| [ Total Views: 29141 | Total Replies: 261 | Thread Id: 111138 ] |
| Pages: 1 .. 3 4 5 6 7 .. 9 |
nbturbo
Threads: 89
Theme: UltimaBB Powder
| posted on December 12th, 2016 at 06:20 AM |
Thanks mate - lucky to even get near it. Got home yesterday from a week in Orroroo. Been doing some serious house renos for Daughters newly purchased
place, then a 70th birthday show on Saturday and hangover repairs yesterday.A large bottle of Jack snuck up on me Saturday and bashed me over the
head.One day I will come over to see your stuff. Will be having Xmas there.
wombatventures
Threads: 44
Theme: UltimaBB Pro Orange
Mood: BUSted, BUGgered & NOTCHed
| posted on December 14th, 2016 at 03:11 AM |
Happens this time of year. We're headed towards VW central for Xmas. Sunshine coast. Will get stuck into the projects in the new year.
nbturbo
Threads: 89
| posted on December 19th, 2016 at 02:31 PM |
1 piece windows.
Does any body know which year Beetle the 1 piece winder mechanism comes from.When I bought my Oval,they were already installed (but very poorly-spent
quite a few hours to get them to work OK) I thought the winders came from a curved screen Bug-but I have just stripped one out and it's nothing like
my Ovals winder.The first 2 are from my Oval which has 2 attaching points for the window runner and the other has only 1 anchor point.
| Error |
| Error |
| Error |
Flintstones
Threads: 69
| posted on December 19th, 2016 at 08:37 PM |
Gary, I'm no guru, I though the early Split beetles had the one piece windows?
nbturbo
Threads: 89
| posted on December 19th, 2016 at 09:04 PM |
Good day Dino- yes they did have them- but window regs would not exist. I have just found new ones available on Cip's web site and only $50 US each-
problem solved. The early splittys also had crutch coolers which I plan on fitting as well- provided I can find something suitable. I have found a
1950 Morris truck wreck I can cut them from, but may find something closer to the originals.
vduboy
Threads: 41
Mood: Dying to get more buggy building time..
| posted on January 26th, 2017 at 07:39 AM |
| Quote: | Originally
posted by nbturbo
Anybody know if an adaptor for a pod filter is available to suit the Suby air flow meter?I cant find anything.
Saas make them, you can get them at supercheap auto, about $16 realise this is a old post but figured someone would like to know if you have already
made one.
It will all be OK in the end, if it's not OK it's not the end!
nbturbo
Threads: 89
| posted on January 26th, 2017 at 11:08 PM |
Thanks for the heads up- would have saved me a lot of work.
kiwiev
Threads: 2
| posted on February 7th, 2017 at 07:10 PM |
hey mate happy new year good to see you are making progress.
Cheers Kiwi
nbturbo
Threads: 89
| posted on February 16th, 2017 at 08:47 PM |
Thanks Kiwi-you are way ahead of me on progress.I have been back to it today.Flap disc on all the tunnel welds.The rear lower engine frame bars have
been pissing me off for a long time.They weren't parallel to the top ones-so cut the supports and rear uprights out-jacked it all up into position
and rewelded.Happy now.I had to make another lower radiator mounting bar (3rd one so far-better be it now) I have made a small ally panel to go behind
the shifter for the power window switches-I will cover it in vinyl.I am also in the process of doing a Suby/Bus auto conversion on a 74 Kombi.I pulled
the Suby engine and wiring loom and ECU yesterday Would have to be the worst job I have ever done.The Suby RH A pillar had been crushed,so made it
impossible to get the dash out.Had to Cut the pillar out and bend the front windscreen panel up.This one doesn't have a separate engine loom and the
ECU was up under the dash on the RH side.Had to pull heater,air con and everything else there to get the loom out.Is there any call on the 4 wd
transmissions.Or just send them to the scrap yard with the body.
| Error |
| Error |
| Error |
nbturbo
Threads: 89
| posted on February 16th, 2017 at 08:49 PM |
This is the start of the Kombi project.What has been found to be the best solution for radiator location in the Kombi conversions?
| Error |
nbturbo
Threads: 89
| posted on March 20th, 2017 at 03:04 PM |
The one on the left arrived today.At last I can now shorten both ends of the steering arms.
| Error |
vw54
| posted on March 20th, 2017 at 06:44 PM |
Left hand thread taps hard to find
nbturbo
Threads: 89
| posted on March 21st, 2017 at 07:48 PM |
I have wanted one for years,so had a look on ebay.$23 delivered from OS.Why did it take me so long? I have ordered a rag sunroof for the Hotrod.Found
a place in the US that does a 20 inch long version for small utes.Got it in grey canvas with a grey headliner.Ordered an extra 3 yards of headliner
fabric to do the rest of the head liner as well as the back wall of the cab.
Fat Boy
| posted on April 4th, 2017 at 05:28 PM |
Great build buddy!!
born again bugger
nbturbo
Threads: 89
| posted on April 4th, 2017 at 06:32 PM |
Thanks Fat Boy.I have made another ally switch panel for the 4 air bag solenoids which fits in front of the shift lever.I have now found this switch
with compressor on it,so have to do a rethink.I will mount it with the bag switches.
| Error |
| Error |
nbturbo
Threads: 89
| posted on April 5th, 2017 at 02:49 PM |
| Quote: | Originally
posted by mackaymanx
2nd photo Crank angle sensor, Cam angle sensor and oxygen sensor. Blue is not standard but from the position probably the knock sensor.
3rd photo 1st gray plugs should be the engine earths( That bit I have). Clear plug I do not recognise but may be for the vacuum control for the
butterfly.
I will keep looking for an engine loom for you, have found the earth side but nothing else so for. Didn't know you were also missing the engine
loom.
Brent-any luck finding an engine loom?
kiwiev
Threads: 2
| posted on April 11th, 2017 at 09:16 AM |
Hi Gary WOW you have been busy, I started another thread I would like you thoughts if you have a minute mate.
Cheers Kiwi
https://forums.aussieveedubbers.com/viewtopic.php?tid=112327
nbturbo
Threads: 89
| posted on April 12th, 2017 at 06:46 AM |
Kiwiev- I am lost for words.Wish I had your energy.
nbturbo
Threads: 89
| posted on April 17th, 2017 at 05:42 PM |
Fitted the new compressor switch today.Made a new switch plate that now bolts in-will be a lot easier to fault find down the track if there are some
electrical issues.Still waiting on another switch which I will use to isolate the interior lights from the door switches if needed.
| Error |
nbturbo
Threads: 89
| posted on April 19th, 2017 at 06:15 PM |
Bought some black fabric this morning and some kwik grip.Decided to go with all black carpet,but grey seats,door trims and head lining.
| Error |
| Error |
nbturbo
Threads: 89
| posted on April 24th, 2017 at 08:54 PM |
Have never really been happy with the mods I did to the front beam for the air shocks to work.I copied what the air ride firm does to their beams.The
top shock mount was too far away from the original shock pivot.It would make the bag harder to extend because of the overall shock and lower pivot
point angle.Reckon it would also be ruff as guts to ride in.I cut it all off today and fabbed up new stuff.The top pivot is now only 10 mm away from a
vertical line from the og position compared to about 70mm before.
| Error |
| Error |
| Error |
kiwiev
Threads: 2
| posted on May 25th, 2017 at 05:15 PM |
| Quote: | Originally
posted by nbturbo
WOW mate you have been busy while I was away great work.
Your power window switches look cool have you powered up yet?
Cheers Kiwi
nbturbo
Threads: 89
| posted on May 25th, 2017 at 09:01 PM |
No- haven't touched it- doing 2 Bay Window Subi conversions. I ordered a 4 solenoid valve block and 2 twin air guages about 8 weeks ago from a
supplier in Adelaide. Arrived late Wednesday arvo with no wiring or hose diagram. Next week. I want to try each bag to make sure they can lift the
pan.
nbturbo
Threads: 89
| posted on June 14th, 2017 at 10:47 AM |
Been waiting for some sort of wiring and hose diagram to try my air bags out.Always waiting on somebody-pisses me off.Been leaving messages for 2
weeks and somebody finally answered the call last night.Was some miscommunication about the air gauges-I wanted black face/chrome bezel old school
type.Got black bezel LED digital readout. Made my ally dash face plate for speedo and clock.Haven't decided yet to have it chromed,powder coated or
go body colour.Was going with mounting screws from behind for the guages and 4 stainless bolts in each corner of the plate-went with exposed bolts for
the guages and blind mounting for the plate.
| Error |
| Error |
| Error |
kiwiev
Threads: 2
| posted on June 20th, 2017 at 04:38 PM |
Awesome work mate we must have the same energy lol
Keep it up Kiwi
nbturbo
Threads: 89
| posted on June 20th, 2017 at 05:15 PM |
Thanks-just finished putting my air bag solenoid back together.Thought it will be the only way I can figure it out.On top of it now.Like how it
works.One side for inflate and the other for deflate.Reckon I will make 4 small ally manifolds with 3 fitting hole-one for the gauge and one each for
up n down.Better than using T pieces.
vw54
| posted on June 21st, 2017 at 07:36 AM |
Do you have to get an Engineer to sign off on all the mods in SA ??
nbturbo
Threads: 89
| posted on June 21st, 2017 at 01:18 PM |
In SA when the pan has been modified,they must be registered as a "Tourer" body type. I have a Tourer registration that will end up on this car -
all done.
nbturbo
Threads: 89
| posted on August 10th, 2017 at 06:13 PM |
| Quote: | Originally
butterfly.
loom.
I have tried many places to get an engine loom-wreckers,Suby Forum and ebay,but have had no luck.There are heaps on ebay,but none have the 3 grey
plugs like this loom.What do you reckon it came from?
| Error |
nbturbo
Threads: 89
| posted on February 18th, 2018 at 04:53 PM |
Haven't been near this for months-been bogged down doing Subi conversions in Bay window Bus's.Got the reinforcing bars in today and finally cut it
in half.Have it booked for dipping in Adelaide,so needed to have it ready to go.Have cut the dash for the speedo/clock panel and welded in the braces
to hold the 7 inch DVD player.I will put the 2 air bag gauges and the engine temp gauge where the ash tray used to be.
| Error |
| Error |
| Error |
