| [ Total Views: 297821 | Total Replies: 905 | Thread Id: 36521 ] |
| Pages: 1 .. 5 6 7 8 9 .. 31 |
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on May 10th, 2005 at 12:19 AM |
rear engine support bar fitted to the type-4 engine mounts to the mudguard bolts .
| Error |
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 10th, 2005 at 12:21 AM |
NOW DOESN'T THAT LOOK STOCK !! you would never suspect what is to be unleashed from under the lid .:jesus
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 10th, 2005 at 12:23 AM |
a view at the top of the engine lid with hoodjax fitted to scoop in massive amounts of cool air .
| Error |
Team
vw54
| posted on May 10th, 2005 at 07:37 AM |
Wayne
The work looks good, I see its a early 54 Chassis
bit of a shame to cut it up but OH well.
HotRodMatt
If it's old or rare - cut it!
Threads: 361
| posted on May 10th, 2005 at 07:55 AM |
| Quote: | Originally
posted by vw54
I see its a early 54 Chassis bit of a shame to cut it up but OH well.
Never a shame to cut anything to make it better!
pete wood
| posted on May 10th, 2005 at 10:45 AM |
man, bet you can't wait to fool a couple of HSV dunnydores.
Old Hutcho
Mood: NSW Blues supporter to the end!
| posted on May 10th, 2005 at 08:06 PM |
Wayne
How good would that look with white window rubbers mate?
Least people wouldnt confuse my car and your car if they saw them side by side!
Old Hutcho
shiftyvw
Threads: 44
| posted on May 10th, 2005 at 08:21 PM |
dont worry the colour looks better on yours (at least it does now) the original and the best!
will this be finished for the nats wayne? |
GoLfMan
Threads: 14
Mood: supercharged
| posted on May 10th, 2005 at 10:33 PM |
insane man. let us know how it goes on the strip!!
firebreathing 4 potter...
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 12th, 2005 at 01:45 AM |
| Quote: | Originally
posted by vw54
Wayne
no its not a 54' . the chassis is a 1967 1300 delux beetle . the body was found to be very rusty when stripped down , so the 56' oval body was used
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 12th, 2005 at 01:46 AM |
| Quote: | Originally
posted by shiftyvw
yep , thats the plan at this stage .
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 02:04 AM |
MORE PROGRESS
old 60's style sports steering wheel fitted
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 02:06 AM |
TURBO SYSTEM FITTED
the start of the manufacturing process of the turbo plumbing by Lincoln @ TEDS MUFFLER SERVICE DAPTO .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 12th, 2005 at 02:08 AM |
the primary exhaust pipes are tach-welded in place
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 12th, 2005 at 02:09 AM |
the primary pipes are removed from the oval , to be fully welded
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 02:11 AM |
the secondary pipes are manufactured and fitted in place . the turbo is then mounted in the position that it will be fitted
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 02:13 AM |
a view of the engine from the rear of the oval to show you the turbo and air filter location
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 02:16 AM |
all of the turbo plumbing is now completed . I now only have to fit the wastegate . pic shows turbo connected with 3" diameter outlet pipe .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 12th, 2005 at 02:17 AM |
all of the pipework is also now completed for the intercooler and connected
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 02:26 AM |
MORE PROGRESS TONIGHT
the complete front end has been removed from the oval
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 02:28 AM |
the alloy front beam is fitted complete with disc brakes
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 02:29 AM |
a tandem brake master cylinder and a collapsable steering shaft has also been fitted for driver safety
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 12th, 2005 at 02:33 AM |
a view of the extensive turbo system plumbing from under the left rear guard . I'm certainly not looking forward to removing it all to have it HPC
coated , but that will be after the VW nationals drags .
| Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 02:35 AM |
another view from under the left rear guard , where you can see the 3" diameter exhaust heading to the rear of the oval
| Error |
Team
Turbo54
Mood: Boost'n
| posted on May 12th, 2005 at 10:53 AM |
I thought you couldn't get stuff HPC'd after you've run gas through them as it tend not to stick as well or are you not doiing the inside?
T54
Were are you getting the HPC done, I need to do the tops of my pistons and valves and inside my head chambers? thanks.
C'mon kids gather round,
NigeType3
Threads: 32
Mood: Speedy
| posted on May 12th, 2005 at 11:06 AM |
Cool stuff so far!
What brake combo you using on this beasty, it looks trick.
dangerous
Mood: 591
| posted on May 12th, 2005 at 07:08 PM |
Any caster shims Wayne? What specs on front & rear alignment do you plan to run?
| Quote: | Originally
posted by westi
That's mad Alan.
Craig Paton
Threads: 68
Mood: Absolutely Gratefull..!
| posted on May 12th, 2005 at 07:30 PM |
Hey Wayne
Cannot believe how quick you're putting this beast together!
One thing though, is the alloy front end! Aren't they a bit "iffy" for street use as far as wheel alignment.(Pot holes etc.)
And finally do they save about 80-100lbs?
Cheers Craig |
debiasi4
Threads: 51
| posted on May 12th, 2005 at 10:22 PM |
ive had used pipes coated before - they blast it first with a very fine abrasive first
we just had some combustion chambers, pistons and valves done in adelaide at maxwell motors in st peters
hypo-vw
Threads: 82
Mood: hypo cruis'n
| posted on May 12th, 2005 at 11:00 PM |
| Quote: | Originally
posted by Turbo54
T54
you can get your pipes HPC coated if they have been previously used , but they must be blasted first . The pipework on my turbo cabrio was done at
Competition Coatings in Sydney . If you use him , keep the pressure on him as he tends to promise dates and doesn't keep to them . Does a great job
though !!
Team
