[ Total Views: 5994 | Total Replies: 61 | Thread Id: 107283 ] |
Pages: 1 2 3 |
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on October 1st, 2014 at 09:23 PM |
Our bus is lowered about 3.5 inches, and the radiator has never been damaged.
karmann141
Threads: 47
posted on October 1st, 2014 at 10:33 PM |
Quote: | Originally
posted by helbus
Maybe I should say "vulnerable" I've just seen many hang very low.
1961 K Ghia - Porsche 5 sp, EJ20T, Brembo's, Dble A arm susp
1974 L Bug - Porsche 944 brakes, Boxster 16's
1974 Bay Camper - EJ20, twin radiators, Boxster 16x7's
Half Beetle trailer with Boxster 16x7's
2011 Tiguan TDI 4Motion
2010 LR Discovery 4 TDV
ian.mezz
Threads: 280
posted on October 2nd, 2014 at 07:58 AM |
you guys crack me up .especially vlad01 the commodore driver LoL
stop all this stupid talk about putting radiators in backs of cars, it's not a Porsche it’s a freaken Kombi and there is heaps of room to put a
Radiator anywhere else besides the engine bay .
ian.mezz
Threads: 280
posted on October 2nd, 2014 at 08:19 AM |
like I said.on your build page
Take a tip from Volkswagen and put the radiator up the front.
Also copy the cooling system from the Subaru as you have the car .
ian.mezz
Threads: 280
posted on October 2nd, 2014 at 08:44 AM |
Quote: | Originally
posted by karmann141
Quote: | Originally
posted by helbus
who cares if the Kombi purist can see a Radiator.
Your already stuck the Subaru motor in your KombiS
karmann141
Threads: 47
posted on October 2nd, 2014 at 11:11 AM |
As the saying goes:
"It's better to remain silent and thought a fool, than to open you mouth and remove all doubt"
vlad01
Mood: Side ways
posted on October 2nd, 2014 at 11:13 AM |
says the guy who uses a plastic tub to "improve" his system
Yes I collect commodores, you got a problem with that? after all they are water cooled and I designed my very own radiator for them, very first drop
in OEM stye performance radiator, I mustn't know anything about water cooled engine cooling system design then.
fits like a glove, only design of its kind. Why? because replacement "OEM" ones are in adequate quality and size and I basically corrected that
because they didn't follow the manufactures design guide lines to save money. And off the shelf performace radiators dont fit with hacking and are
shit made in china and don't last the minimum 20 year I expect instead only last few months.
hell even my computers are water cooled.
oh yeah, whats that "its not a porsche" comment, are you forgetting that they run a complex 3 small radiator, multi line design with auxiliary
coolant pumps up front? yes all that and its up front too.
if it works well in the back with this simple design then why re invent everything?
71 notchback,
ian.mezz
Threads: 280
posted on October 2nd, 2014 at 04:54 PM |
vlad01
I haven't heard of any factory Kombis with the radiators in the back.??????
Porsche spend millions on designing their cars .
and I also bet lots of designing went into the computer .
looks like the guy just got two of any sort of radiators that fitted the holes.
hot air gets blown in from both sides of the Kombi engine bay.
The engine bay is a BOX and hot air raises and has no where to go that's why it better with the lid open to let the air out. It needs to be directed
down
vlad01 even a commodore has a big PLASTIC fan shroud to direct the air. A plastic cut drum will do the same job.
best to have Radiators rubber mounted like in a commodore
Also how much did the cooling system of the Subaru hold compared to how much the cooling system holds in the new system .
karmann141 ,vlad01 stop kidding your self's and giving the guy bad ideas and just let him put 1 radiator up front .
I told him all along it didn't look right and now look where he is after you saying she be right
oh then we wouldn't be having this chat hahahahaha
chellejohno
I hope you get it sorted either way 1 or 2 radiators ,
the best thing is having a nice running Subaru powered VW .
even this don't look to bad for a after market job.
Error |
ian.mezz
Threads: 280
posted on October 2nd, 2014 at 05:17 PM |
. it works for Volkswagen
http://www.carscoops.com/2013/08/vw-says-adieus-to-brazilian-made-kombi.html
Error |
chellejohno
Threads: 7
posted on October 2nd, 2014 at 05:54 PM |
Hey Ian,
Had a look at the tardis front mounted radiator last year at old bar, and I reckon it's about the best looking front mount I've seen, I'll take
more pics if it's there this year for future reference
vlad01
Mood: Side ways
posted on October 2nd, 2014 at 10:16 PM |
hey johno, whats the dimensions of your radiator?
71 notchback,
roverv8bay
Threads: 32
posted on October 3rd, 2014 at 06:17 AM |
G'day all. This debate will never end. In the 6 kombis I converted for customer n the 80' using different owner choices in engine I never front
mounted any radiator in the bays I used ms65 Toyota radiators with brand new Mazda bongo fans that are reversed to drag cool air in through the
tailgate. I had a new louvered tailgate made to suit. On the splits I used a triumph 2500 mounted parallel with engine sealed to the body totally so
the Renault 16 fan pulled cool air through the vent plus I used the hot air tube to feed air from a scoop under the floor hanging just far enough
below the bar to be in flow. I used top hose filler cap above the high point so as to bleed plus had a drain cock fitted to the top tank so very
little air left in the system. if you have a look at pics ECLECTIC in my build I don't like the look at all even though it's only the body left the
really vw. just my 2 bobs worth
ernie
karmann141
Threads: 47
posted on October 3rd, 2014 at 01:57 PM |
Thanks Ernie - just another way to skin a cat - that works.
Unfortunately it's not a debate - someone just can't accept the fact that you can keep a water cooled conversion cool with anything other than a
front mounted or underbelly radiator.
Personally a could'nt give a rats .... what he thinks. The beauty of engine bay mounted radiator/s is that does not spoil the lines/look of a Kombi
and are totally out of the way and protected - and with a little effort - IT WORKS.
vlad01
Mood: Side ways
posted on October 3rd, 2014 at 06:48 PM |
Totally agreed!
+ 1M
71 notchback,
chellejohno
Threads: 7
posted on October 6th, 2014 at 02:37 PM |
Got a set of clear earz, thanks to Justkampers who brought them up to old bar.
Made a big difference on the way home, was able to sit on 90-100ks on the freeway with the caravan, with temp between 90-100, still not ideal because
the fans were on most of the time, but I'm pretty happy with that, after all it's pulling 800kgs of caravan!
Cheers Johno
helbus
A.k.a.: Pete S
Threads: 312
posted on October 6th, 2014 at 04:10 PM |
just over two tonnes moving at 100kph. That takes horsepower to move, and making hp makes heat. Well done, as long as you keep it under 110, you will
survive. I would highly recommend a low coolant sensor that buzzes and lights up on the dash. I have a temp guage, and because our bus never
overheats, I wasn't watching it. The heater bypass hose blew from old age, and engine dumped coolant, and engine cooked to the point where the
plastic timing covers melted off.
vlad01
Mood: Side ways
posted on October 6th, 2014 at 05:32 PM |
Quote: | Originally
posted by chellejohno
Cheers Johno
I reckon get some custom rads of find ones with larger cores, make or find fans with shrouds, last but most important is a air damn/flap in front of
the engine bay.
You'll be good to go with towing stuff then.
Also bigger engine might help , doesn't have to work as hard and
result in less heat. It will make more HP with same heat more or less.
only if you want/can be bothered with a bigger one.
71 notchback,
ian.mezz
Threads: 280
posted on October 6th, 2014 at 06:29 PM |
Quote: | Originally
posted by vlad01
Cheers Johno
the engine bay.
yeah, don't run it to long if they think there air in the system , as you could do a head gasket.
I had a chat to karmann141 at vw Warwick.
It turns out its about personal choice .
vlad01 how's your Subaru /vw coming along
ian.mezz
Threads: 280
posted on October 6th, 2014 at 06:38 PM |
this car has 3 radiators
A small one join in on heater hoses under the car.
its a bash car it just handles it on 40 plus days but have to drive 90Ks and take it easy
they are very happy with their car as it was done that way by a work shop , because it was going on rough roads in Oz
Error |
ian.mezz
Threads: 280
posted on October 6th, 2014 at 07:52 PM |
race cars have them on the side, with a hose at top and a hose on bottom . it looks like a V6 commodore motor with a small radiator
once the body back on you would never know
Error |
karmann141
Threads: 47
posted on October 6th, 2014 at 11:22 PM |
Hi Ian - Yes it is a personal choice.
Just to clarify, the Green Bash Kombi above has 3 radiators - 2 in the engine bay (the fans are on the other side). The engine bay has been completely
sealed like the aircooled motor mainly to keep the heat from the exhaust sytem out which is at the rear, hence the propped open and louvred engine
cover.
Hi Johno,
Glad to hear the Earz helped (knew they would) - continue to fine tune your cooling system.
Error |
Error |
Error |
Joel
posted on October 7th, 2014 at 03:24 PM |
It will cream in an 800kg caravan once you get the air flow sorted.
Brad proved many years back just how well an EJ22 powered Kombi can tow when he trailered that tractor from Melbourne to Brisbane.
I cant remember what the tractor and trailer weighed but the whole thing Kombi and cargo was nearly 5.5 tonnes all up and still cruised on 100km/h on
the flat.
That was one the things that really sold me a on a subi conversion.
helbus
A.k.a.: Pete S
Threads: 312
posted on October 7th, 2014 at 05:13 PM |
Here is the thread with the 5.4 tonne GVM EJ22 powered Kombi
http://forums.aussieveedubbers.com/viewtopic.php?tid=40005&page=1#pid366029
Joel
posted on October 7th, 2014 at 06:25 PM |
Thats the one, cheers i wasnt having much luck finding it.
chellejohno
Threads: 7
posted on October 7th, 2014 at 06:49 PM |
Had a really good run today, temp wise. Between sydney and canberra the outside temp dropped to about 18 degrees, and so the kombi dropped to about 90
and on the flat and downhills dropped enough to give the thermo fans a break.
We had a shocking headwind though, that just killed us on the hills, 60-70ks on some of them, but the temp still sat well, even when we pushing up
those hills.
It's a great feeling on the freeway overtaking other caravanners in their flashy big four wheel drives and mansion size vans, one guy in a terracan?
Towing a small van cracked the shits, put his foot down and wouldn't let us pull back into the left lane.lol.wanker.
Can't wait to drive it to work later in the week without the van.
vlad01
Mood: Side ways
posted on October 7th, 2014 at 08:31 PM |
Quote: | Originally
posted by ian.mezz
Quote: | Originally
posted by vlad01
Cheers Johno
the engine bay.
yes just fine, but scrapping the suby idea though, might just use an GM alloytec v6 or type 4.
71 notchback,
vlad01
Mood: Side ways
posted on October 7th, 2014 at 08:36 PM |
cover.
Hi Johno,
Where is the 3rd one?
71 notchback,
vlad01
Mood: Side ways
posted on October 7th, 2014 at 08:41 PM |
Quote: | Originally
posted by ian.mezz
yep, Turbocharged VN series one V6 by the looks aka LN3 engine circa 88-90.
Thats a standard sized radiator.
71 notchback,
chellejohno
Threads: 7
posted on October 9th, 2014 at 09:41 PM |
Drove the kombi to work today, first real run without the caravan (120ks). Temp sat between 74-78, outside temperature was 18degrees.
That's not too cold now is it? Might have to pull the ears back off!!
vlad01
Mood: Side ways
posted on October 11th, 2014 at 09:55 PM |
got a thermostat that works properly in there?
not one of those trident or dayco ones? I found them shite and ran 70-80 not the 91 advertised, 4 in a row trident and 1 dayco. not one worked
right.
got a genuine fixed
71 notchback,
Pages: 1 2 3 |
