[ Total Views: 65537 | Total Replies: 469 | Thread Id: 42287 ] |
Pages: 1 .. 4 5 6 7 8 .. 16 |
Brad
Threads: 332
Mood: Manx Buggy Building
posted on June 30th, 2008 at 06:34 PM |
Wow ....
westi
what the
Threads: 28
Mood: not blue, pink
posted on July 2nd, 2008 at 01:11 PM |
is your arse still saw.or maybe it's still convulsing alittle.
nice gear as always rod.
nothing but the best,love it.
can't wait to see it in action.hurry up ,i want to see more pic's.
down sharon.
dangerous
Mood: 591
posted on July 2nd, 2008 at 06:07 PM |
Speed up the process and put it in the yellow car...engines should be at the back.
Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
posted on July 2nd, 2008 at 07:01 PM |
i agree
down sharon.
23split
Threads: 8
Mood: RRRRRRRRRR
posted on July 2nd, 2008 at 09:45 PM |
Hey Rodney, welcome back home.
Absolutely awesome motor; makes my 2332 look a bit pedestrian.
Are you back in your workshop yet? Talk to you soon. Paul
RodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
posted on July 12th, 2008 at 02:25 PM |
Almost speachless !
Error |
Error |
Error |
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
Flintstones
Threads: 69
posted on July 12th, 2008 at 09:09 PM |
How nice does that look!!
Dino
2443TT
A.k.a.: Ian
Threads: 68
posted on July 12th, 2008 at 10:18 PM |
Looks like we are going to see some header fabrication happening soon...
matberry
posted on July 12th, 2008 at 10:29 PM |
Wow ....
kombiPILOT
Threads: 0
Mood: floaty
posted on July 13th, 2008 at 10:00 AM |
(I pick my jaw off the floor and wipe drool off chin) and then i do
my best Homer Simpson " UUUuuRrrrrrr............PAUTER........MMMmmmmm |
RodPenrose
Threads: 330
posted on December 30th, 2008 at 09:02 PM |
ENGINE MOUNTED
I have mounted the engine and it all fit's good at this stage . I will be removing the rack and pinion unit in favour of a small billet steering box
as I found it too dificult to route the steering shaft under and around the engine . I could easily bring the shaft over the top of the engine but
this creates the issue of disconnecting the steering every time the engine is removed . The steering box is the same unit as used in most front
engined dragsters and will now travel under the rocker cover to a bell crank linkage . I will also be fabricating all of the turbo exhaust and intake
manifolds by the end of January . I have decided to stick with the single turbo idea for weight and simplicity of the entire fabrication of the
manifolds . The Turbo of choice being the Garrett supplied GT51R . This is good enough for a recomemded 900 hp and will do for the time being and will
be up-graded when necessary , ROD.
Error |
Error |
Error |
humpty
Threads: 139
Mood: Totally boosted!
posted on December 30th, 2008 at 09:17 PM |
God damn!
reub
VWRX is gone...
posted on December 30th, 2008 at 09:18 PM |
Fantastic to see Rod.
We all look forward to seeing this beast roar!
Reub
fish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
posted on December 30th, 2008 at 11:29 PM |
Good work Rod, I spoke to Don the other day, he mentioned your engine and even he was excited. Should be a bullet.
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on December 31st, 2008 at 02:14 PM |
Nice to see some progress there Rod. Hope everything else is trouble free to get the thing on the track maybe sometime next year??
You vs Mr Kristen in the Ghia should be an event not to miss me thinks.....
humpty
Threads: 139
posted on December 31st, 2008 at 02:37 PM |
Quote: | Originally
posted by LIFE IN THE LOW LANE
And lets not forget the "new" Hound Dog!!!
It'll be nice day when all those sub-10 cars are out!
RodPenrose
Threads: 330
posted on February 7th, 2009 at 09:31 PM |
I have started on the aluminium intake manifold . I will have a single 75mm throtle body mounted in the centre of the engine and have a removable
centre section to allow the top of the block to lifted for regular maintenance of the conrod bearings . I am yet to determine if I will use a plenum
style of intake system or if I will gently direct the air into the individual cylinders . The tubing used is 3'' and it will then divide into a 2
1/4 '' runner for each cylinder .
Error |
Error |
Error |
reub
VWRX is gone...
posted on February 7th, 2009 at 10:15 PM |
Keep it coming Rod
Reub
humpty
Threads: 139
posted on February 8th, 2009 at 12:30 AM |
You are crazy Rodney.... Bloody awesome it is too!
kroozzn63
Threads: 317
Mood: mmm coffee
posted on February 8th, 2009 at 10:07 AM |
hey rod just a question "i know it wont make it faster but are u going to polish up all the intake pipes "? They are begging for it , if you have a
polish wheel ill come and do it for u ..
show us your gates
2443TT
A.k.a.: Ian
Threads: 68
posted on February 8th, 2009 at 04:10 PM |
Polished alloy is a complete pain in the ass to maintain, unless your going to volunteer to do the upkeep on the polish as well. Ceramic coating is
the go for a chrome like finish and it works as a heat barrier too.
posted on February 8th, 2009 at 08:44 PM |
coating is definately the way to go and is what Troy will do to his pipes once all the tinkering is finished cause I ain't polishing them every other
week!!
RodPenrose
Threads: 330
posted on March 23rd, 2009 at 07:08 AM |
Intake manifold
I have completed the basic design of the inlet manifold and am happy with the outcome . I am researching the fuel injectors needed at the moment so
this will do until I need some more welding and fabrication . I am looking into using the new E85 fuel rather than methanol so I can use less
injestors/wiring ect , all to save a bit more weight . The turbo is mounted and the exaught is almost finished , ROD.
Error |
Error |
Error |
RodPenrose
Threads: 330
posted on March 23rd, 2009 at 07:10 AM |
Error |
Error |
matberry
posted on March 23rd, 2009 at 08:22 AM |
Looks good Rod. Why no expansion joints in that manifold? Is it Al or ss? Wont it crack with temp differential anyway, even if its the same material
as the case, heads and barrels?
kroozzn63
Threads: 317
Mood: mmm coffee
posted on March 23rd, 2009 at 09:40 AM |
ahh thats better , nice design Rod , any ideas on car colour/interior yet?
show us your gates
STOCK
Threads: 12
Mood: OK
posted on March 23rd, 2009 at 11:40 AM |
LOOKING AWSOME ROD.
THAT MOTOR IS AWSOME
CANT WAIT TO HEAR IT SCREAM
STOCK
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
posted on March 27th, 2009 at 07:37 AM |
I think you better stay with Methanol fuel Rod , much more forgiving on tune - up and have a good look at how the fuel works ( yes it's nice to be
green E-85 ) . Lots of v8 guys you methanol with efi .
Wait ! what wait ,car will be lite anyway , E-85 tune window is'nt large ,it's not real racing fuel .
clinker42
Threads: 154
posted on April 3rd, 2009 at 05:15 PM |
Hi Rod
Do you have a 4 link program, Id love to see a pic of your chassis from the side (low down) and see the 4 link bars and up to the front. I bet it
will be a pain to set the 4 link up.
Trev
RodPenrose
Threads: 330
posted on April 10th, 2009 at 08:43 AM |
Trevor , I have plotted all of the 4 link points on a graph and I am happy with the adjustability that I have created on the rear end . This is the
same basic design that is used on 90% of drag racing cars so it should be quite easy to get some sound advice when it comes time to tune the chassis .
I researched the rear end set up a lot before I started as I didn't even know what a 4 link was , what an anti roll bar was , what a whishbone was .
It is amazing what I have learnt in regards to different set-ups , 4 link bars and how they work , the length of the bars , the length of the bars in
relation to the wheel bsae of the car , pinion angles and a lot more . I am looking forward to the challenge when the car is finished , ROD.
Error |
Error |
Error |
