[ Total Views: 3605 | Total Replies: 42 | Thread Id: 100791 ] |
Pages: 1 2 |
SuperOwen
Threads: 67
posted on May 2nd, 2013 at 07:16 PM |
Yeah they're going back up to around that height. If you cant be fast be spectacular!!
DavoBuggy 1641
Threads: 12
Theme: UltimaBB Pro Orange
posted on May 3rd, 2013 at 01:29 AM |
Nice work dude, good to see the buggy has found a good home.
Keep up the good work.
See you at the showdown!
Cheers Dave!
SuperOwen
Threads: 67
posted on May 10th, 2013 at 01:12 PM |
Snuck the buggy onto the dyno this morning just to get a baseline run for comparison after we hot the motor up a little bit after the VW Sydney meet.
As a bonus I got an extra 10 RWHP to play with next meeting just from pulling some timing out! Add 1000rpm to the numbers on that sheet for what the
engine was actually pulling.
Error |
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
posted on May 10th, 2013 at 01:34 PM |
Wow, 145.6hp from one cylinder.........
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
whathaveidone
Threads: 98
Mood: Heading for 10.99
posted on May 10th, 2013 at 01:41 PM |
Cool!!!!pays to dyno hey. Might see that 11 yet!!! Specially if you use the other three cylinders
SuperOwen
Threads: 67
posted on May 10th, 2013 at 03:58 PM |
Quote: | Originally
posted by 11CAB
My secret is out.....
SuperOwen
Threads: 67
posted on June 22nd, 2013 at 11:04 PM |
Been tinkering a bit more with the Buggy. Worked out the gear ratios so I could get accurate numbers off that dyno graph, peak power is about 6600
rpm. I've got the two step working properly now and setup on a dial which I can adjust from inside the car. Once we have a working launch rpm I can
just unplug the adjustable chip and put a regular one back in so it doesn't get bumped etc.
The cooling system has been changed over to a regular type one setup and another breather line added on the case. Also rewired the o2/rpm logger setup
so it doesn't lose the log if you forget to stop recording before switching the ignition off, which has happened every run so far where I didn't
forget to start logging....
Rebuilt the rear brakes as well, a blown wheel cylinder had leaked all over the shoes and left me with a one wheel braking system, still stopped ok,
just a bit spongy on the lever
If everything works out on the day I'm pretty confident of going 12.0x and maybe even an 11.9, then the engines getting pulled and hotted up a bit
for warwick.
Error |
Error |
Error |
SuperOwen
Threads: 67
posted on July 19th, 2013 at 09:27 PM |
We decided to pull the buggy motor apart for a quick health check before the next meeting. It was running fine but has been together for quite a few
years in various cars before the buggy so was due for a checkup.
While it was apart we decided we may as well get a bit more power out of the old girl as well.
Everything looked like new inside apart from some minor cam thrust wear so we replaced them and put the bottom end back together as it was.
Error |
Error |
SuperOwen
Threads: 67
posted on July 19th, 2013 at 09:34 PM |
The top end changes are a bit more interesting.
Previously we only had 8.2:1 compression mainly due to a really trick set of Fred Simpson ported heads with massive chambers for turbo use. We didn't
feel like flycutting a nice set of heads that much so after rummaging through the shed we settled on some old ARPM heads, ported with matching IDA
manifolds. The smaller chambers on these will push us up to 10.8:1 and which will hopefully wake the motor up but still be pump fuel friendly
(Cheep!!). Had a few issues with rocker clearance but some thicker lash caps sorted that (thanks dave).
Error |
Error |
SuperOwen
Threads: 67
posted on July 19th, 2013 at 09:43 PM |
These heads should make some decent power, four digit flow figure.
So with more comp, better heads, IDA's and probably a bigger exhaust I'm hoping for a decent drop in times, 11.80's is realistic I think. We'll
put it on the dyno next week before hopefully running the test n tune in a fortnight.
Error |
cnfabo
Threads: 140
posted on July 19th, 2013 at 09:53 PM |
Quote: | Originally
posted by SuperOwen
Wow you can Almost put a fist in there,lol........
SuperOwen
Threads: 67
posted on July 19th, 2013 at 10:29 PM |
Might need a some "assembly" lube though.
cnfabo
Threads: 140
posted on July 19th, 2013 at 11:52 PM |
Quote: | Originally
posted by SuperOwen
Pages: 1 2 |
