[ Total Views: 12149 | Total Replies: 133 | Thread Id: 108401 ] |
Pages: 1 2 3 4 5 |
bugmaniaar
Threads: 18
posted on June 29th, 2015 at 07:37 PM |
Looking good.........
vwpizza
Threads: 46
posted on July 25th, 2015 at 04:33 AM |
Great read,love the work and the pics...
if it looks like crap smells like crap then guess what!!!!!
grazza7755
Threads: 49
Mood: relaxed
posted on September 21st, 2015 at 08:24 PM |
72 Single cab
Righto, back in action to assemble the ute.
I took the auto down to Sydney last week where the motor was being rebuilt. We connected it all and fired it up. Sounds sweet. Too long a drive to
bring it back and find it won't start.
Then the job of cleaning it all out and fish oiling it. What a bastard of a job crawling in the treasure chest trying to spray fish oil everywhere. I
certainly won't rust. I sprayed 3 litres in every hole I could find, some of it even stayed with the ute, most runs out on the floor.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on September 21st, 2015 at 08:26 PM |
72 Single cab
Fat mat sound deadening going everywhere
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on September 22nd, 2015 at 06:56 AM |
Started here behind the dash, sorting wires, putting wiper motor in whilst it is easy, cutting the few added wires out and generally tidying things
up.
Just remembered to pull the ignition out as I didn't get a key with it.
All cables oiled up and working smoothly.
Dash will go in next.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on September 23rd, 2015 at 06:33 PM |
72 Single cab
H4 Crystal Xenon headlights with Mega White 60/55w Halogen bulbs now fitted after soldering all the wires behind that had been scotch locked
previously.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on September 23rd, 2015 at 06:37 PM |
72 Single cab
Stainless screws and bolts for everything that I could think of make the job easier to do and easy on the eye when done.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on September 23rd, 2015 at 06:53 PM |
Coming together quite well now.
While I think of it, I have new Fuch alloys going on it an will not need the existing alloys that have reasonable to good tyres on them.
If someone out there has a good use or knows of someone that could do with them, happy to give them to a good home, but hopefully to someone who needs
or deserves them.
Let me know.
Better pics available of previous posts.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on October 1st, 2015 at 07:14 PM |
72 Single cab
Bit more work done today.
Front door rubbers are in, have tried it without gluing except for the area near the checkstraps. Hope they stay in.
The LED taillights are Ebay specials just trying for the older look but with modern efficiency.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on October 4th, 2015 at 07:55 AM |
72 Single cab
The front VW badge was challenging.
Firstly, trying to get the right position as there were no existing holes, so looking at images on google trying to judge the right place.
Secondly, I have bought a stainless steel badge which has 4 threaded studs on the back. After drilling the four holes, I find that the top two are
totally inaccessible from inside the cab as they are behind the permanent air ducting.
As the badge is flat and the front is curved, the badge needs to be pulled in to sit flush.
My solution was to bend the top studs upwards, hook them through the top holes and then put nuts on the bottom ones to pull it in. It worked.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on October 9th, 2015 at 06:16 PM |
72 Single Cab
More insulation going in.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on October 9th, 2015 at 06:18 PM |
72 Single Cab
Starting to carpet over the insulation now.
Using 'boat carpet' which is waterproof and therefore I hope won't hold any moisture.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on October 9th, 2015 at 06:23 PM |
72 Single Cab
Also started on the window regulators today.
First, a thorough clean as they are stiff and full of old grease and dirt.
I have bought an after market electric winder kit and going to try reversing the winder part so that it is all hidden inside the door.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on October 9th, 2015 at 06:28 PM |
72 Single Cab
The mechanism drill apart OK and even though I thought I had cleaned it well, it was full of hard packed muck.
So, further clean then welded it back together facing inwards. Had to cut spaces out of the other half so they would locate on the winder tube.
Just have to get my head around all the parts in the kit and then see if it will all fit inside the door frame and clear the glass etc.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on October 10th, 2015 at 11:53 AM |
72 Single Cab
Spent a bit of time installing the hood lining, isn't that a fun job.
Working upside down by yourself and doing it without knowing which part to do first.
New ones come about 100mm too big all round which further confuses you.
At least I got it up there, albeit with a few waves in it.
I have walked away from it now but will give it a few more hours later and try to stretch it in the right directions.
It'll look alright from 10 feet on a dark night.
Error |
1303Steve
posted on October 10th, 2015 at 02:41 PM |
great work
grazza7755
Threads: 49
Mood: relaxed
posted on October 10th, 2015 at 03:36 PM |
72 Single cab
Thanks Steve, I'm having great fun enjoying the rebuild.
Hope to have plates on it by Christmas.
Still heaps to do.
Graham
grazza7755
Threads: 49
Mood: relaxed
posted on October 13th, 2015 at 05:39 PM |
72 Single cab
Time for these glamours to have a birthday.
I stripped off the covers and glued foam in where the tear was.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on October 13th, 2015 at 05:41 PM |
72 Single cab
Covered top area with a Dunlop foam underlay from Bunnings.
Added the heated seat pad.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on October 13th, 2015 at 05:43 PM |
72 Single cab
Then stretched on the new covers.
It looks a little bit 'full' but will settle down and be quite comfy.
Error |
Perezoso
Threads: 10
posted on October 18th, 2015 at 06:01 PM |
Love your work and this thread. I've got a 72 SC waiting to be done and you have given me heaps if ideas.
Dan
72 super beetle
74 rat panel van
grazza7755
Threads: 49
Mood: relaxed
posted on October 19th, 2015 at 08:39 AM |
Thanks Perezoso, good to know that the journey is helpful to others.
Started on the dash now.
Took off the chequer plate addition and welded up all the holes that were not needed.
I bought a blue stitched leather dash cover and spent a few frustrating hours stretching and gluing it on.
End result not too bad.
Error |
Error |
Error |
bugmaniaar
Threads: 18
posted on October 20th, 2015 at 03:15 AM |
Heated seat pad....love it...Should be good for roasting nuts...
grazza7755
Threads: 49
Mood: relaxed
posted on October 21st, 2015 at 04:34 PM |
72 Single cab
Leather covered dash is now all bolted in with all the ducting cleaned and sealed.
Added these 'Ambulance' fans in which to be honest I had never heard of till recently.
One each side in the ducting and 2 speed motors.
Might even give driver and passenger their own control switch.
Should heat up a single cab in record time i think.
Error |
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on November 8th, 2015 at 08:23 AM |
72 Single cab
Seat heat switches now mounted in the dash under the radio hole.
Wiring and relays for it secured under the dash and marked so i remember what they are all for.
Error |
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on November 8th, 2015 at 08:34 AM |
72 Single cab
Still got stuff everywhere going on.
Started assembling the doors which is painfully slow to do.
Stupidly, I put the quarter window and moulds on and then realised/remembered that the winder mechanism has to go in first so had to unassemble it and
do it again.
Error |
Error |
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on November 8th, 2015 at 08:45 AM |
72 Single cab
Electric window mechanism now in.
As mentioned before, the winder gear box was drilled off, turned around so that the spline faced inwards and then spot welded together again.
This allows all the works to be inside the door out of the way.
Central locking mechanism mounted which also required a lever mechanism to be made and mounted in the door as the activator didn't have enough grunt
for the kombi locks.
So a fulcrum leverage thingo did the trick.
Error |
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on November 8th, 2015 at 09:05 AM |
72 Single cab
Steering column rubbed back and painted with pressure pak.
Mounting it in and getting that damn horn wire at the base of the column connected was yet again another frustrating challenge, but done.
Error |
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on November 8th, 2015 at 09:10 AM |
72 Single cab
The old front bar was carefully taken apart as the rubbers and alloy moulds are a bit delicate.
A few ding repairs, a coat of paint and reassemble.
Brand new second hand bar.
Still no luck with a rear bar as this ute was a one year model for brackets etc.
Might have to make an alloy rear bar, i think.
Error |
grazza7755
Threads: 49
Mood: relaxed
posted on November 8th, 2015 at 09:36 AM |
I have eight set of two holes around the tray where the tailgate and side gate brackets normally mount.
I don't have these gates and don't intend to ever get them as i like the look of these utes without them.
I made a steel sample of flat plate with a cut of shackle welded to it.
I will get eight of these made in stainless.
These will then make great tie down points for when the missus has her kayak on the back. (This is the original intended purpose of this project)
Error |
Pages: 1 2 3 4 5 |
