[ Total Views: 19228 | Total Replies: 263 | Thread Id: 106947 ] |
Pages: 1 .. 4 5 6 7 8 9 |
adlbeetle66
A.k.a.: Denver
Under the car.........again!
Threads: 98
Mood: ICH BIN VW NUSS
posted on May 28th, 2015 at 08:16 PM |
Started getting some rust cut out today..
Am picking up my heater channels and other repair sections at the end of next week .
Yes, that is more zinc coating
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
I apologise for the blurry photos - night time
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 28th, 2015 at 08:17 PM |
The inner guard on this side is stuffed... see above for the repair sections i will be using...
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 28th, 2015 at 08:18 PM |
Heres a pic to show just how thick the bog was that the previous owner had "rust repaired"
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 28th, 2015 at 08:19 PM |
And one more pic...
Error |
Dibsy
Threads: 37
posted on May 29th, 2015 at 06:37 PM |
Wow Denver, that is starting to look like my first Oval !
I hope you are going to learn how to do the welding yourself, good experience.
Best of luck mate.
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on May 29th, 2015 at 08:13 PM |
Thanks Mark,
Doing some myself, and getting another mate to do the trickier bits .
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on June 4th, 2015 at 07:53 AM |
Did a bit more...
Got the welding gear out
Got a brace all welded up... in between putting out fires that caught onto the hood lining down the pillar
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on June 4th, 2015 at 07:54 AM |
This now means i can open and close the doors
Have loosened a few of the screws.. just gotta wait for my blisters on my hands to heal before i can keep going
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on June 13th, 2015 at 12:29 PM |
One door is off.. the other one is a bit more stiff, so WD-40 time, and come back later
Then i took the shifter and degreased it all...
Got the grinder out.. and took off the paint around the shifter area...Got the tops of the bolts painted...
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on June 13th, 2015 at 12:31 PM |
Bought a quick shift kit.. Had to modify the little plate so it would sit inside the spacer nicely.. Then painted it silver to match
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on June 13th, 2015 at 12:32 PM |
Then cut out come rust...
Found some more rust near the horn bracket... cleaned it up and zinc primed it ready to cutting out and welding time.. i may have to take the bumper
off to do so though
Error |
Error |
Finky
posted on June 13th, 2015 at 01:38 PM |
Good work Mate! Looks like your heading for a full resto!
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on June 13th, 2015 at 02:27 PM |
Thanks Finky.
Not quite.. i just want it to look original, but with a difference if you know what i mean
So i can say "just bought it off an old granny, and cleaned it up a bit"
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on June 13th, 2015 at 06:42 PM |
Started to put a thin layer of bog on the decklid...
Error |
CheapChalee
Threads: 1
posted on June 15th, 2015 at 10:12 PM |
Nice work, I had a lot of rust on my 69 also.
Chalee
ptjcmaavw
Threads: 3
posted on July 18th, 2015 at 04:09 PM |
Any updates Denver?
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on July 27th, 2015 at 05:01 PM |
Sorry, its been a while...
First i had bought some repair panels.
The passenger heater channel will be returned and a whole new channel will be bought.
I also cleaned up the rust on my passenger guard, and from a donor guard i got from 'bushed' i made up a repair piece and rust treated it ready for
welding.
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on July 27th, 2015 at 05:04 PM |
I also bought some A Pillar repair panels that came from the UK. They are far superior to the cheap Chinese rubbish that can be easily sourced.
Then i purchased a better sway bar for the front beam. I am currently in the process of painting it black.
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on July 27th, 2015 at 05:08 PM |
Bought some white-walls and cleaned them up and they look new
I now have the shell on a frame so it is now nice and solid to work on.
I cleaned back the front apron to bar metal so i can get to the rust down the sides...
I cleaned up the rust on the rear inner guard then with a bit of messy painting i managed to blend it all in - you can see where i was doing it by
looking at the zinc'd sections...
That'll do for now
Error |
Error |
Error |
Banshee777
posted on July 27th, 2015 at 08:08 PM |
Like the frame, mines sitting on the left overs of my retaining wall.
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on July 27th, 2015 at 10:12 PM |
Thanks Banshee77, more pictures coming soon!
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on July 27th, 2015 at 10:14 PM |
Got the shifter all assembled.
Then i added a person touch and painted.
I then marked out the sections to be cut.
Error |
Error |
Error |
Strogger
Threads: 8
posted on July 27th, 2015 at 10:25 PM |
Coming along nicely mate.
I used the same front heater channel sections for mine, not sure what you think, but mine were a bit "off" and it took a lot of cutting, bending and
swearing to get mine into a semblance of order..
Go easy when you weld them in, they are much thinner and will blow through when welding if your not careful, or if you have a cheap arse mig with
bugger all control like me.
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on July 28th, 2015 at 07:31 AM |
Thanks, i am using a whole new one on the passenger side, and just the little black ones on the drivers side...
Thanks for the advice
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on July 28th, 2015 at 03:35 PM |
Guards.
Got the lip all cleaned up, and zinc coated.
Then mixed some paint up and tried to blend it in a bit...
Error |
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on July 28th, 2015 at 03:39 PM |
Epoxy Mastic 121 time!
Cleaned the drivers pan of rust again, then pulled out the master cylinder to repaint as it is quite surface rusty and dirty...
1st coat done
Error |
Error |
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on July 28th, 2015 at 05:54 PM |
After school yesterday i decided to mix up some more and do another coat, and make sure i get all the seat rails.
Originally i though i had ordered BLACK paint, but it turned out GREY. Thats ok, i will use this to my advantage. You will see how it tuns out soon
Error |
ptjcmaavw
Threads: 3
posted on July 29th, 2015 at 08:00 PM |
Lookin good. am wanting to see what they are going to run out like...
adlbeetle66
A.k.a.: Denver
Threads: 98
posted on July 30th, 2015 at 06:01 PM |
Got the spot welds drilled out - just a move towards getting the heater channel out..
Error |
Error |
