSebastienPeek
Threads: 89
posted on July 19th, 2011 at 09:47 AM
Yeah, how did you cope in the winter with the front window frosting over? Mine seems to do it all the time, even if I have the quarter panels open...
So really, I have no choice but to replace the current one with a reproduction flasher relay?
Ahaha I do that anyway sometimes, sometimes they don't like to switch themselves off when I'm turning, but sometimes they do.
I have to admit, that is kinda cool!
I have to follow this eHow, right?
http://www.ehow.com/how_4507818_replace-turn-signal-relay-vw.html
MemberSebastienPeek
Threads: 89
posted on July 19th, 2011 at 07:37 PM
This is what I'm planning on what Zelda will look like, sitting a little lower than stock, but everything else is decent.
http://i1099.photobucket.com/albums/g388/SebastienPeek/Screenshot2011-07-19at93731AM.png
Get those wicked popout rear windows, that is the next thing I want to do once everything is out of the way and she's driving nice.
posted on July 19th, 2011 at 08:49 PM
I just used to put the heat on the windscreen that keeps it clear as long as you're not sitting idling at traffic lights all the time.
Just any 3 pin relay thats the right orientation, VWs are positive on the right from memory.
MemberSebastienPeek
Threads: 89
posted on July 19th, 2011 at 09:19 PM
I may need to learn how to do that then :P
I'm going to figure out how to connect the heaterboxes so that they are either always on or always off, shouldn't be too difficult.
I'm picking up one tomorrow hopefully, a lot is going to happen tomorrow!
MemberSebastienPeek
Threads: 89
posted on July 19th, 2011 at 09:30 PM
Might be giving Stan Popboy a call.
Who says yes to a 1916cc twin port in Zelda?
If I do, what else would need to be replaced? Suspension, gearbox, clutch, I need a list to work through!
I bought some things for Zelda's interior the other day. Looks like she'll be getting her sound system setup done very soon ;)
MemberSebastienPeek
Threads: 89
posted on July 20th, 2011 at 11:54 PM
20th of June, a day to remember in the life of Zelda.
Woke up this morning to find the passenger side mirror completed smashed to pieces and the drivers side one lying on the floor.
Rule number one, don't park Zelda on the road, ever again!
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0318.jpg
After the massive rampage I went on, I went down to Imparts to pick up a couple of things, specifically a new blinker relay, gear rod bush and a correct lens for a rear guard.
Got home and it was time to start working on her. We needed to patch up the rust in the air box (damn there was a shitload) and install the new relay. It all started with the removal of the bonnet.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0321.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0324.jpg
(You can see the arse dent better in this picture).
We then ripped out all the bonnet lining and got stuck into the rust. This is what we found.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0325.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0327.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0329.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0330.jpg
So went down to Supercheap Auto and found us some rust converter and primer. Applied and waited about half an hour, then applied another coat.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0332.jpg
After waiting for the second coat to dry, we started putting on this liquid metal in a tube substance. This worked a treat, filling in everything perfectly. After a few goes anyway, we kept getting tiny pin holes in one of the rust spots.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0338.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0339.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0341.jpg
While we were eating lunch after this was all done and dusted, a package arrived. It was something that was needed for interior fitting. I have photos of what came but they're currently on my other camera. That'll be for another post! Especially what happened after lunch anyway, will post everything tomorrow.
Memberdonn
Threads: 428
Mood: LAID BACK AND CONFUSED
posted on July 21st, 2011 at 07:29 AM
Jeez Seb, you must live in a bogan saturated area, sounds like you wpouldn't want to leave anything unguarded overnight, bloody mongrels. :grind:
MemberSebastienPeek
Threads: 89
posted on July 21st, 2011 at 07:51 AM
It isn't even that donn, I think it was an ex-friend that must have either figured out what car is mine or he's been planning it for a while.
Don't worry, I went crazy when I saw what happened, almost went to his place straight away to letterbox smash.
It isn't that we live in a bogan area, I think because Zelda has character, people look at her. And then they decide to do stupid things.
No doubt the arse dent was from some drunk bloke posing with her.
I'm just happy that now I get a place in the drive way, no matter what. I'm also taking down my P plates wherever I drive her, so it looks like an old farts car. I have a blanket across the back seats now as well, once again, trying to capture the old fart feel!
MemberSebastienPeek
Threads: 89
posted on July 23rd, 2011 at 10:30 AM
Today is going to be big.
Watch this space.
Getting a lot done today.
MemberSebastienPeek
Threads: 89
posted on July 23rd, 2011 at 04:47 PM
Today was supposed to be my speaker install, but kinda turned into a get as much as possible done day.
While waiting for a mate to come down to get the measurements for the sub box and the parcel shelf, I decided to rip the backseats completely out and to see what was in place when it came to sound deadening. I found the following...
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0347.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0348.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0349.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0350.jpg
As you can see, the sound deadening is pretty much non-existent. After doing this, I gave my mate a call and he said he wasn't going to be able to make it today, so currently Zelda has no back seats!
After I'd done this, SpLiTmEiStEr came around with a new set of side mirrors (yes, I know they're not matching) and a set of new windscreen wipers. I only used one of the windscreen wipers to fix up the bent one.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0353.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0355.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0354.jpg
I then decided to give priming one of the guards a go, I only had enough time to put one coat on one of the guards before it started to rain.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0359.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0360.jpg
Who would have thought government property would come in so handy! ;)
Hopefully tomorrow will bring the ability to finish off coating this guard and getting everything ready for the new speaker and sub install. Will post more tomorrow!
MemberSebastienPeek
Threads: 89
posted on July 24th, 2011 at 10:31 AM
Just another little update.
The other day when we were fixing the rust holes in the fresh air box, we installed a new head unit too.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0362.jpg
I also got myself some new anti-theft billet door locks.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0363.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0364.jpg
And I even got myself a new gear knob!
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0361.jpg
MemberSebastienPeek
Threads: 89
posted on July 25th, 2011 at 01:32 AM
Today was a very special day, well yesterday was anyway. It marked the day Zelda got some new and very loud speakers and subwoofer too... Yes, in Zelda.
The aim was to build a housing exactly the same as this, with a custom subwoofer box and so forth.
http://forums.aussieveedubbers.com/viewtopic.php?tid=78247
But instead, we went out on a limb and decided to build something fairly different. It all started with one cardboard template.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0365.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0366.jpg
We then went and got all the wood for the custom subwoofer box, that at this stage we were still going to build. This is what we had and how it was originally going to be like.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0367.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0368.jpg
So that when it was to be mounted inside and with the parcel shelf on top, it'd look like this. But obviously with the holes cut and so forth. Just a mock up.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0370.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0371.jpg
The idea was to rip apart this and mount it all into the new custom subwoofer box that we were going to make. This is the subwoofer that was going to meet it's doom.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0372.jpg
But this is where Mum came out and said, why don't we do it this way? So we decided to give it a shot and this is what happened. The subwoofer would be, in it's current enclosure, mounted within a simpler "box" with the parcel shelf mounted on top still.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0373.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0374.jpg
We than ran into another problem. If we were using the original design, and basing it off of the link I had above for inspiration, it would easily bolt into the body. The subwoofer that I had purchased came with mounts, but they wouldn't be enough to hold in the two sides onto the floor.
So we ripped out the carpet out of Zelda's back section, and figured there really wasn't much else we could do but build a base and rest everything on top. So we did.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0375.jpg
After we knew what was happening with the subwoofer and parcel shelf, we started to wire in the subwoofer to the head unit. We also found a nice little place to mount the bass control remote, nicely tucked away as well.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0376.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0377.jpg
It was then time to make sure we got the base for where the subwoofer would be mounted to and positioned and the speakers all mounted to the parcel shelf perfect before we placed the subwoofer into it's section. A lot of cutting up MDF to make sure everything would fit perfectly for the wires and the subwoofer enclosures bass port.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0380.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0381.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0382.jpg
So once all of this was done, it was time to get the subwoofer and the base into place. I didn't take any photos of the base mounts, but basically four screws (metal screws) were drilled into the bottom of the MDF wood and through the base of rise in the body. This held the base of the enclosure into the car, it wasn't going to move anywhere!
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0383.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0384.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0385.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0386.jpg
We then wired up the subwoofer, screwed the parcel shelf to the top and wired up the speakers.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0389.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0391.jpg
After all of this, the install itself took six hours. Incredible! It was then time to put the back seat back in and see how it all fit. Perfect fit.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0393.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0394.jpg
But that isn't all. Tomorrow comes the task of figuring out how to cover the top parcel shelf and what in. Will post more updates tomorrow when everything is finalised and looking even more awesome!
I forgot to mention, the battery died while we were pumping it for a bit. So we had to push start her the first time to get her back up and running. After I did a lap of the block, I parked out the front and a police car parked on the other side of the road. They had had a complaint of excessive bass from one of our neighbours. First night of having it in Zelda, and the police are already out to get me!
MemberSebastienPeek
Threads: 89
posted on July 25th, 2011 at 11:23 AM
Have discovered that with the current setup, I'm going to have to take the whole assembly out of the car and cover it.
While doing this, I'm going to spray paint the whole assembly black, which means I have to remove the speakers from the parcel shelf, spray, install speakers and then wrap in some sort of cloth.
I want it to be black, so what sort of black cloth will I need? Is there such thing as speaker cloth, where is a simple place to pick it up? Any fabric shop or will it have to be a specialist car audio shop?
Will start the removal process soon, should only take an hour. Good thing is, I build this, and I can put it in any bugs luggage area because they are all the same! So if anyone needs dimensions to make one the same/similar to mine, just hit me up via PM and I'll be able to send you everything you need.
Memberbeetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
posted on July 25th, 2011 at 01:10 PM
Nice work Seb. :tu:
From your ole' mate Jeff
Memberkaiisons
Mood: Dubbin
posted on July 25th, 2011 at 04:44 PM
what about carpet?
MemberSebastienPeek
Threads: 89
posted on July 25th, 2011 at 09:47 PM
So today, things went from good to bad to good.
I pulled everything apart. I figured that I'd paint the top of the parcel shelf black with a spray can. This was to make sure when the speaker grille cloth went over it, it was black underneath.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0395.jpg
I then test fitted it before we went to get the speaker grille cloth. It is black, got it from Jaycar for $18. Bloody cheap and works a treat!
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0396.jpg
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0398.jpg
We then started to line the parcel shelf with the speaker grille cloth. This is where the photos stopped until I'd had it all in place as it was getting dark quick. However, the speaker grille cloth is held in by staples around the back and sides and thumbtacks were hammered underneath the front to give the cloth the tucked under look.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0400.jpg
As you can see though, it doesn't line up at the back anymore. Which is a massive disappointment. However, Mum has found this foam stuff that I can use to stuff down there and cover it up. Hopefully this will fix it.
http://i1099.photobucket.com/albums/g388/SebastienPeek/IMG_0403.jpg
This isn't the finished project either yet. I still have two major factors to do which will blow you away. But, due to school starting back tomorrow, I'll be out of action for a bit and will be enjoying the massive headaches induced by the new subwoofer!
Membershokwave2
A.k.a.: Matt Hamilton
Threads: 28
posted on July 26th, 2011 at 07:24 AM
Nice shelf! I built a similar parcel/speaker shelf on sunday, except no subwoofer. Mine has the two speakers and a flip up lid so i can hide stuff under the shelf. I'll try and post some pics today. I also curved the ends of the shlef so it would sit flush and there would be no gap under the window like you have.
Keep up the great work.
MemberSebastienPeek
Threads: 89
posted on July 26th, 2011 at 09:20 AM
Shockwave,
Originally there were no gaps, but is seems when we covered the MDF afterwards I must have lined it up wrong.
I may have to pull it apart and have another go, but that is going to mean a lot of work and have to recover the parcel shelf again.
We'll see what happens. Seems like my rear seat doesn't close properly either now...
MemberSebastienPeek
Threads: 89
posted on July 26th, 2011 at 10:30 AM
I really hope taking off the speaker cloth isn't going to be a massive pain in the arse.
I'm going to have to rip it off, unscrew the parcel shelf, slam it right at the rear, and screw back in.
Then cover the the shelf back in the speaker cloth. Just going to have to make sure the shelf is clean and what not.
I think I might as well do it tonight after school, really hoping it'll be a simple job. Touch wood.
Seems everything goes a little wrong with Zelda. But we're almost there, and then she'll be finished.
MemberSebastienPeek
Threads: 89
posted on July 26th, 2011 at 10:32 AM
Ordered new window cranks to match the billet door locks.
Also ordered me some new black side mirrors.
Hopefully they come from classic vee dub soon, there online ordering system is a bit weird.
But seems every decent VW store is in Sydney or Melbourne, a fair drive from where I am at.
Memberian.mezz
Threads: 280
posted on July 26th, 2011 at 11:18 AM
you can buy those shelf s alreay made. $65
I hope link works.:blush: page 6
https://www.classicveedub.com.au/cvd_new/parts.aspx?Item_Code=1&Parts_Cat...
:lol::crazy::lol::crazy::lol:
MemberSebastienPeek
Threads: 89
posted on July 26th, 2011 at 11:24 AM
Ian,
I didn't want to buy one pre-made, I wanted to give it a shot building something myself with mates.
I think it turned out pretty damn good, just have to make sure everything is perfect before finalising the designs.
Still have a lot to do, that only this custom shelf would be able to do, if I bought a already made one, the rest of my designs wouldn't be able to be acted upon.
posted on July 26th, 2011 at 12:37 PM
Those pre made ones are way to light and piddly to mount decent speakers to let alone a sub and amp.
Sebastien, make sure the back seat locks back in place once its all in and finished.
You wouldnt believe the damage an unsecured enclosure can do in a rear ender, emergency stop or roll over accident.
Many hatchback drivers have been injured by unsecured sub enclosures in accidents.
The main battery feed to the amp I hope they gave you an inline fuse for and it's fitted right down at the battery?
[ Queries: 40 ] [ PHP: 9.0% - SQL: 91.0% ]
