[ Total Views: 4372 | Total Replies: 35 | Thread Id: 110488 ] |
Pages: 1 2 |
Carl and Emily
Threads: 38
posted on February 9th, 2016 at 03:53 PM |
Quote: | Originally
posted by cabidas
I've inspected my door trims more closely and one mark on the drivers door one is actually a slight nick. I was quite shattered.
Does anyone know a good place that re does Beetle trims verbatim?
I'll have to get the seats redone anyway, so I might consider getting the door trims done at the same time if they can be replicated using the same
material, on the assumption it's available...?? The poo brown colour with the vinyl melted lines..
Are you going for a perfect restoration???
Your door trims look pretty good from the photo's,..
lots of people would love those originals in that condition,..
so what if they aren't perfect.
There are repro's available,.. like TMI etc,..
cabidas
Threads: 14
posted on February 10th, 2016 at 09:23 AM |
Yeah you might be right.
The intention is to be pretty spot on. I've had this car since a boy, and I have no real intention of ever parting with it. I'd rather get an extra
job than sell it if I got into trouble. I've had it too long.
I was happy with the trims knowing there would likely be a scuff or two. It was just the nick the shattered me. There are vinyl repairers who may be
able to stitch it. I'll see how I'm feeling at that stage.
Looking at the roof lining I'll likely have to redo it. I think it's been sitting too long. And given the extent of the resto I'm planning, it will
likely have to come off in full.
And I can't be confident that I was gentle with it when I pulled it half down at 15.....
So do you know anyone local that is real good with bug linings?
Thanks for TMI. Hadn't heard of them. And it's good to know that option is there if necessary.
Carl and Emily
Threads: 38
posted on February 10th, 2016 at 07:18 PM |
I think maybe you should get the body and mechanics sorted first.
I think your door cards are very usable and it's an easy fix later if your budget allows.
You need to decide what your budget is and that will dictate a lot of things for your build.
From our experience.
Expect the unexpected.
Rust is generally worse and costs more than it looks.
Get the body right first.
Decide if you are going IRS conversion because the time to do it economically is while it's apart. (Body off pan.)
If you haven't been out to any shows,.. perhaps it might be an idea to make a point of it,.. and talk to some folks.
We're in Brisbane so don't really know anyone down your way.
I'm sure someone else will chime in.
Will be watching your build with interest. Keep the posts coming.
Carl
cabidas
Threads: 14
posted on February 11th, 2016 at 01:29 PM |
Yeah I'm not the biggest people person at the moment. lol. More research on the IRS is definitely warranted.
Anyone got any recent links? I haven't looked yet. I have only been going off 15 year old magazines....
The internet did not exist when I got my dub. Well it did, but no one had it then....
Finding some really interesting For Sale prices for bugs on Facebook. Many suggest that if I bolted mine all back together, I'd get a pretty penny
for it as is.....
But I won't do that.
A few things are transitional at the moment. I can clear up the money, but would likely take a few months. I'm happy to spend $25k. It won't be a
daily driver, so I'm a bit worried about storage.
Mother dear is a bit of a hoarder, so I'm worried if once done if I kept it in her shed it'd end up with a pipe through a panel.... :-S
The only reason it's survived this far is because it's surrounded by shite... lol
Dad just bought a Roller, so his garage is full too.
I would be keen to see a few IRS mods. Is there a Nationals or something coming up?
cabidas
Threads: 14
posted on February 17th, 2016 at 03:50 PM |
Ok so I put the door on today.
It took a bit of fart arseing around as the threaded plate on the bottom was a bit rusted (given it was from a donor car found in a paddock).
A bit of Dubya D soon sorted it out. Thought I'd crossed threaded it at first! Assume that those plates can't be replaced..??
I must have snapped a screw from the original one when I took it off back in the day, as half the head was rusted into a bottom hinge hole. Drilled
and then tapped it out. And had a donor screw to replace it.
After that all sorted.
However the bad news is that the door doesn't align, much to my dismay. The pics below illustrate how it's dropped a bit.
It may have already been dropped back then before the replacement, but there doesn't seem to be much wear on the (older style) locking mechanism, so
dunno.
You can see in the hinge pic that there is a bit of a crease in the sheet metal, so I presume there was originally an issue.
Any assistance or experience on this anyone has will be greatly appreciated. I hope to God that it's welded in correctly.
But whatever the issue is I have to get it sorted before I get it painted.
I've played with the adjustments to no avail. One would presume that if it's out a mil at the bottom, it could be out 10 at the top....
Are there any types of shims etc that people use? How do people normally deal with the issue??
Are hinges able to be replaced, etc etc??
Many thanks.
Please avoid quoting within the thread if you can. Makes it harder to read (IMO).
(Are there any plans for an UG to the forum framework to a slightly more modern style...??)
Oh yeah, and I found the glove box lid hidden in a box of stuff.
I'm actually thinking the front of it might be in better condition for paint matching than the rear, as the rear side is pretty filthy despite a
wipe.
It still has the original sticker on it, so won't be painting the back.
Maybe just removing the chrome trim and painting the front.
I've got a few other bits for colour matching like the indicator stalk etc etc. So will see how we go when we get to that stage.
I managed to crease a side chrome trim too! Grrrr. Was hidden inside the car and I didn't see it. Thought they were all out. Gunna have to get a new
couple I would say.
Will check them all out properly later. There were originally all in great nick.
cabidas
Threads: 14
posted on March 14th, 2016 at 03:34 PM |
Ok so I have been investigating the door closure/sagging issues more.
I can confirm that the hingepins are good. There doesn't seem to be any play. They were a tad seized originally, and I'd lubed them up before I put
the door back on.
So I know it's either a welding issue on the A pillar (likely), or a bend in the hinge or door.
I haven't yet tried to fix with a shim, but don't think it will be enough.
It could be adjustment is needed to the pan and heater channel etc. I've read up on this online. But I'll investigate this more as I get closer to
moving ahead and am able to drag it out of the shed and get it more accessible and mobile.
However I've now came across another issue. Even if I lift the door into place, I cant get the door to hold in the second latch position.
So the door just pops back again to the first latch click spot.
(I nearly put a crease in the door face trying! :-S)
Any ideas? I'm googling as we speak but coming up stumps.
Is there a way to test if my latch is cactus?
They seem cheap enough to buy. (I've got a good understanding of the AU dub variations now after reading up on the ClubVW site)
Pages: 1 2 |
