[ Total Views: 8388 | Total Replies: 90 | Thread Id: 104493 ] |
Pages: 1 2 3 4 |
LOWBUG
Threads: 33
Mood: OUT OF CONTROL
posted on January 30th, 2014 at 04:13 PM |
Will it be ready for Sydney event?
RISKY4LIFE
posted on January 31st, 2014 at 08:05 PM |
i dont think it will be ready for sydney ! and i hope the welds on the safety chain and hitch plate are mega good ! i have even seen 2 links welded on
safety chain ! anyways awesome trailer ! will it have a break away system ?
RodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
posted on February 1st, 2014 at 07:33 PM |
Kev , the idea is to be able to use the trailer to get the buggy and car to the Sydney event . This way I only have to do one trip with everything I
need . It may not be totally finished on the inside , but the internal lining and fit out can be done as I find the time .
I have spent days trying to design a rear door assist mechanism and am happy that it all works well . I have purchased some components from a garage
door supplier and actually made it all fit . The rear door at the moment is about 48 kg's in weight and is a bit heavy to lift . Now with the assist
, I can do it with one hand . I managed to get the flooring cut today and will I will cut the tie down holes tomorrow and glue it all in place , ROD.
Error |
Error |
Error |
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
RodPenrose
Threads: 330
posted on February 1st, 2014 at 07:35 PM |
Flooring .
Error |
Error |
Error |
RodPenrose
Threads: 330
posted on February 6th, 2014 at 07:29 PM |
Progress is so shitty at the moment with so many stuff ups . Before I started on the trailer I confirmed with the tyre shop that I can get a 15 x 6"
mag wheel as a std replacement wheel as I have std wheels off a commodore to use as a set-up wheel . 2 weeks ago I went to purchase the 6 mags and now
he informs me that they are in fact 6.5" with a slightly different off-set . After exhausting all avenues I decided to order new hubs in a ford 5 x
114.3 pattern as this is very common . I ordered the wheels to suit , and had the new tyres fitted to only find that the new hubs need to have the
centre bore machined to fit . This has now been done and the wheel nuts now are a special order due to the small mounting holes in the wheels . I went
to bolt them on tonight and they are still not correct as the tool for the lug bolts will not fit in the rims . I will have to do some more running
around tomorrow to try to fix the problems .
I have managed to secure the floor and I have cut all of the interior lining sheets as it was easier to do this now before the exterior sheets are
attached . Yesterday the exterior sheets turned up and if I can get it back on it's wheels tomorrow I will sheet it over the weekend . I have also
given it a wheel alignment and tightened all of the suspension bolts and with the addition of grease nipples , all lubed ready to roll , ROD.
Nickster
Threads: 34
Mood: Rolling with 'The Dub Collective'
posted on February 6th, 2014 at 07:41 PM |
Excellent work Rod, a man on a mission!
1962 Deluxe Beetle
1970 Low Light Microbus
1303Steve
Threads: 556
posted on February 6th, 2014 at 08:11 PM |
Hi Rod
Good work on the trailer. Check here for special wheel nuts http://www.niceproducts.com.au/
RodPenrose
Threads: 330
posted on February 7th, 2014 at 07:20 PM |
Steve , thanks for the link , I have an account with Nice and they didn't have what I need . Today I made some brackets that were welded to the top
of the frame so I can mount the pit tent as well as extra attachment points just in case I want to make a larger purpose built awning . I attached
some rear supports to the rear of the trailer so it will be stable when not coupled to a vehicle . I ended up sorting out the wheels problems and now
they are all mounted .
Error |
Error |
Error |
RodPenrose
Threads: 330
posted on February 7th, 2014 at 07:24 PM |
I ended up with a 15 x 6" wheel with a +45 off set . The tyres are a 185-65 and now I have some extra tyre clearance . Tomorrow I will start to sheet
the sides and maybe the roof , ROD.
Error |
Error |
Error |
modnrod
Threads: 50
Mood: Old School Volksies!
posted on February 7th, 2014 at 10:12 PM |
Quote: | Originally
posted by RodPenrose
Nice and shiny Rod!
New Corolla Accessory rims?
RodPenrose
Threads: 330
posted on February 10th, 2014 at 11:55 AM |
I had a big weekend and with some help from Klaus , and I managed to mount the sides . The sheets are 4.0 m x 1.5 m and are a 3 mm thick aluminium
composite . Gloss black on the outside and gloss white on the inside . I also managed to start on the propeller plate lower sections , ROD.
Error |
Error |
Error |
RodPenrose
Threads: 330
posted on February 10th, 2014 at 12:01 PM |
Inside view of the framework and the sheets . The sheeting is attached with a flexible urethane compound called Sikaflex . Today I will trim the roof
sheets ready for attachment . I also have some joining moulds for the sheets that are a mill finish only , so they are getting powder coated gloss
black today , ROD.
Error |
Error |
Error |
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on February 10th, 2014 at 01:17 PM |
love the black
mactaylor
Mood: even my dog is german
posted on February 10th, 2014 at 03:14 PM |
sikaflex is the best rod, so many compounds and sticks like shit to a blanket! I use it on a daily basis and cant spruke it more!
EVERLAST CONCRETE TANKS
1800 552 123
gordysbeetle
Threads: 19
posted on February 10th, 2014 at 03:30 PM |
It won't get a vin number. It will get it's own post code.
Super1302
posted on February 10th, 2014 at 08:48 PM |
Good work Rod, keep it come'n
humpty
Threads: 139
Mood: Totally boosted!
posted on February 12th, 2014 at 01:04 AM |
That's an extremely sexy trailer Rodney.... Awesome work.
modnrod
Threads: 50
posted on February 12th, 2014 at 04:10 PM |
Gday Rod.
It looks like I might have something to play around with here at work that could possibly use some of that ally composite sheeting you are using for
your build.
Could you please provide a link or a manufacturer name or something so that I can check the stuff out?
Thanks,
Dave
RodPenrose
Threads: 330
posted on February 13th, 2014 at 07:20 AM |
Dave , there are a few different brands around , Alupanel , composite panel , The one I am using is Q Bond out of Vic I think . The Q Bond is
available in a 1220 x 2440 , 1500 x 3050 , 1500 x 4000 and 2000 x 4000 sheet , in about 30 different colours on each side . I am happy with the
product as it is easy to cut , bend and attach to the framework of my trailer . I can weigh a sheet for you , but I think the 1220 x 2440 sheets are
about 12 kg's . The sheets have a plastic protective coating on both sides , ROD.
modnrod
Threads: 50
posted on February 13th, 2014 at 08:52 AM |
Perfect!
Thanks man!
RodPenrose
Threads: 330
posted on February 13th, 2014 at 08:08 PM |
Well , a couple of big days have seen me finish the sheeting , install the windows , and thanks to type 3 Chris , the 240 volt wiring has been
installed and neatly routed through the frame . Tomorrow I will do the sheeting on the doors along with all of the capping for the openings . I have
also had a small roller machined up that I will mount in the tailgate so the winch cable will not scuff , ROD.
Error |
Error |
Error |
RodPenrose
Threads: 330
posted on February 13th, 2014 at 08:10 PM |
Here is an inside view looking through the rear door . The wiring will be hidden out of sight , ROD.
Error |
Error |
RodPenrose
Threads: 330
posted on February 14th, 2014 at 08:36 PM |
Another productive day today . I attached the front sides and sealed all of the roof with the urethane to make it water proof . I will put a hose on
it tomorrow before I start the capping to double check for leaks . I also lined the 3 doors and they will be capped and fitted tomorrow , ROD.
Error |
Error |
Error |
RodPenrose
Threads: 330
posted on February 14th, 2014 at 08:39 PM |
The doors will lay flat tonight with weights added to prevent the sheets lifting , ROD.
Error |
Error |
Error |
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on February 14th, 2014 at 09:53 PM |
Good show
Is the car race car ready to go ?
RodPenrose
Threads: 330
posted on February 15th, 2014 at 08:36 PM |
Daimo , the car is ready to go . I did all of the prep work after Adelaide and was going to run it just before Christmas and pulled the pin due to the
heat .
I managed to get the roller fitted today that will support the winch cable as it runs over the ramp . The ramp also has all of the propeller plate
fitted and should be edged tomorrow . I also managed to do some of the rear capping over the top of the rear door , ROD.
Error |
Error |
Error |
RodPenrose
Threads: 330
posted on February 19th, 2014 at 07:46 PM |
I have added the sheets to the outside of the rear door and the anti rattle pins are welded in place . I have also added a few thin strips of
aluminium angle that is already powder coated black to the rear of the roof . The aluminium angle is a mixture of 50 x 25 and 70 x 25 in 1.6 . ROD .
Error |
Error |
Error |
RodPenrose
Threads: 330
posted on February 20th, 2014 at 07:07 AM |
I have also attached the 25 x 25 x 1.6 angle to the rear door as a finishing mould for the flooring . The 3 front doors hare also mounted and are
waiting for the edge mouldings . ROD.
Error |
Error |
Error |
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on February 20th, 2014 at 08:05 PM |
Awesome work Rod. Pushrod tube seals arrived today- thanks.
RodPenrose
Threads: 330
posted on February 27th, 2014 at 06:21 PM |
Well , I didn't end up finishing the trailer in time for the Sydney event last weekend . All was good until last Tuesday when the edge moulding were
attached to the doors and they would not fit back onto the trailer due to the hinges . I didn't leave enough room for the hinges and they fouled on
the edge mouldings . I have cut off the hinges and replaced them with some good quality stainless hinges to only find that they have way to much slop
in them . I then replaced them with a stainless piano hinge and still no good . Today I have purchased some more of the original hinges and I will now
modify them to suit my needs . ROD.
Error |
Error |
Error |
Pages: 1 2 3 4 |
