[ Total Views: 10115 | Total Replies: 245 | Thread Id: 23205 ]
 Pages:  1  ..  7  8  9
Author: Subject: need help with ej20t conversion
MemberJeza
Threads: 23
Mood: Spinning
posted on November 4th, 2004 at 06:17 AM
Anthony
You mean front struts like these
http://www.beetleracing.com/catalog/product_info.php?cPath=21_24&products...
Which is what Jak and Blue74l are running, and similar to what Steve C has/ had on the yellow bug.
I admit I made my own, mostly because I wanted to learn- but mine are untested and may need changes to the springs etc.
The V-Force ones are well road/ track tested
Jeremy
......random gibberish for today.......
Member71superbug
The Itch Itcher
Threads: 72
Mood: Subified
posted on November 4th, 2004 at 08:31 PM
thanks jeza. they are the sort of thing i was looking for.
would these also allow me to run a wider wheel up front??
i am currently running a 185 tyres all round but hope to run 205 up front and 235 at back. what sort of mods would be needed to run these?
Memberseagull
Threads: 752
posted on November 4th, 2004 at 08:39 PM
are you ready for a drag yet !
Member71superbug
The Itch Itcher
Threads: 72
Mood: Subified
posted on November 5th, 2004 at 01:25 AM
is who ready for a drag yet?
wat would be needed to run 205 up front and 235 rear?
or would there be a better combo?
Anthony
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on November 7th, 2004 at 09:58 PM
Seagull....
Give me 4 weeks and I will meet you in the desert for that drag we spoke about!
P.S. Do not forget the dirt bike!
Matt
Member71superbug
The Itch Itcher
Threads: 72
Mood: Subified
posted on November 9th, 2004 at 06:45 AM
This is my competition around the household. what you guys reckon? well this aswell as a new cv8 monaro. Has bigger turbo, Front mount intercooler, rebuilt motor. I think it ran a 14.1 on 8psi. brother sometimes runs 14 psi though. (its an auto)
http://img.photobucket.com/albums/v514/supaficial/thecompetition.jpg
[Edited on 8-11-2004 by 71superbug]
MemberJeza
Threads: 23
Mood: Spinning
posted on November 9th, 2004 at 07:52 AM
Anthony
A lot depends on your chosen wheels offset, and what guards you choose to run. Offset is best measured by another term (often confused) called backspace. This is the distance from the mounting surface to the most inner part of the rim, ie the bit that will conflict with the suspension. For Supers I believe the limit under standard guards is 7 inches on the front, but best to check with what others have done.
It appears that your wheel width is goverened by rules in various parts of Australia- so best you check with your local people. Hot rod clubs are great source of info for this. Or kit car / scratch build car clubs.
Tyre selection I reckon then depends on your power output.
CT runs 185's and 205's on his oval and he races it with a 1916cc motor. Bugs are really light at the front so you want to get a tyre that will warm up and be suitable with very little weight on it. Tyre width and profiles also affect the way the car will handle, ie understeer / oversteer etc.
So no short answer really, just more things to think about and research, unless you just want to look good then I'd say go for 17s and phat is good.
Have fun
Jeremy
Member71superbug
The Itch Itcher
Threads: 72
Mood: Subified
posted on November 9th, 2004 at 08:03 AM
i would want to fit under stock guards if possible.
was thinking a rim like this
http://www.tempetyres.com.au/products_closeup.asp?part=ITEM+%237003&part_...
(will need to copy and paste whole thing into browser)
what do you guys reckon.......i know they are 5 stud. and i would have to change to that. but they are 17x7 inch .
Anthony
 Pages:  1  ..  7  8  9
[ Queries: 40 ] [ PHP: 9.0% - SQL: 91.0% ]
