[ Total Views: 6701 | Total Replies: 83 | Thread Id: 106854 ] |
Pages: 1 2 3 |
chellejohno
Threads: 7
posted on September 7th, 2014 at 12:37 PM |
Put the radiators in for their final fit, all went well, sorted out the wiring in the engine bay for the fans etc. Ready to slip the engine in, just
waiting on some heater hose to connect up before I put it in as it looks a bit tight to get to once the engine's in place
Error |
Error |
Sunnyjim
posted on September 7th, 2014 at 08:00 PM |
great work
johnno
Great work
Coming along nicely !
chellejohno
Threads: 7
posted on September 12th, 2014 at 07:16 PM |
Spent yesterday afternoon and today putting the engine back in and connecting stuff up, all went well, no real hiccups. Put the original exhaust
headers on along with the catalytic convertor, facing forward towards the front of the car, I think it sits really well as I'm going to bring it back
around similar to karman141 did to keep heat out of the engine bay.
Then late this afternoon the moment of truth arrived, I hesitantly connected the battery terminals and waited, sure that I'd be able to see or smell
wires melting, but all good, turned the ignition on, still all good and kicked her over. Once the fuel was thru she ran beautifully, I'm so bloody
relieved.
Still need to fit up the radiator hoses etc and finish connecting things down the dash end of the car, but all in all, really happy.
Error |
Error |
Sunnyjim
posted on September 15th, 2014 at 11:38 PM |
fuel pump noisy?
hey chelli
I am interested in how your fuel pump turned out ?
l first bought an ebay copy , it was nice and quiet but couldnt keep up with the flow.
then I bought an original bosch 044 model . it now keeps up with the flow but geez it is friggin noisy .
what is your experience so far.?
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on September 15th, 2014 at 11:58 PM |
I have a Bosch 044 fuel pump. I cant hear it over the roar of the exhaust or the tunes out of the speakers. Actually thinking about it, I don't
notice it at idle. Maybe the rubber mounted clamp is enough for me to not notice it.
chellejohno
Threads: 7
posted on September 16th, 2014 at 08:11 AM |
Quote: | Originally
posted by Sunnyjim
hey chelli
Hey Paul,
I actually commented to a mate that your pump was really noisy when we started the car up but to be honest with you it's not really noticeable, it
might be more noticeable when we get the muffler on and quiet it down a bit.
How bigs your inlet fuel hose, I'm running 10mm in, 8out, like helbus did. Just thought if your not getting enough fuel to the pump it might be sort
of cavitating and thus the noise.
Cheers Johno.
chellejohno
Threads: 7
posted on September 17th, 2014 at 07:41 PM |
Connected up the throttle today, I used the original linkage, just welded a bolt to it and put it straight thru where the original cable end would
have gone on the throttle body, with a couple of washers and a nyloc nut. Also fitted the carbon canister.
Error |
Error |
Sunnyjim
posted on September 17th, 2014 at 08:27 PM |
looking great
chellie
looks great
Did u have to use a sheath over the accel cable? I had to otherwise it got caught
I went an bought a universal accel cable so it could be one piece all the way through.I heard some others have joined theirs
What did u do?
Sunnyjim
posted on September 17th, 2014 at 08:29 PM |
Chellie
what have u decided for the air intake?
just a pod out front ?
or are you going to bend it around to try to get cold air?
chellejohno
Threads: 7
posted on September 17th, 2014 at 10:02 PM |
Hey Paul,
Yep I made up a plastic sheath that runs from the end of the existing tube to the bracket on the new reverse manifold, only thing that I reckon I've
gotta do is put a spring on the cable as it's not returning all the way on its own, not that it's binding, just sometimes it doesn't quite make it
back.
As for the intake, I'm just running a pod facing straight toward the rear, like helbus ran. I'll see how it goes.
helbus
A.k.a.: Pete S
Threads: 312
posted on September 17th, 2014 at 10:25 PM |
I was able to use a stock VW bus accelerator cable. The modification was in the mount point to the throttle body, but the cable being stock means a
standard replacement is available.
chellejohno
Threads: 7
posted on September 18th, 2014 at 04:49 PM |
Quote: | Originally
posted by helbus
Yep I've stuck with the standard cable, came out spot on length wise, and as you've said just modified the mounting point
Sunnyjim
posted on September 18th, 2014 at 08:15 PM |
good to hear
I must admit wasn't too sure how to route the cable, probably went the long way and I also do have lots left over!
chellejohno
Threads: 7
posted on September 25th, 2014 at 07:40 PM |
Well, been a busy few days, but worth it. Been waiting over three weeks for hoses that I'd ordered which were supposedly in stock. They arrived
yesterday, well most of them, enough to get by, but not quite the set up I want. Put an exhaust on too, nothing elaborate just a muffler and tailpipe
exiting just in front of the rear wheel, looks pretty neat.
Connected up the hoses today and started her up, took a while to bleed the air out of the system, I was a bit worried at first, temperature seemed to
be a bit high, but once we got the air out it runs quite cool.
Drove it around town for a while, didn't want to go too far in case I had to walk, then took it for a 100k round trip. Ran beautifully, temperature
behaved itself, all in all very happy with the result.
Error |
Error |
chellejohno
Threads: 7
posted on September 25th, 2014 at 07:43 PM |
While I've been mucking around with the suby motor my beautiful wife has gave the interior a much needed revamp. She recovered the side panels, and
the rock n roll bed/seat, and made new curtains, looks great.
Error |
Error |
Sunnyjim
posted on September 26th, 2014 at 07:24 PM |
Johhno
that wife is a keeper!
ian.mezz
Threads: 280
posted on September 29th, 2014 at 02:32 PM |
that left radiator hose fitting needs to be on the bottom of the radiator. while they are out just get a 10m bleeder bolt put in the top .
As hot water comes in the top radiator hose and cools as it drops down and flows across the radiator and out the bottom hose back to the engine. the
water in the bottom half of the radiator isn't cooling correctly.
ian.mezz
Threads: 280
posted on September 29th, 2014 at 02:34 PM |
I just looked at pictures BOTH radiators fitting need to be moved to bottom of the radiators .
if you came into my shop and said my car over heats at HWY speed or towing , I would say that your old radiator was half blocked the bottom would be
full of rust and crap etc .
But in your case the bottom half of the radiators are really doing nothing as they wouldn't be flowing correctly just like they were blocked, because
water isn't flowing efficiently
ian.mezz
Threads: 280
posted on September 29th, 2014 at 02:52 PM |
It would also help if you got some plastic 20l drums cut them up and put behind the fans so that the hot air is pushed out the bottom of your bus and
as you drive at speed its sucked away the hot air . here is a pic of my plastic job
Error |
ian.mezz
Threads: 280
posted on September 29th, 2014 at 03:07 PM |
Also I just looked at a Subaru and you seem to have the Radiator hoses on the wrong way around .
As you don't not seem to have any of the hoses from the motor going to the top of the radiator .
the top radiator hose from motor should go to the top of the radiator .
ps its great to see that you got in and got it done .
vlad01
Mood: Side ways
posted on September 29th, 2014 at 03:27 PM |
Only reason they go on top is for bleeding purposes. When the radiators in/outlets are on the sides it only matter you use the lower one feeding the
engine, because you don't want air cavitating the pump.
Looking at the pic, he's got it right. Lower rad fitting on the RHS rad doing to the engine inlet.
71 notchback,
ian.mezz
Threads: 280
posted on September 29th, 2014 at 03:38 PM |
Or just don't take any notice of my observations and just put one radiator , one fan and a two hoses
one to the top and a hose to the bottom of radiator and fit it towards the front of the car .
ian.mezz
Threads: 280
posted on September 29th, 2014 at 03:40 PM |
Quote: | Originally
posted by vlad01
the lower hose seems to going to the middle of a side ways fitted radiator .
something's wrong its getting hot.
vlad01
Mood: Side ways
posted on September 29th, 2014 at 04:28 PM |
not enough air flow obviously.
It would be to do with the aero.
Also radiators aren't optimal size and side tank design wise. But 90% of the problem will be air flow I bet.
Time to add a lip (air dam) across the front of the engine bay.
Where is your lip behind the radiator?
lol plastic drum
71 notchback,
Pages: 1 2 3 |
