[ Total Views: 5067 | Total Replies: 39 | Thread Id: 111808 ] |
Pages: 1 2 |
bevoracing
A.k.a.: Tony Beven
Threads: 35
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
posted on November 25th, 2016 at 09:24 AM |
Great thread Steve
Those Thing rear bends are available separately :-
http://www2.cip1.com/ProductDetails.asp?ProductCode=C23%2D35181%2D1
They are more costly than a complete beetle system but at least they attempt to have a difference from left to right to encourage movement of gas
through the heat riser. You have to wonder if some of the cheap headers with the same casting both sides move anything at all?
The Thing tail pipes could come straight back under the bumper of a CB, not perfect but it could work. No way to get it up above the bumper in that
short a distance. I bet if you took that J Bugs box, blocked the rear pipe and took a pipe straight out of the top it would work perfectly.
I think the distance across 13,15 &1600 heads, from exhaust flange to flange, is all the same (but now I’m going to have to go and measure it of
course).
Not sure what CB John did, his seems to have pipes curving around like some sort of header. Definitely something different, but still with the ground
clearance and out the right hole? He’s good.
No Facebook for me thanks Steve, you keep us posted.
Tony
ztnoo
Threads: 120
Mood: Dazed & Confused
posted on November 25th, 2016 at 10:53 AM |
Tony,
My thoughts EXACTLY, but I was waiting for someone else to notice and make comment.
As long as the exhaust port/muffler flange assembly is as close in dimension as possible, and which can be made to work I'm sure with innovation, why
not drill/bore a hole in the top or the muffler and weld a sleeve or a pipe stud to the upper side of the muffler, then duplicate a CB type
tailpipe???
This setup isn't going to be accomplished for a few hundred dollars, but lacking the dribbling of ideas from those in possession of "The Jig", I'd
give it a shot if I were in OZ and wanted a general looking, original concept, through the rear body openings for the CB exhaust system for probably
half the price of the custom option.
Just one man's opinion.
Other opinions and commentary are ALWAYS welcome here.
Fine tuning the proper daily ratio of Maxwell House to Bacardi 151.........
* Don't worry about the world coming to an end today. It's already tomorrow in Australia !
ztnoo
Threads: 120
posted on November 25th, 2016 at 10:39 PM |
The CIP1 Option
Tony,
That cip1 spot is is good one.
I looked a little deeper into all that.
Currently they are having a Thanksgiving day sale on those parts until midnight (California time) Monday, November 28th.
It says Free Shipping during the sale on these items, but my guess is that means only here to US addresses.
I guess it would never hurt to ask if you are an overseas buyer. The worse they could say is NO.
Those parts are available separately: left & right side manifolds with pre-heat, and left and right side mufflers, all made for a '73 Thing.
C23-35181-1 - EXHAUST MANIFOLD - HEAD TO MUFFLER - LEFT SIDE - 73-74 THING
C23-35182-1 - EXHAUST MANIFOLD - HEAD TO MUFFLER - RIGHT SIDE - 73-74 THING
http://www2.cip1.com/ProductDetails.asp?ProductCode=C23%2D35182%2D1
C23-35181 - MUFFLER WITH TAIL PIPE - LEFT SIDE - ELIMINATES HEATER BOX - 73-74 THING - (A10)
C23-35182 - MUFFLER WITH TAIL PIPE - RIGHT SIDE - ELIMINATES HEATER BOX - 73-74 THING - (A10)
Sale pricing: 66.49 + 66.49 + 127.49 + 127.49 = $ 387.96 USD (521.930 AUD)
Regular pricing: 69.99 +69.99 + 149.99 + 149.99 = $ 439.96 USD (591.658 AUD) Live mid-market rate 2016-11-25 12:16 UTC
Without shipping costs figured in, it appears to me to be approximately half the costs of the units as being talked about over on the CB Facebook site
using the "jig".
Doesn't seem to be a lot of movement on this over there, and if there was, I speculate it would likely take a good bit of time to pull
off......months maybe.
I think if I were interested in the cip1 set, I'd inquire about the possibility of getting as assembled exhaust flange to exhaust flange width
dimension, get the measurement on a CB engine exhaust port to exhaust port width, and if those two dimensions are close, roll the dice.
Even if it required some modification, at least it looks like it could be done at a considerable savings from the cost of a "jig" fabbed set.
Again, just one man's opinion.
ztnoo
Threads: 120
posted on November 26th, 2016 at 05:20 AM |
KO 343
ztnoo
Threads: 120
posted on November 26th, 2016 at 11:01 PM |
CB KO 432
bevoracing
A.k.a.: Tony Beven
Threads: 35
posted on November 28th, 2016 at 12:58 PM |
Hi Steve
I got my tape out and checked the dimensions across the exhaust port flanges, front to rear, of a 1300 F125 engine and a twin port 1600 engine, and
they are in fact the same. So those Thing exhausts will bolt onto the engine. Of course I can’t check, but there’s an acre of room under a CB so I
would say they will fit under the car too.
As for that Victorian one, if I had my TIG out and all the stainless on the bench, I wouldn’t put the boxes down there under the heads. He must have
had his own reasons for doing that. Perhaps the plan is to hack the body up and “slam” it? That would be a shame.
Tony
cb john
Threads: 6
posted on November 28th, 2016 at 01:11 PM |
I see too much agonising about mufflers....I can provide measurements of the system...To copy it to original configuration is not simple but
possible, if the cost is not taken into consideration...
ztnoo
Threads: 120
posted on December 1st, 2016 at 09:09 AM |
John,
I'm sure whatever you, or anyone else, can offer in the way of accurate specifications would be greatly appreciated by those seeking real information
about recreating a CB OEM style exhaust system.
It appears the gents in charge Bill's Moore's files aren't particularly interesting in releasing this information, at least it seems that way from
other sites I follow. I guess I don't understand that mindset, because that wasn't the way Bill operated and it certainly wasn't his mind set. Bill
was willing to share information with anyone and everyone.
CBKO294
Threads: 12
posted on December 8th, 2016 at 11:57 AM |
Yes I would really appreciate any specs / numbers / dimensions on the exhaust.
Thanks to everyone that has posted information on this topic.
steveo169
Threads: 18
Mood: moderate to south easterly
posted on July 19th, 2017 at 12:03 AM |
Hi everyone
Can any, or all, of you send me some details there was lots o chatter and some photos and concepts tossed about but keen on drawings and hand
measurements to start with.
I'm ready to get an exhaust so I need details please.
Getting things together so need to try and get this puppy running!
Steveo
Pages: 1 2 |
