[ Total Views: 8558 | Total Replies: 103 | Thread Id: 104990 ] |
Pages: 1 2 3 4 |
Dalyrics6
Threads: 14
posted on June 18th, 2014 at 12:34 AM |
Pics
Error |
Error |
Error |
Dalyrics6
Threads: 14
posted on June 18th, 2014 at 12:35 AM |
Anyone want any of these? I have no use at all for them
Error |
Error |
Error |
Dalyrics6
Threads: 14
posted on June 18th, 2014 at 12:37 AM |
Pics
Error |
Error |
Dalyrics6
Threads: 14
posted on June 18th, 2014 at 12:39 AM |
Pics
Error |
Error |
Error |
Dalyrics6
Threads: 14
posted on June 18th, 2014 at 12:40 AM |
Pics
Error |
Error |
Error |
Dalyrics6
Threads: 14
posted on June 18th, 2014 at 12:41 AM |
Pics
Error |
Error |
Dalyrics6
Threads: 14
posted on June 18th, 2014 at 12:42 AM |
Pics
Error |
Error |
Error |
Dalyrics6
Threads: 14
posted on June 18th, 2014 at 12:43 AM |
Pics
Error |
Error |
Error |
Dalyrics6
Threads: 14
posted on June 18th, 2014 at 12:44 AM |
Pics
Error |
Error |
Error |
Dalyrics6
Threads: 14
posted on June 18th, 2014 at 12:45 AM |
Pics
Error |
Error |
Error |
Dalyrics6
Threads: 14
posted on June 18th, 2014 at 12:46 AM |
Pics
Error |
Error |
Error |
Dalyrics6
Threads: 14
posted on June 19th, 2014 at 10:04 AM |
Just went on the JustKampers Site, Found a master cylinder for beetles from 67 thru to 98, however when i asked if it would fit mine, i waws told it
wouldnt and the part i needed would cost $280!!! from $60 to $280...
i need:
The Master Cylinder $280
Tyres $110@
Paint fix $250+
Air Filter $35+
looks .like a fare bit of saving to do... then again, i
did by a beetle to do this haha
Dalyrics6
Threads: 14
posted on July 5th, 2014 at 01:52 PM |
Removed the flywheel, replaced the main seal and painted the components...
Error |
Error |
Error |
Dalyrics6
Threads: 14
posted on July 5th, 2014 at 01:53 PM |
More pics
Error |
Error |
Dalyrics6
Threads: 14
posted on July 15th, 2014 at 08:43 PM |
I am seriously thinking of painting my Door trims and my seats black with Dupli-Color Vinyl Paint, Anyone else tried this? i don't have a lot of
money at the moment and think it will be a cheap solution to buying new one's.
Scottkombi
Mood: Sick of Work
posted on July 16th, 2014 at 08:02 PM |
Vinyl paint is amazing stuff - I have paited a few steering wheels with it (2 bay kombis) and it looks awesome and has yet to fade or get sticky even
on hot sweaty days.
Definately worth a try.
88 Caravelle Syncro Camper
89 Caravelle GL microbus - 5 speed
69 Microbus
05 Mk5 Golf 1.9 TDi DSG
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
posted on July 16th, 2014 at 09:25 PM |
I have used it on sections of my door cards, and it is very good, but after about 5 years of quite heavy use, it is wearing off in places.
From your ole' mate Jeff
Dalyrics6
Threads: 14
posted on July 16th, 2014 at 11:08 PM |
Thanks for the reply's, I am thinking of painting just the door cards for the time being and seeing how it looks before I try the seats, however I am
not sure on how many cans to buy? How many cans did you use Jeff? Also my cards are bent up at the bottom corners after being left in direct sunlight
for the past 16 years,is there a way to fix tthis? I was thinking of using a heat gun to heat it to the point of flexing them. Or should I just buy
new ones?
Thanks.
Dalyrics6
Threads: 14
posted on July 16th, 2014 at 11:11 PM |
Example
Error |
Dalyrics6
Threads: 14
posted on July 16th, 2014 at 11:12 PM |
Drivers side isn't to bad...
Error |
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
posted on July 17th, 2014 at 12:14 AM |
I made up custom door cards & had them trimmed in Black Vinyl. I have then fitted door pockets on them, which is what I painted black - I only
used 1 can to do it all, but prep. it VERY well.
This is the front door card setup, with a large open pocket, a pocket with a door, a courtesy light at the front, and a 'clearance' light in the VW
emblem at the back -
And this is the rear card setup, which just has a pocket on it.
I hope this gives you the idea.
Dalyrics6
Threads: 14
posted on July 17th, 2014 at 01:12 PM |
That looks really good. I may have to try somthing similar later on. Also what sort of car are those rear seats from? They look really comfortable.
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
posted on July 17th, 2014 at 09:18 PM |
They are the original rear seats from my car - I just re-did them.
The old upholstery was shot, so I stripped them down to the frame. I then got a pair of old front seat backs that had adjustable head rests, stripped
them down, cut out the frame section I needed, and had them welded into my old seat back.
The bloke that did my interior then worked some magic on them to make them look good.
Dalyrics6
Threads: 14
posted on July 20th, 2014 at 10:11 PM |
They look amazing haha great job!
I have another question at the moment... My transmission is leaking in multiple places... I will upload pictures however, is this an easy fix for a
beginner? Or should I get it professionally rebuilt? Also what would it cost to rebuild it my self vs a general price for a mechanic to do so?
Error |
Error |
Dalyrics6
Threads: 14
posted on July 26th, 2014 at 11:22 PM |
I was in the process of installing my Engine after replacing the Main Seal however i am having difficulties with lining the transmission shaft up? i
have the engine supported by a trolley jack sitting half on the shaft however it seems as if somthing is stopping the engine from sliding all the way
onto it. Can any one please help? i dont want to break anything.
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
posted on July 27th, 2014 at 10:12 AM |
You may not have the splines lined up. Grab the fan belt and turn it around slightly to see if that will line up the splines.
Bizarre
Threads: 730
posted on July 27th, 2014 at 10:31 AM |
and it needs to go in straight
remember you are at a bit of an angle
Dalyrics6
Threads: 14
posted on August 22nd, 2014 at 01:37 AM |
Had to relocate the bug today, at least it's now closer to home.
And as the engine I am still having difficulty installing it, I have however ordered a clutch allignmdnt tool as I didn't have one but was told they
are a good thing to have
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
posted on August 22nd, 2014 at 06:19 AM |
Ooh yeah. If you don't have it aligned properly, it will be a big struggle.
Dalyrics6
Threads: 14
posted on August 23rd, 2014 at 12:07 AM |
yeah haha, i never thought about getting one as this is my first engine install. But after finding out the hard way i think its best to get it, it was
only cheap to so even if it don't work (even though it will) its still worth a shot.
Pages: 1 2 3 4 |
