[ Total Views: 3223 | Total Replies: 65 | Thread Id: 101517 ] |
Pages: 1 2 3 |
ian.mezz
Threads: 280
posted on April 8th, 2013 at 06:36 PM |
eg
Powerplus 102+ Unleaded Racing Fuel is specifically engineered for normally aspirated and Turbo - Super Charged engines. Compression
Ratios from 8:1 to 14:1. It is formulated with power enhancing oxygenates, to help engine builders and race teams push their engines to the limit when
competing in events where maximum power and torque is required. Suitable for engines developing up to 650+ Horse Power.
whathaveidone
Threads: 98
Mood: Heading for 10.99
posted on April 8th, 2013 at 07:20 PM |
Im just going off what the rep told us on sat Ian. Ill double check on friday when i get home.
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
posted on April 8th, 2013 at 07:31 PM |
Octane rating for methanol looks like around -110-115
ian.mezz
Threads: 280
posted on April 8th, 2013 at 07:40 PM |
Quote: | Originally
posted by whathaveidone
yeah the stuff they make black rubber hoses out of these days is good stuff
1916baja
Threads: 176
posted on April 8th, 2013 at 07:58 PM |
I think the 105,108,110 and methanol require the teflon hoses guys.... The 102 does not.
typethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on April 8th, 2013 at 08:06 PM |
Either way mick I'm running to tunes in my car, race on methanol and a petrol tune to flush the system
Stanley
Threads: 270
posted on April 8th, 2013 at 08:07 PM |
I used to be able to get hold of avgas from work but no more....avtur anyone
matberry
posted on April 8th, 2013 at 08:09 PM |
Well put in telon hoses. Bugger all difference when using braided lines. I use teflon on all the efi engines as it is better for stable pressures at
the injectors and the higher pressures used.
1916baja
Threads: 176
posted on April 8th, 2013 at 08:17 PM |
Yeah, i'll be using the good hose and fittings for the system regardless.... Im just looking around as to what fuel is available to run. I think this
is a good thread, There has been alot of info bought up here that i havent managed to find on here before. I have emailed powerplus race fuels to see
what they reccomend and how much it is.
And Troy, it'd be nice to have efi! unfortunatly 2 seperate tunes on a holley just aint that easy!
typethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on April 8th, 2013 at 08:40 PM |
Could always just drain your tank and drain the fuel bowl and flush with petrol... Lol
modnrod
Threads: 50
Mood: Old School Volksies!
posted on April 8th, 2013 at 10:30 PM |
Quote: | Originally
posted by typethreeking
That's not a bad idea.
I've seen guys in the pits pull off the $1000 JET 830 annular methanol after a trailer pass, plonk on a Holley500 with adaptor, feed it 100octane out
of a fuel jug slung off a bonnet hook, then idle the car for a couple of minutes before shutdown for the meet.
After that it's just rinsing then blowing out the lines/tank at home later.
westi
what the
Threads: 28
Mood: not blue, pink
posted on April 8th, 2013 at 11:33 PM |
coming out soon,hopefully.
just got my new valve springs,so just need to find some time to put it back together,
i kinda got jammed by jambo as always,everyone wants there cars finished,so the poor old junka cops second fiddle as always.
i have fuel at 102 oct,but it's realy only for streeters.and e85 is good,but regaurdless of what you hear or read it is corrosive,so meth is the
best,you can buy a couple of different kinds of meth.n1 is the same amount of work as the e-85.
coogee is alittle more matainence but worth it because it is so sooo cheap.
use what ever suits your budget.
down sharon.
humpty
Threads: 139
Mood: Totally boosted!
posted on April 9th, 2013 at 01:28 AM |
No cooling on Micks new engine though Troy. I have the same problem with my new combo.... I reckon meth will be in my future too.... But by all means
keep this chat rolling.... I need more info and convincing too.
1916baja
Threads: 176
posted on April 9th, 2013 at 03:11 PM |
Quote: | Originally
posted by humpty
Good one humpty, you stopped the thread!
matberry
posted on April 9th, 2013 at 03:14 PM |
lol TC Humpty
whathaveidone
Threads: 98
posted on April 9th, 2013 at 06:30 PM |
Just keeping it alive
Stanley
Threads: 270
posted on April 9th, 2013 at 07:41 PM |
I'm still coming to terms with Westi coming out soon.
whathaveidone
Threads: 98
posted on April 9th, 2013 at 08:30 PM |
We all knew long ago!!!! Just being supporting!!!
westi
what the
Threads: 28
posted on April 9th, 2013 at 11:29 PM |
me and stock,more than just freinds.lol
down sharon.
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on April 10th, 2013 at 05:31 AM |
Friends with benefits? Lol
humpty
Threads: 139
posted on April 10th, 2013 at 11:33 PM |
Quote: | Originally
posted by 1916baja
Quote: | Originally
posted by humpty
Hahahahhahahaa.... We aim to please Mick!
dragvw2180
Threads: 33
posted on April 13th, 2013 at 12:10 AM |
I know how expensive c16 is , I pay $ 17.50 a gallon here locally but really my car does not use much per pass. I do not have cooling tin and drive it
back to the pits after each pass usually get about two to three passes per gallon.
If you go with alcohol make sure your complete fuel system is compatable and will not corrode or dissolve , been there and done that. Mike
McCarthy
P.S. I let a friend get his first passes in my turbo car at our race at Piedmont , after he had problems I made one pass to make sure it wasn't the
car , darn that felt good !!! I am the fat man with sunglasses hahahha
1916baja
Threads: 176
posted on April 13th, 2013 at 06:50 AM |
I have decided to go with pp105 race fuel, it suits my budget at the moment and down the track I can convert to meth if I want to experiment more.
Thanks.
20bkombi
Threads: 26
posted on April 14th, 2013 at 07:57 PM |
Good choice Mick.
Suits your budget and much less time needed to maintain.
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
whathaveidone
Threads: 98
posted on April 14th, 2013 at 08:11 PM |
Have been doing a bit of reading this weekend and am looking into VP ROO16. Just the same as VP16 but oxigenated to makd it a more stable burn.
better for boosted engines!!! Am going to contact the local rep and have a chat
1916baja
Threads: 176
posted on April 14th, 2013 at 08:20 PM |
Be good for your "boosted" engine then aye Ben! Let us know how you get on...
whathaveidone
Threads: 98
posted on April 14th, 2013 at 08:23 PM |
whathaveidone
Threads: 98
posted on April 14th, 2013 at 08:25 PM |
I ment for yours!!!!
1916baja
Threads: 176
posted on April 14th, 2013 at 08:28 PM |
Hmmm yeah ok...
Stanley
Threads: 270
Maybe it is boosted Mick....rumour has it
Pages: 1 2 3 |
