[ Total Views: 5690 | Total Replies: 43 | Thread Id: 109810 ] |
Pages: 1 2 |
Sunnyjim
posted on October 15th, 2015 at 11:15 AM |
steve
sorry i missed your earlier suggestion to get rid of the heads of the bolts.
I can get the external case bolts off but there are 6 inside the water jackets and a couple of inches down. I cant get a wrench onto it only can gt a
socket onto it
Yesterday I went and bought a can of stuff designed to loosen bolts but the real issue is I can't find a way to grip the heads of the rounded off
bolts.
I am now wondering if a professional engine rebuilder shop might have a special way to solve this ?
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on October 15th, 2015 at 07:04 PM |
Jim i admire your tenacity...your heading is hairbrain or masterstroke...i think you can rule out masterstroke...but if you keep going you are
entertaining...and not knocking you...i currently have five subaru engines at my place and four kombi/subaru gearboxes and one subaru gears kit
1303Steve
Threads: 556
posted on October 15th, 2015 at 07:35 PM |
Once you cut the heads off the case should come apart I think, the bolts need to be replaced anyway, just mark the centre and drill the heads off
Sunnyjim
posted on October 16th, 2015 at 06:11 PM |
rocknrob
as you can see this is all about learning for me. i an not a mechanic i have had many sleepless nights worried about the complexities of the
internal combustion engine. (nah not really ).
You should be proud of your collection especially if some of them are working.
i started today to drill the heads out of the case bolts. Do you think it will pop apart or i will need to use some type of force?
i Could try a car Jack.
lou0060
Threads: 30
posted on October 16th, 2015 at 09:49 PM |
yep, it will be tight. a car jack worked for me when I split mine last year. Also there are a couple of sneaky bolts, small M8's I think that will
catch you up if you don't undo them as well. You might have already found them but worth mentioning just in case.
1971 karmann ghia Cabrio - Cruising
1963 beetle Sunroof - gathering dust
1968 race beetle - twin turbo Subaru - stress relief
1960 beetle - old school low & slow
Sunnyjim
posted on October 19th, 2015 at 07:17 PM |
weekends progress
on the weekend I started drilling out the heads of the case bolts. It is tough going
I was also able to remove all 4 pistons. I cannot see any major damage but will post a piccy for all to see and comment on soon
Sunnyjim
posted on October 20th, 2015 at 02:46 PM |
pistons out of there
still can't crack the case but none the less moving forward. i got all 4 pistons out. The rollers or pins look in good condition so do all 4
pistons. all have black burn marks on them as i guess is to be expected.
Sunnyjim
posted on March 3rd, 2016 at 10:19 AM |
hi all
been a while so i think i need to bring closure on this thread.
in the end i took the car to a mate who had a big arse garage with real tools in there. ( not my pissy supercheap aldi collection ) We used a drill
press to get rid of the head bolts. ot was real tough going. harder then expected
still the case would not split. frustration set in. It led to brute force which led to me stripping some threads.
now one useless ej25dohc case now stares back at me..
so i think this is the end of this project.
pete wood
posted on March 4th, 2016 at 02:22 PM |
You can fix those thread easily enough. Patience and time.
To be honest though, I'd sooner buy a low milage 2nd handie when it comes to Subarus.
Sunnyjim
posted on April 6th, 2016 at 07:31 AM |
possible
G'day Pete
thanks for the comment
as i have not stripped the thread but broken the metal around it i assumed the case weep would need to be welded then a new thread put in.
i also wanted to just get a good 2nd hand ej25dohc. but i did that and failed.
i went to a jap engine importer and got a supposed less than 100k donk. got it installed and low and behold it also has a head gasket issue. it
however seems very strong no smoke or rattles
so i was thinking to just get the HG done on the engine already in my kombi so it is driveable. i was then going to take my time and redo the
original engine now sitting on my shed floor.
i will post a pic soon of the damage and appreciate your advice.
Sunnyjim
posted on April 9th, 2016 at 07:51 AM |
here is the stuffed thread picture
G'day Pete
see the picture below. You see i have broken metal not just stripped the thread. i got to heavy handed trying to split the case.
i assumed i would need to weld the case . I am not sure if that is Viable or not.
whadya reckon?
coletrickle
Threads: 34
posted on April 9th, 2016 at 08:25 AM |
You planning on re using your rods and pistons? I've got a new set of both.
Sunnyjim
posted on April 12th, 2016 at 07:07 AM |
hi Cole
thanks for the offer. i will keep it in mind.
i am not yet sure but was thinking of getting a complete kit
Sunnyjim
posted on June 25th, 2016 at 04:00 PM |
i have picked up another ej25 dohc engine.
not yet sure of its' history . i will do some work to see if it makes sense to rebuild.
Pages: 1 2 |
