[ Total Views: 4258 | Total Replies: 31 | Thread Id: 100448 ]
Author: Subject:  July 1972 in blue
MemberDoug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet :)
posted on July 7th, 2014 at 06:38 PM
Engine is now nearly fully dressed and ready to install once I am done with bodyworking.
http://i254.photobucket.com/albums/hh94/dougsweetman/1972%20S%20Bug/20131203_194931_zpsr1ttzy01.jpg
Bit of an improvement from when I got it;
http://i254.photobucket.com/albums/hh94/dougsweetman/1972%20S%20Bug/IMG_0813_zpse657e236.jpg
Have also rebuilt both rear axles / CV's (learned a lot doing this !!!! like not all cv joints take the same size balls.....) and put new Bugpack silicone boots on
http://i254.photobucket.com/albums/hh94/dougsweetman/1972%20S%20Bug/20140113_195104_zps41otle55.jpg
http://i254.photobucket.com/albums/hh94/dougsweetman/1972%20S%20Bug/20140210_214232_zps0rbi0x9y.jpg
MemberDoug Sweetman
Threads: 58
Mood: sweeeeet :)
posted on July 7th, 2014 at 06:44 PM
Last thing I have done was to cut the old accelerator pedal off the rusty section of floorpan that was removed and weld it on to the new repaired section.
http://i254.photobucket.com/albums/hh94/dougsweetman/1972%20S%20Bug/20140705_170730_zpsrl4z8dhw.jpg
I don't have a MIG or TIG welder, so thought I would have a crack at doing it with my trusty Lincoln HandyStick 130 DC Inverter stick welder. Grabbed some 1.6mm 6012 rods and @ 35amps managed to glue the two pieces of ~1mm thick sheet metal together.
http://i254.photobucket.com/albums/hh94/dougsweetman/1972%20S%20Bug/20140707_150130_zpsvduwcy0q.jpg
Welds are certainly not pretty but are plenty structural enough for what they hold together.
http://i254.photobucket.com/albums/hh94/dougsweetman/1972%20S%20Bug/20140707_150113_zpsttr84qer.jpg
Very pleased not to have blown any holes doing this - my first experiment using a copper chill / backing strip to soak up some of the heat. Worked a treat.
http://i254.photobucket.com/albums/hh94/dougsweetman/1972%20S%20Bug/20140707_150047_zpszwuq6slt.jpg
http://i254.photobucket.com/albums/hh94/dougsweetman/1972%20S%20Bug/20140707_150827_zpsb54qfkwj.jpg
http://i254.photobucket.com/albums/hh94/dougsweetman/1972%20S%20Bug/20140707_150838_zps8f42zixz.jpg
Next destination is either headliner and get the windows back in..... or replace bailey channel and scrapers in the doors, then door handles and ignition barrel replacement. Not sure yet.
[ Queries: 40 ] [ PHP: 8.5% - SQL: 91.5% ]
