| [ Total Views: 34905 | Total Replies: 265 | Thread Id: 44043 ] |
| Pages: 1 .. 3 4 5 6 7 .. 9 |
JVLRacing
Threads: 30
| posted on June 10th, 2009 at 09:15 PM |
  ouch
1303Steve
| posted on June 10th, 2009 at 11:45 PM |
Hi Damo
Good read, what model motor is that. I didn't think the later models had a cat in the up pipe. I have VF 30 as well, came with the motor.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on June 11th, 2009 at 06:19 AM |
Hi Steve
motor is 2001/'02 (i think)...........however i suspect the exhaust might have came off the previous engine........i'll tell you what tho, with the
heat shield removed, those up pipes are a fairly agricultural piece of work
will you run the VF 30 or ?
jzk25
Threads: 3
| posted on June 11th, 2009 at 06:59 AM |
STi's don't have a pre turbo cat, only MY01-02 WRX have it. And yes, they often end up jammed in the exhaust housing. Sometimes you get away with
it, sometimes the piece of cat reprofiles the turbine wheel. Any normal up pipe will bolt in it's place but if you have factory management you need
to either refit the exhaust temp sensor or put a resistor across it. Aftermarket management cares not.
1303Steve
| posted on June 11th, 2009 at 05:50 PM |
Hi Damian
I think the VF30 will do for a start. With the little things Ive done and will do it should make a bit over 200kW at the wheels, plenty for a
while.
Bigger intercooler, bigger cross pipe, 3 inch exhaust, boost up a little and Autronic SM4 ECU.
hellbugged
A.k.a.: Daimo Pell
| posted on June 11th, 2009 at 10:36 PM |
| Quote: | Originally
posted by jzk25
thanx heaps for your knowledge........so, going by that engine is '02 as i first suspected. HALTECH ecu, so no probs with changing it. cut it up and
cleaned it out with the die grinder so will do for the interim till we get all our duckies in a row again
hellbugged
A.k.a.: Daimo Pell
| posted on June 11th, 2009 at 10:41 PM |
| Quote: | Originally
posted by 1303Steve
Hi Damian
while.
cool Steve,
200KW at the wheels is plenty for sure....if you come up for the Winter break earlier in the week, we can throw a few laps down at Raleigh to get you
keen on finishing yours off......very similar specs.
jzk25
Threads: 3
| posted on June 12th, 2009 at 08:41 PM |
VF30 should make 200kw atw at around 18psi. 18psi would be considered a safe boost level for an STi engine with good intercooling.
1303Steve
| posted on June 13th, 2009 at 08:16 AM |
Thanks for the offer Damo, I will see what I can do about getting up earlier.
jzk25, are you aka Allen? I have a PWR air 2 water barrel intercooler.
hellbugged
A.k.a.: Daimo Pell
| posted on June 14th, 2009 at 10:44 AM |
| Quote: | Originally
posted by jzk25
cool, thanx again
what about on standard WRX motor, safe PSI would be?
what difference internally of STI motor and standard REX?
jzk25
Threads: 3
| posted on June 14th, 2009 at 01:10 PM |
Yeah Steve it's Al that did your wiring.
Daimo, 200kw atw(all 4) is no problems for a std WRX engine if tuned nicely. An STi engine has forged pistons and rods(in 2001 on) larger cams, AVCS
valve control, no tumble valves, 550cc injectors, semi closed block deck and a lot of other little differences. They can handle up to 300kw atw(with
shortned life obviously).
I wouldn't go over 20PSI in a std wrx engine with good intercooling. Charge cooling is a big variable when mounted in a beetle so you need to be
careful of that. You would be better going up to a larger more efficient turbo in a beetle as it probably doesn't need the low end power due to no
weight and the larger turbo will free the engine up and reduce the chance of detonation. Something like a TDO5 20G with 8cm exhaust housing.
1303Steve
| posted on June 14th, 2009 at 04:17 PM |
Hi Al
I thought was you, when I get mine running eventually I might look at things that can be upgraded on the outside, that's why I bought a STI motor, it
has all the good gear from the factory.
Would a TDO5 20G be a good upgrade for a 2002 STI motor?
jzk25
Threads: 3
| posted on June 15th, 2009 at 06:59 PM |
Yeah TDO5 20G has a 68mm compressor as opposed to 60mm of the VF30 and 35. You can also get 8cm exhaust housings which will free up the top end even
more. As always there is a sacrifice in low end power but in a light car it shouldn't matter. STi engine in particular will happily rev to 8k rpm and
make power there so the bigger turbo is a good thing.
Kando Dynamic is a good source for TDO5's.
hellbugged
A.k.a.: Daimo Pell
| posted on July 5th, 2009 at 08:44 PM |
well, i got the heebeegeebies and pulled the turbo off to make sure it was undamaged internally...........pulled the exhaust housing off to reveal no
significant damage to the blades where it had been jammed.
so the car is pretty much ready to race again now it's got it CAMS compliant livery on again........even polished the alloy and painted the exhaust,
the car won't know what's going on now
JVLRacing
Threads: 30
| posted on July 5th, 2009 at 09:50 PM |
looks smarter
hellbugged
A.k.a.: Daimo Pell
| posted on April 30th, 2010 at 10:53 PM |
spose i should try and get this thing to the Nationals super sprint again hey.....bring on the pressures of the internet
colonel mustard
Threads: 51
| posted on April 30th, 2010 at 11:19 PM |
DO IT!!
westi
what the
Threads: 28
Mood: not blue, pink
| posted on May 1st, 2010 at 11:40 PM |
lookin great with the paint,need's more tread though.you gota fill them guards up.
down sharon.
hellbugged
A.k.a.: Daimo Pell
| posted on May 2nd, 2010 at 08:40 AM |
alrighty then .........have had the child labour camp working on that
one Westi........not up to making a nice cross over pipe yet tho, know anyone????
porsche cup wheels & tyres were a bit tarty after the fire extinghisher powder had a munch on them. 10 and 11 inch modi fodees fill those
guards.........
hellbugged
A.k.a.: Daimo Pell
| posted on May 2nd, 2010 at 09:48 PM |
ok we are on the way
the child slave labour is working well
the "practice" slicks have had the treatment too.....spit and polish and a good 10 coats of "RPM GRIP" (tyre softner).......that stuff is great
for anyone with either new or aging race tyres!
.......but it's not all a "work only" policy. the lil one got to enjoy the fruits of her labour after a long day
it must be in the blood
DAMN TRAILER SAILORS!.....
first step with this thing is always the trailer, but have managed to trim through the list of things to do before an event attendance is even
possible.
:locate trailer and ramps bolt on the tyre chocks
:thorough de-mulch, degrease and wash the tray
:find some decent rims to replace rusty spares and get tyres changed over
:search faulty wiring, end up soldering half of the wires in the broken loom, more at the back, re-insulate many joins of which the insulation had
aged and no longer served it's purpose
:replace rear tail lenses and clean up terminals so they actually work
:solder all wires at plug end
:replace "break away" unit
:weld broken tie down points and search and locate chains
:wheel bearings and electric brake maintanance
trailers SUCK !
..........but they do serve a purpose....
did a fuel system clean and fired it up.
up to temperature and sent a can of subaru upper engine cleaner through the engine......got it safely onto the float and now in the garage at home for
those late night stints.
'tis not much, but it's a start for sure
as i was fiddling around with it this arvo, a teenage fella with autism came past and spent a good hour looking around and asking questions. the dude
was an absolute motorsport nut and was stoked to strap himself in, put up the window net and shift up and down the gears. He was STOKED.......and so
was i. it has been worth the effort already
making up a list for the car now, plenty to get done yet
matberry
| posted on May 2nd, 2010 at 09:59 PM |
Looking good Daimo, plenty o' time this year hey. Good luck.
reub
VWRX is gone...
| posted on May 2nd, 2010 at 10:02 PM |
Looks sweet as dude! Not sure about internet pressures, but if you want some I'm happy to dish some out
I'll have to get this aircooled 'bug' out of my system and start my own subie power upgrades...
Reub
hellbugged
A.k.a.: Daimo Pell
| posted on May 3rd, 2010 at 08:31 PM |
| Quote: | Originally
posted by reub
too funny as i'm working in the opposite direction....... .........if only i can get this subie thing reliable, i'll be getting back to the ole faithful aircooled
matberry
| posted on May 3rd, 2010 at 10:39 PM |
| Quote: | Originally
posted by hellbugged
Bout time dude   .
hellbugged
A.k.a.: Daimo Pell
| posted on May 5th, 2010 at 08:03 PM |
onto the car........
: re-wire tail lights and master cylinder so brake lights operable (more damage from fire) which took the best part of a day..............Rizzo
didn't look too impressed on dummy grid when i sent someone to tell him they had failed again last year.......hopefully he might have to see them
this time around
: re done hardened fuel lines and pump wires at front of car away from radiator lines......added pre pump filter back under tank that was removed at
Valla races 2008
: check front end components including bearings, pads for wear,calipers, tie rods,ball joints and steering.....bleed brakes and grease
: sort headlights
: fix front splitter
: fill and fully charge neglected battery
: clean out rat shit from interior
: change coolant, move turbo H20 return to correct side of engine
: replace bolts and gaskets in de-cated up pipe
: install new air intake pipe and subsquent re arrangement of attached ancillaries
: treat K&N air filter
: insulate tank from heat and build radiator shroud (most likely some of the longest/hardest running the car has ever done SHOULD happen at
Wakefield)
: check rear brake pads and lines then bleed
: clean engine bay of all soot and crap from the fireball (FINALLY)
: condense spares boxes down to at the most 2 boxes of "well shouldn't....... but could possibly happen" essentials
: "pallet wrap" 3 sets of freshly "softened" wheels
: get away for a test and tune before even putting it on the trailer for the trip
: engineer and blue slip in time to drive to Goulburn .......forget the trailer
.........and i'm still miles in front of last year!........back to it guys, check ya!
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on May 5th, 2010 at 09:10 PM |
So does the VWRX need a test Pilot ?? !
hellbugged
A.k.a.: Daimo Pell
| posted on May 6th, 2010 at 06:33 AM |
yeah it does Craig..........you know the deal
"leave your pink slip with me before you go!"
and "no no officer, it IS the yellow one, we just finished painting it!"
JVLRacing
Threads: 30
| posted on May 6th, 2010 at 12:53 PM |
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
| posted on May 6th, 2010 at 06:29 PM |
that thing should be on the roads...what a great car
hellbugged
A.k.a.: Daimo Pell
| posted on May 6th, 2010 at 10:28 PM |
yeah Rob would be a great street drive.........but it really is way too fast for the street.........2nd gear finishes at 120+km/h and it takes no time
at all to get that done
my licence wouldn't last long
