[ Total Views: 5108 | Total Replies: 80 | Thread Id: 100275 ] |
Pages: 1 2 3 |
whathaveidone
Threads: 98
Mood: Heading for 10.99
posted on December 28th, 2012 at 10:01 PM |
cant belive with all the technology available,lapping valves is still done with a stick and a suction cap between 2 hands!!!!!!!!!!!
Nice work guys
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on December 29th, 2012 at 06:57 AM |
Quote: | Originally
posted by whathaveidone
Nice work guys
my local engine reconditioner has spent 150K on a machine that cuts valve seats in the heads and it does an awesome job , but being a bit 'old
school' I still like to lap the valves in and check the seat sealing , especially after I have been playing in there with a die-grinder ......
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 5th, 2013 at 07:58 AM |
we are using an additional 4 new rims with new Hoosier race tyres on Horace for his come-back to speedway
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 5th, 2013 at 08:05 AM |
a new CSP oil pump relief cover and aeroflow oil fittings have been fitted to the engine .
Berg swivel feet adjusters will be used also this time to take a bit of load off the valve guides . I soak the swivel feet in auto trans oil prior to
assembly to ensure that I get lubrication into the ball of the swivel
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 5th, 2013 at 08:14 AM |
new scat race race pushrod set is cut to the length I need and the tips are installed .
After installing the rockers and adjusting tappets I find that the 42mm inlet valves are striking the pistons .... so heads back off and pistons out
to have the valve notches enlarged .
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 5th, 2013 at 08:22 AM |
while I work on the engine , Cindy helps Ben with the assembly of a new battery isolation switch and replacement of all electrical terminals .
with the valve notches re-machined the engine is assembled and new inlet manifold gaskets are cut to match the ports . The inlet manifold has also
been welded and requires minor porting
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 5th, 2013 at 08:25 AM |
a new Scat welded & balanced cooling fan is used , the engine is assembled , carbs cleaned , exhaust fitted and the engine is back in Horace
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 5th, 2013 at 08:27 AM |
aeroflow oil fittings are fitted to the oil lines , breather box is cleaned and connected , and a new tacho is installed
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 5th, 2013 at 08:30 AM |
the fuel system has been fully cleaned and filters replaced , the race harness belt is removed and will be replaced .
Horace has his own personalised trimmed seat ..... complete with shit stain !! lol
Error |
Error |
Error |
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 5th, 2013 at 08:32 AM |
the engine has been run , basic tune set and it is off to the dyno this morning at 10am for tuning .
If all goes well at the dyno , Ben Ford will be racing Horace at Nowra speedway tonight ......
Error |
Error |
Error |
Team
coletrickle
Threads: 34
posted on January 5th, 2013 at 10:28 AM |
Waiting for news!
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 5th, 2013 at 10:50 AM |
Horace dyno results
well, extremely happy with the dyno results from the 1641ml engine in Horace .
We went to the dyno at 10am , first run made 95.7hp @ the wheels and with some minor tweaking we ended up with 105.8hp @ the wheels and 757lbs of
tractive effort (which is almost as much as my blue sports sedan) and by 11.15am we are back at WPVW .....
This gives us 1.05hp per cubic inch of capacity @ the wheels .
looking forward to watching Ben give those water-pumpers a thrashing tonight , and playing pit-crew for him .
Error |
Team
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
posted on January 5th, 2013 at 11:05 AM |
Top stuff - good luck
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on January 5th, 2013 at 12:21 PM |
Great result Wayne.
Did you do any 4th gear runs ?
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on January 5th, 2013 at 12:29 PM |
Well done!!
Would be cool to see it run
coletrickle
Threads: 34
posted on January 5th, 2013 at 03:37 PM |
Exellent fellas!Got me all motivated to pull my finger out and get my old 1585 back together.Do your thing tonite Ben!Shame I can't be there
tonite!Is there an event around the Sydney event in feb?Ill come early or stay late to see Horace Do his stuff!
airkool_little_bastard
Banned
Threads: 6
posted on January 6th, 2013 at 12:11 AM |
When you’re racing, it’s life. Anything that happens before or after... is just waiting.
Super1302
posted on January 6th, 2013 at 07:59 AM |
what happened?
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 6th, 2013 at 09:14 AM |
Quote: | Originally
posted by Super1302
what happened?
It was disappointing to say the least to see Horace perform so crap after such good preparation results , we haven't looked into it too deep as yet
to determin what the smoke is caused from , but the drematic loss of power was a result of 2 broken rocker arms on no.3 cylinder . Unfortunately I
didnt have any spare rocker arms with me to replace them .
These are the same rocker arms that I have always used on this engine and they are stock VW arms on solid rocker shaft assemblies .
I have changed the valve springs , added swivel feet adjusters and new pushrods . My thoughts at this early stage is that the increased rocker angle
with the swivel feet adjusters may be just too much load for the stock rocker arms with the new heavier bugpack dual springs .
We also have 1 plug showing very lean and 1 plug very oily .
We will get horace back to WPVW , remove the heads and barrels for inspection and report from there ......
thanks for posting the vid .... great footage..... I will check the 2 incar vids and get them posted also
Team
whathaveidone
Threads: 98
posted on January 6th, 2013 at 09:26 AM |
Dam
hypo-vw
Threads: 82
Mood: hypo cruis'n
Quote: | Originally
posted by Craig Torrens
Great result Wayne.
no Craig , we did all the tuning in 3rd gear only ..... and then the power runs in 2nd gear as this is the only gear we use on the track during a race
. It gives us an accurate comparison between Horace and other speedway cars that we have built engines for and tuned .
Horace made 105.8hp @ the wheels , in comparison we built the engine for the orange datsun 1600 (car 18) , tuned it on the dyno in 2nd gear also as
this is the gear he runs in and it made 92.8hp @ the wheels . Another datsun 1200 coupe I assisted with and tuned on the dyno made 113hp @ the wheels
Team
coletrickle
Threads: 34
posted on January 6th, 2013 at 09:31 AM |
Bummer,did you have to clearance the rockers for the swivel feet?
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 6th, 2013 at 01:44 PM |
Quote: | Originally
posted by coletrickle
no Col , the rockers dont have to be clearanced for the Berg swivel feet adjusters , as the rocker assemblies are spaced away from the valves with
0.090" shims and pushrods are then cut to the correct length
Team
tayloredvw
Threads: 39
Mood: make love not war
posted on January 6th, 2013 at 08:36 PM |
Hey wayne, bad luck about the engine trouble.
Just wondering what type of sealant do you use to seal the oil lines into the case?
Doug Sweetman
Threads: 58
Mood: sweeeeet
posted on January 6th, 2013 at 10:35 PM |
Unlucky mate, sorry to hear. I'm ire ome investigation into geometry and loading will clear it up for you. Sounded brilliant on the YouTube vid !
2442supercharged
Threads: 2
posted on January 7th, 2013 at 10:01 PM |
pics of broken rockers
Error |
Error |
Error |
dangerous
Mood: 591
posted on January 8th, 2013 at 07:10 AM |
I used that same rocker set up on all my engines until I stepped up to the Pauter heads and it worked well.
Even with 460lb chevy valve springs and on my AF heads when I ran my nines.
VW rockers are forged steel, so perhaps something bottomed out.
Adjuster looks to be out a bit far, but that is not really relevant in your issue.
Great engine combination and power!
Quote: | Originally
posted by westi
That's mad Alan.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on January 8th, 2013 at 08:31 AM |
Wayne
Noticed the spring shimms in the heads and was intent on asking simply out of interest before the failure........Do you tighten up the springs to max
rates from bind or happy to run just them to stop chaffing on the head?
Nice little engine
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 8th, 2013 at 07:55 PM |
Quote: | Originally
posted by hellbugged
Wayne
Nice little engine
I like to measure the installed height of the retainer , collets and valve on all 8 valves , then I shim the springs so that they have even spring
tension and leave minimum 0.060" from coil bind .
Team
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on January 8th, 2013 at 08:04 PM |
Quote: | Originally
posted by dangerous
Ben Ford came up with a reasonable theory taday Dave , 2 years ago Horace broke an inlet valve and badly bent the exhaust valve on no.2 cylinder ,
perhaps the rocker assembly was on the other side of the engine back then and the rocker arms had been stressed ?? maybe ....
We will pull the heads and barrels from Horace tomorrow and get it sorted so that Ben can run Horace at Parramatta Speedway this saturday night in the
street stock class .
The promoter of the class ( which is mainly Holden commodores and Ford falcons) approached us last saturday night and asked if we would be interested
in bringing Horace to PCR and running at the rear of the field , mainly as a crowd pleaser !!
We gladly accepted , so Horace goes to PCR this saturday night !!
Team
Pages: 1 2 3 |
