[ Total Views: 29145 | Total Replies: 261 | Thread Id: 111138 ]
 Pages:  1  2  3  4  5  ..  9
Author: Subject:  The Hot Rod is started
Membernbturbo
Threads: 89
Theme: UltimaBB Powder
posted on September 9th, 2016 at 09:31 PM
I hooked up the cooling fans yesterday and made them run backwards-didn't end well.When they were running backwards,they didn't produce as much air as when going the correct way and made a strange noise.I checked the cause-the blades have a fixed curve in them to make more air and run quiet.Decided to remove everything,and put the fans on the other side of the radiator and try it.Fans are running the correct way,make heaps of air,run fairly quiet and are bringing air across them as in the standard set up.Had to shift all the brackets to shift the radiator closer to the motor.Made the top radiator locating pins to be now part of a full width deflector panel which will force all the incoming engine bay air through the radiator.
Membernbturbo
Threads: 89
posted on September 9th, 2016 at 09:33 PM
some more
MemberCamo
A.k.a.: Kev
Threads: 209
posted on September 10th, 2016 at 09:56 AM
I still say we need a 'LIKE' button on these forums :tu:
Kev
Membernbturbo
Threads: 89
posted on September 14th, 2016 at 02:14 PM
A couple of Suby questions-is there an adaptor already available to bolt to the air flow meter to take a pod filter,or do you have to make your own?There is a valve on the intake manifold,just near the throttle body-is it for cold starting?It has a large hose going to the intake pipe,2 water hoses and a small loom.
Membermackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off :td:
posted on September 14th, 2016 at 02:26 PM
That is the idle control valve, yes it is for cold start but works all the time at idle. Get some carby cleaner and go to town on it to clean it up. Move the cylindrical valve around to get right in there.
Quote of the week
Membernbturbo
Threads: 89
posted on September 15th, 2016 at 05:46 PM
Anybody know if an adaptor for a pod filter is available to suit the Suby air flow meter?I cant find anything.
Membermackaymanx
A.k.a.: Brent
Threads: 97
posted on September 15th, 2016 at 06:49 PM
Kennedy Engineering make something, no idea how good it is but come with a muffler in reduce intake noise. Designed for T3 use, no idea what it looks like without the muffler bit or whether is comes seperately.
http://www.kennedyenginc.com/Pages/SubaruVanagonGen.aspx
http://i490.photobucket.com/albums/rr269/nacradriver/DSC_10971.jpg
http://i490.photobucket.com/albums/rr269/nacradriver/DSC_10961.jpg
http://images.thesamba.com/vw/gallery/pix/724627.jpg
Quote of the week
Memberkiwiev
Threads: 2
posted on September 15th, 2016 at 09:13 PM
Nice job mate can you please tell me where you got the air bag kit from.
Cheers Kiwi
Membernbturbo
Threads: 89
posted on September 15th, 2016 at 09:50 PM
Thanks Brent-looks like my Tig and lathe are going to get a workout for the pod filter mount.The bloke got the loom and reckons it's all good-just a few small jobs-thanks for that as well.
Kiwiev-got it all from Airkewld in the States.Got the 2 rear bags,front shocks and front lower arm extenders,the rear top and bottom plates and the bag air fittings.I will get the solenoids,switches,guages and hose from somebody here.You could probably get it all here,but I am hoping Airkewld got the correct weight bags and shocks for a Beetle's weight needs.They don't give very good fitting instructions,so it was a lot of tack weld-try-cut-reweld-try-etc.I am also a bit luckier because it doesn't all have to fit under a Beetle body.They cut a large amount from the rear suspension arm to keep the bag low enough so that the top bag mount will fit under the body.The rear suspension arm is really compromised for strength.I mounted my lower plate on the arm without any need to cut into it at all.The fronts were a major PITA,trying to get the arc of travel correct.I had a look at their website about the top mount extenders,and copied theirs fairly close.When the suspension was fully depressed,the lower arm and shock alignment were almost a straight line,which would have been impossible for the shock to inflate and extend.I worked out the travel arc and fabricated new top mounts to suit.Also had to get the bumpstop in the right place to prevent the shocker bottoming out before the stops were hit.
Memberkiwiev
Threads: 2
posted on September 16th, 2016 at 07:31 PM
Thanks for that mate I was thinking of baging the rear of my super bug eventually I have to pull body off replace one pan and do the dreaded death foam. Has anyone you know of done oval window in a super bug? Dont mind fibre glass or steel handy with both.
Thinking of installing twin AC electric motors 250 Hp 250 ft lb and Tesla batteries.
Thanks for the advice
Cheers Kiwi
Membernbturbo
Threads: 89
posted on September 16th, 2016 at 10:26 PM
Cheers Kiwi
I don't understand your meaning of "oval in a superbug" ? If you mean Oval body on a Superbug pan- yes the body will fit any IRS/ ball joint pan. Rear body support to floor pan is the only difference - just need to modify the bracket on the Oval body to suit. It's a really good conversion if your into the small window body.The 2 front body mounts may need slight mods.
Memberkiwiev
Threads: 2
posted on September 16th, 2016 at 11:44 PM
Oval rear window I heard there was panel you could cut and weld or even a fibre glass panel.
But a body swap is food for thought too.
Thanks Kiwi
Memberbeetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
posted on September 17th, 2016 at 01:25 AM
An oval body won't go onto a superbug pan without also changing the frame head on the pan to a beam, so you will lose the struts. It will go onto any other beam pan (K&L or BJ), but the oval body doesn't have the mounts for the top of the struts etc.
I have seen those oval conversions, but I don't know who does them unfortunately.
From your ole' mate Jeff
Membernbturbo
Threads: 89
posted on September 17th, 2016 at 07:25 AM
Kiwiev- as I stated the Oval body will fit any IRS/ ball joint pan- but a lot of work. I googled the oval conversion and found a hinged panel that fills the big back window with a split conversion - couldn't find who makes them. Will spend a bit more time chasing it.
Memberkiwiev
Threads: 2
posted on September 17th, 2016 at 12:52 PM
Thanks mate
I want to keep the super bug body and pan as it has front disc brakes and struts, I have got wide front 67 look fiberglass guards and wide fibreglass rear guards.
I was trying to get the old look.
And as I have the death foam rust around rear window was wanting to continue the old look, split rear window does sound cool.
So what body look are you looking for with your rod?
Cheers Kiwi
Membernbturbo
Threads: 89
posted on September 17th, 2016 at 07:17 PM
I have a complete 54 and a bare 56 body only- the 56 is in fairly good shape at the fro nt but ordinary around the arse end. Won't bother me to cut it in half to make a ute body.
Membernbturbo
Threads: 89
posted on September 19th, 2016 at 11:01 AM
Is it critical which way the air flow meter sits? Does the electrical switch housing have to be on top? I would like it to be 90 degrees from on top.
Membernbturbo
Threads: 89
posted on September 20th, 2016 at 01:59 PM
Finished my air filter pod to air flow meter adaptor.I had an old turbo that went down hard real early in the Drag Car build.I cut the intake flange off,machined it round to fit in some 10mm ally plate.Welded it on the meter side,then machined it flat for the O ring to seal.
Membernbturbo
Threads: 89
posted on September 20th, 2016 at 02:00 PM
Drilled and threaded for 6mm bolts.
Memberkiwiev
Threads: 2
posted on September 20th, 2016 at 07:14 PM
Nice work mate do you have a photo of it sitting on?
Cheers Kiwi
Membernbturbo
Threads: 89
posted on September 21st, 2016 at 08:50 AM
Which part Kiwiev??
Memberkiwiev
Threads: 2
posted on September 21st, 2016 at 11:02 AM
The air pod sensor on motor if you have got that far just trying to visualize it.
On another note do you have a link to your power window kit looking for something for the 66 bug.
Cheers Kiwi
Membernbturbo
Threads: 89
posted on September 21st, 2016 at 06:03 PM
I have it just sitting in position-but think I may cut most of the plastic intake pipe off and mount the air flow meter just after the bend which will have the pod filter inside my support frame.I will be making an alloy cover to go over the whole engine and transmission, to ensure all air coming into the engine bay goes thru the radiator.The pod filter will also be in this air flow.I have finished the rear frame today-it's all tacked together.I may fit a diagonal brace between the top and bottom side engine bars.It's really strong as it is-I can lift the whole pan from the rear bar without any deflection.I will be fabricating a tow bar to weld to the rear lower bar.
Membernbturbo
Threads: 89
posted on September 21st, 2016 at 06:05 PM
I managed to find a home for the radiator overflow bottle which is out of the way but still close enough for a joiner hose.
Membernbturbo
Threads: 89
posted on September 21st, 2016 at 06:24 PM
http://i.ebayimg.com/images/i/111204502213-0-0/s-l140/p.jpg
I don't know if this works Kiwi-it's what I ordered from Ebay.It's a universal 2 door car electric window kit.
Memberkiwiev
Threads: 2
posted on September 22nd, 2016 at 06:07 PM
Thanks mate for the link im concerned about relying on the winder mechanism, I will wait and see how your pan out.
Love the idea of the radiator facing rear what sort of rear end panels are you boing to use to cover the motor etc?
Cheers Kiwi
Membernbturbo
Threads: 89
posted on September 22nd, 2016 at 09:42 PM
I am a long way off from doing the windows. I guess like everything else,there will be a lot of modifications. I am doing 1 piece windows in this car.I did them in my Oval and they are so easy to wind.Those electric motors will have no trouble moving the glass if the window regs are the same as the Oval's. I have had new glass made with the dark tint in the glass.I won't know how I'm going to cover the motor until I am ready to do it. I have a few ideas- but it will all fall into place as I'm doing it. The side panels will be the same as my Drag Car,but this one will need to have a lot of heat and road grime protection. Will also need a sealed area for travel bags etc.
Memberwombatventures
Threads: 44
Theme: UltimaBB Pro Orange
Mood: BUSted, BUGgered & NOTCHed
posted on September 23rd, 2016 at 06:35 PM
Going awesome there Gary!
When are you running the drag car next? will have to come for a look..
Can't wait to see the rod finished.
[size=5]DUBS BY THE RIVER2021[/size] Morgan SA - Sept 18-19 2021
Currently suffering from delusions of sanity!
Membernbturbo
Threads: 89
posted on September 23rd, 2016 at 07:02 PM
Some time in November is the next meet if all goes well with the club.Hot rod is a bigger project than I imagined - had the old rose coloured glasses on when I dreamed this up. Should have known better after the Drag Car. In too deep now.
Membernbturbo
Threads: 89
posted on September 23rd, 2016 at 10:00 PM
Had to get back on the lathe tonight.The front air shocks have an 1/8th inch plastic line to inflate them.I want to use 1/4inch high pressure line on the whole car.I searched for an adaptor of any sort-nothing available.The fitting on the shocker is 7/16th UNF,so bought some bolts and made the first one.I will silver solder the fitting into the steel boss I made.I threaded the hole to 1/4 bsp to take the brass 1/4inch connectors.I will weld the boss to the front beam in an appropriate spot where I can keep the 1/8th line to a minimum.
[ Queries: 40 ] [ PHP: 17.4% - SQL: 82.6% ]
