[ Total Views: 19614 | Total Replies: 263 | Thread Id: 106947 ] |
Pages: 1 .. 3 4 5 6 7 .. 9 |
adlbeetle66
A.k.a.: Denver
Under the car.........again!
Threads: 98
Mood: ICH BIN VW NUSS
posted on May 12th, 2015 at 08:44 AM |
Inner panel all welded and just needs dressing now.
Coupla patches left on the outer skin and then clean up, zinc prime and pop back together again
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 12th, 2015 at 08:45 AM |
And to nearly finish things off we have the inner panel dressed and zinc primered...
Then the inside of the outer skin cleaned up and zinc primered...
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 12th, 2015 at 08:47 AM |
And again... The finished product...
Just have to grind back the spot welds on the inside
Error |
Error |
Error |
bushed
Threads: 66
posted on May 12th, 2015 at 11:35 AM |
how can I unsubscribe from this please
38 mails in 20 hrs!!!
congrats
black things need light to take pic
but yeah anyone help unsubscribeme
taa
CheapChalee
Threads: 1
posted on May 12th, 2015 at 01:37 PM |
Looks like you got the rust out. Got/had a lot of rust in my 69 also.
Chalee
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 12th, 2015 at 03:40 PM |
Haha
Sorry, but i've been up to heaps!
Will send you an email...
Thanks Chalee, still got plenty of rust to go!
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 13th, 2015 at 06:08 PM |
Got the lip on the chassis all clean and Zinc Primed..
Error |
Error |
Error |
Paul Smith
Threads: 6
posted on May 14th, 2015 at 02:57 PM |
Is that zinc primer weld through and if so what's it called and where do you get it?
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 14th, 2015 at 03:55 PM |
Yep, you can weld onto it..
I bought it from QWS..
http://www.weldingsupply.com.au/
I dont think it's on their website, but thats where i got it from...
psimitar
Threads: 148
posted on May 14th, 2015 at 10:35 PM |
Quote: | Originally
posted by Paul Smith
So long as it's high zinc content then you can weld thru it but unlike a true weld thru primer it may not be as temperature stable. I've never
checked but TBH I've not noticed it bubble and peel from the heat generated by welding
madness is in the eye of the beholder
scoopsta
Threads: 1
posted on May 15th, 2015 at 08:33 AM |
i use U-POL Weld #2 copper weld thru primer ...awesome stuff.. not tried the zinc primer as yet
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 16th, 2015 at 06:22 PM |
Here's the stuff i've been using..
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 16th, 2015 at 06:28 PM |
Got the weber off today... Saw that it's got 36mm venturi's in it, so it'll work..
Soaked it in some degreaser for a while.. got all sorts of goo and flakey stuff floating on the top
When i put the carby in, the water was clear.. check out the colour now!
Also made up a manifold block-off plate
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 16th, 2015 at 06:30 PM |
Its now sitting on the bench drying
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 16th, 2015 at 06:31 PM |
Also noticed some rust appearing on the bottom of the tunnel.. treated and primed it, so i could get a good look at it.
Error |
Error |
ptjcmaavw
Threads: 3
posted on May 17th, 2015 at 12:30 PM |
MMM... new solid metal
Nice work there for a 13 y.o!!
Funny rust you have there.. havn't seen it like that before.. my guess is that is was parked on an angle for many years..
Keep us informed!!
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 17th, 2015 at 12:36 PM |
Thanks mate,
When i bought it, it had been sitting for 2 years, and a year before that it had been sitting for 10 years!!
Where all the rust is kinda backs up that statement!
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 17th, 2015 at 07:37 PM |
Was a bit bored, so i got the spark plugs cleaned up..
Before & after..
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
Then checked the spacing was correct, then re-installed!
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 17th, 2015 at 07:38 PM |
Looking a bit sad and dusty..
Error |
psimitar
Threads: 148
posted on May 17th, 2015 at 10:20 PM |
Paint thinners and an old toothbrush or brass wire brush will give the carb body a nice clean up if you wish to make it look like new.
Plugs are nice and sooty so mixture of the carb is rather rich. See if you can find an exploded view of the carb online so you can find the idle,
main, air jets and emulsion tube.
will give us an idea which jet or jets are on the large side
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 18th, 2015 at 08:20 AM |
Thanks..
Here you go..
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 18th, 2015 at 08:21 AM |
Its what i've been using anyway..
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 18th, 2015 at 03:54 PM |
I suppose i could use this too
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 19th, 2015 at 03:55 PM |
Little bit more..
Got the exhaust off...
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 19th, 2015 at 03:56 PM |
Then i decided to rust treat & prime the underside of the wheel well...
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 19th, 2015 at 03:58 PM |
Then i re-primed the inside of the decklid..
Yes, have still got to grind the spot welds off...
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 23rd, 2015 at 07:02 PM |
Today i ground back the spot welds and primed them
Then i chopped out the battery tray section of my old pan to practice welding the new pan on!
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 23rd, 2015 at 07:03 PM |
Also, some goodies arrived from overseas!
adlbeetle66
A.k.a.: Denver
Threads: 98
Error |
