[ Total Views: 290872 | Total Replies: 905 | Thread Id: 36521 ]
 Pages:  1  ..  6  7  8  9  10  ..  31
Author: Subject:  WPVW turbo oval progress - 443bhp (10.13@139.70mph)
Memberhypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:04 PM
Originally posted by NigeType3
Cool stuff so far!
What brake combo you using on this beasty, it looks trick.
I am using modified late beetle discs up front with superbug calipers and late beetle rear brakes . I chose drums for the rear as the handbrake is a lot more efficient at the start line . Also using tandem brake master cylinder .
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:06 PM
Any caster shims Wayne? What specs on front & rear alignment do you plan to run?
plan to run 1 degree positive camber on the rear and 3mm toe-in on the front . the rest I will have to make up as I go . depends if the bloody thing goes in a straight line !!
[Edited on 28/5/2005 by hypo-vw]
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:10 PM
Originally posted by Craig Paton
Hey Wayne
Cannot believe how quick you're putting this beast together!
One thing though, is the alloy front end! Aren't they a bit "iffy" for street use as far as wheel alignment.(Pot holes etc.)
And finally do they save about 80-100lbs?
Cheers Craig
I will have to try and avoid large pot holes on the street to look after the beam , but will be pulling it back out to narrow it in the near future . this will also help to stiffen it a little . the weight saved is closer to 35 pounds .
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on May 12th, 2005 at 11:12 PM
MORE PROGRESS TODAY
today Karen from KARENS AUTO TRIM , Shellharbour came to the workshop and fitted the new headlining .
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:13 PM
headlining fitted and finished
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:15 PM
today I fitted the wastegate to the secondary engine pipes but haven't yet finished the dump-pipe .
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:16 PM
the HAWAIIAN white rubbers and front guard beadings are fitted and looks great !!
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:17 PM
side view of the white rubbers
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:18 PM
rear view of the white rubbers
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:19 PM
how's the view through the rear oval window
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:21 PM
the LT-8 micotec computer is fitted and the wiring loom to the engine is connected
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:23 PM
there wasn't enough space in the engine bay for the mallory promaster ignition coil , so it has been fitted in the back of the oval
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:25 PM
rear view of the oval with the taillamps now being fitted and the electrics being sorted .
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 12th, 2005 at 11:28 PM
this will blow you away !! pic shows the last rego label still attached to the front screen ( 1989 ). this is the screen from this car as the oval was stripped at my workshop 5 years ago and has been stored under cover since .
MemberDoug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet :)
posted on May 13th, 2005 at 12:51 PM
Arrrgghhh youre killing me with the white rubbers !!!!
But its not my car is it, so I'm very happy that you like them.
This is an absolute work of art, and its just incredible how quick its going together !!!
Make sure you post some action shots and links to some video once the beast is firing in anger !
posted on May 13th, 2005 at 01:01 PM
what rims is it getting?
MemberNigeType3
Threads: 32
Mood: Speedy
posted on May 13th, 2005 at 01:53 PM
I luv the white rubbers makes it look more like a church goer.
You should put wide std rims on it so you can have white walls to.
That will fool everyone hehehehehe
MemberDoug Sweetman
Threads: 58
Mood: sweeeeet :)
posted on May 13th, 2005 at 01:58 PM
Yeah, that'd look shit hot !
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on May 13th, 2005 at 04:44 PM
hey wayne are the headers your using to take the exhaust forward from the heads, are they custom made or are they the stock ones off a 914( type 4 without the cooling fins) cause this is very similar to what i want to do with my exhaust on chaos minus the turbo for the moment. how do they go for ground clearance. btw i wasnt bagging you before just saying that it would be in the grey area of the design rules.
the chaos project - click me
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on May 13th, 2005 at 09:53 PM
the rims are empi BRM's that are 15"x5.5" in silver 5-stud as pictured below
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 13th, 2005 at 09:57 PM
rear quarter view of the BRM's . unfortunately due to excessive wheel track problems in the front end , stock 4-stud rims will be used at the VW drags next week . this will be rectified by narrowing the front beam shortly after this event and the BRM's also fitted to the front in 5-stud
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 13th, 2005 at 09:59 PM
the rear of the oval finally looks complete with tail lamps and empi number plate frame . now I just need the number plates !!
posted on May 14th, 2005 at 09:34 AM
looks tops wayne. Shame I won't be there to see you race...:(
Membermalcolm
Threads: 102
Mood: where did he go!!!!!!
posted on May 14th, 2005 at 10:24 AM
wayne i noticed the blow off valves go to atmophere for reg don,t they need to be recycled back into the inlet system for induction noise.
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on May 14th, 2005 at 10:34 PM
a 1967 beetle doesn't have to comply with any AUSTRALIAN DESIGN RULES , so I am not aware of the legallities of venting the blow-off valve to atmosphere ( it is only an air pressure relief valve / NO FUEL ) . I will have to see what the engineer has to say and what it has to comply with for engineering purposes . Thanks for the comments though !!:duh
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on May 14th, 2005 at 11:01 PM
MORE PROGRESS TODAY
today I spent the entire day doing all the crappy little jobs that needed to be done to complete the oval job properly . All of the factory wiring at the front of the oval is now repaired and connected ( headlamps , speedo , switches etc ) . I then manufactured the dump pipe from the waste-gate to the 3" engine pipe and welded it in place . After fitting up the engine pipe I then assembled the rest of the exhaust system and did a final fit-up including manufacturing support brackets . and finally fitted the battery box and did a dummy fit-up of the internal housing that will cover the turbo assembly . the box still has to be welded together . Eaton Fluidpower @ Unanderra manufactured and delivered the oil pressure line to the turbo and Fred @ Turbologic has the oil drain hose that I will collect on monday . all going well the oval should fire-into-life on monday afternoon . first pic shows the dump pipe welded to the engine pipe
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on May 14th, 2005 at 11:02 PM
view from inside the oval of the turbo now complete with wastegate connected
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on May 14th, 2005 at 11:04 PM
view from the rear of the engine of the waste-gate in the background and where the dump pipe is ducted to
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on May 14th, 2005 at 11:05 PM
view from under the rear of the oval showing the design of the exhaust system
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on May 14th, 2005 at 11:07 PM
rear view of the oval showing the exhaust outlet
[ Queries: 40 ] [ PHP: 15.1% - SQL: 84.9% ]
