[ Total Views: 52400 | Total Replies: 453 | Thread Id: 50353 ] |
Pages: 1 .. 10 11 12 13 14 .. 16 |
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on April 18th, 2013 at 08:20 PM |
this project is just awesome mate .... one of my personal favourite threads on this forum
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
posted on April 18th, 2013 at 10:02 PM |
Well done Gary coming along quick now , you could bead roll a tailgate shape into the back panel or air brush .
Least you have plenty of room for wheelie bars and chute holder later .
Good colour to .
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on April 18th, 2013 at 10:03 PM |
Well I guess there is only 1 option for me- I will have to tow it over to your world next February and give it a run.
whathaveidone
Threads: 98
Mood: Heading for 10.99
posted on April 18th, 2013 at 10:07 PM |
You could always have a few late nights and get it here for june!!!!!! I agree with pete on the bead rolls. would finish it off nicely.
nbturbo
Threads: 89
posted on April 22nd, 2013 at 09:12 PM |
Took it out last Saturday to give it a try out.Had some serious overfuelling problems from idle and up to about 2,500 revs.I have a standard VW
convertor in it still,but it just wouldn't drive from rest without flooding the motor and stalling.I managed to get 2 half arsed runs in-but with
both runs the motor didn't clear itself of fuel till about half track-then all hell broke loose as it came on boost.The last run got me through the
lights at 91mph,so I am almost 100% happy with it.We are doing a computer link up one night this week with the Tuner,and he will pull a lot of fuel
out below 2000 rpm.I am still having some oil mist coming from a couple of pushrod tubes-what do you blokes consider to be the best brand tubes to
use?
Flintstones
Threads: 69
posted on April 22nd, 2013 at 10:22 PM |
Glad to see that you got it out on the track.
hopefully it won't take the tuner much to sort out.
when are you planning to go back out to the track?
you've got to post some vids for us
nbturbo
Threads: 89
posted on April 22nd, 2013 at 11:34 PM |
Our next meet here is May 11- my priorities now are to have the rear body fully painted,a new hi stall convertor done and of course get the fuel map
sorted. If all this doesn't happen b4 May 11, then I will be ready for the meet after that.
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on April 23rd, 2013 at 01:31 PM |
great to hear Gary , that you have way too much fuel supply .... it is easy to take small amounts out , it is a lot harder to find extra fuel supply
or even repair a torched engine .
Very well done mate , looking forward to hearing and seeing how your car goes as you pull fuel out and get a cleaner tune
Team
ian.mezz
Threads: 280
posted on April 23rd, 2013 at 06:18 PM |
Quote: | Originally
posted by nbturbo
use?
one of these fix lots of oil leaks .
Error |
nbturbo
Threads: 89
posted on April 23rd, 2013 at 10:43 PM |
I like that-must be made of some good gear.Being so close to exhaust etc,would get seriously hot.Had planned on making an ally catch pan to sit under
the motor and make it easily removable.
nbturbo
Threads: 89
posted on April 23rd, 2013 at 11:09 PM |
Quote: | Originally
posted by hypo-vw
I have heaps of fuel available still.The injectors are no where near maxed out at full revs under load and I have a 1400 HP pump,so have a lot left in
the pump also.
nbturbo
Threads: 89
posted on May 4th, 2013 at 10:27 PM |
I had some issues with the blue hose that I bought which was Methanol / Oil resistant ( came highly recommended from the hose guy here) It turned out
to be shit.It was made from some type of plastic and as soon as it got hot it went hard and wouldn't seal any more.I have changed it all now for some
good braided hose.I have made an aluminium catch pan to go under the engine and bellhousing- just in case it springs a leak.It can be removed by just
one spring loaded clip.Engine tuner let me down last week-have locked in a definate time this Monday.
Error |
Error |
Error |
nbturbo
Threads: 89
posted on July 7th, 2013 at 07:31 PM |
I have finally finished all the paint and mechanical jobs on my car.I have a signwriter doing a wrap down each side and an Australian flag on top of
the spoiler.Have to fit the chute and cable when Rod's container arrives.
Error |
Error |
Error |
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on July 7th, 2013 at 08:47 PM |
Sensational mate!! Looks the goods!!
nbturbo
Threads: 89
posted on July 16th, 2013 at 08:12 PM |
Looking for some info-what do you blokes who are running Methanol with electronic injection do after each meet? Are ther any special things you do to
keep everything clean and prevent any alloy corrosion? I have heard of different things that are done to prevent the fuel system getting sludge build
up with the Methanol going to jelly.
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
posted on July 16th, 2013 at 08:27 PM |
Put a tune in it to run on pump fuel, doesn't need to be anything special just enough to start and run, make sure you've got a drain plug in the
tank to drain the methanol and run a few litres of unleaded through to flush it out
ian.mezz
Threads: 280
posted on July 16th, 2013 at 09:20 PM |
seven years in the making , must feel good now that its nearly ready to race , well done.
nbturbo
Threads: 89
posted on July 16th, 2013 at 11:01 PM |
Quote: | Originally
posted by ian.mezz
It sure is a good feeling now it's ready- but a bit wary that it will scare the shit out of me when I give it the first full power run. Thanks for
that tip Troy, will ring the tuner bloke tomorrow to see what he can organize. I remember he put 2 tunes into it related to ambient temperature. It
gets really cold here at night after fairly warm days, so I can put a different tune in it to run after dark.
1916baja
Threads: 176
posted on July 17th, 2013 at 10:12 AM |
Get your injectors cleaned and flowed regularly. Dave has found the injectors to be a constant maintenance issue with the meth. I know he won't see
this so I answered it for him, I'm sure he'd stress the same thing.
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on July 17th, 2013 at 06:18 PM |
Quote: | Originally
posted by 1916baja
Hi Gary , firstly I would like to congratulate you on a very unique and awesome quality build , that ute of yours looks fantastic mate .
Us guys at Team WPVW all use methanol fuel in both our injected & carburetted drag bugs . We run a methanol fuel additive from VP Racing Fuels Inc
. This additive has a scented candy smell which helps with the 'eye burning' issues from the methanol exhaust fumes , and is designed to protect all
aluminum fuel system parts . It also lubricates the valve guides and valves .
If we are competing at race meetings within 3-4 weeks of each other , we leave the fuel in our cars ..... if the meetings are months apart we drain
the entire fuel system and flush it out with unleaded fuel . The injected cars we plug into the Microtech and remove 40% fuel from the mixture trim
and they run smoothly .
Ben Ford has not raced his bug since November and the same fuel still sits in it now ..... we checked his fuel system prior to starting it with the
new injection system a couple of weeks ago and found no signs of contamination / jelly .
Error |
Team
1916baja
Threads: 176
posted on July 17th, 2013 at 06:52 PM |
Yeah, he's using that... Still has to keep an eye on it though.
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
posted on July 17th, 2013 at 07:59 PM |
Additive is the go , I use to flush with BP Zoom (oil in petrol) but later switch to VP Additive and this stop the jelly blobs But
the other best thing to do is just run your car every couple weeks ( keeps fuel from drying out in the system every where ).
The flow level line is the corrosion piont ( fuel level meets the air level ) this is when the white powder stuff comes from , I use to seal off the
fuel tank as well from the air ( stops moisture entering and corrosion in alloy fuel tank )
Cast alloy is mostly what gets atttack .
nbturbo
Threads: 89
posted on July 18th, 2013 at 06:10 AM |
Thanks for the info fellas. Wayne,appreciate your comments- I have been using that additive in the fuel, but had no idea about it's protection
properties as you have mentioned. Have got a 50% fuel map coming. Checked out the new body wrap yesterday- love it. He has to do the lamination
still,can then start fitting it.
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on July 18th, 2013 at 08:31 AM |
Nice tow-car, Gary. Is that a S.A. tow-hitch?........seems a bit high to me.
When do you start on the race car?
nbturbo
Threads: 89
posted on July 18th, 2013 at 02:26 PM |
Good day Greg-decided that it's going to be a dual purpose vehicle,tow car during the week and drag car on weekends. Will hook number 8 up to it one
day,and tow it faster than it's ever gone before.
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on July 18th, 2013 at 08:48 PM |
Quote: | Originally
posted by nbturbo Will hook number 8 up to it one day,and tow it faster than it's ever gone before.
I love it , light-hearted rib-jabbing comments
just Gold !!
Team
nbturbo
Threads: 89
posted on July 28th, 2013 at 09:01 PM |
Started on a set of ladder bars for my car this week.Can't believe how many hours go into this stuff.Used 7/8" C/M tube and fabricated the wheel
brackets from some 100X50X4mm RHS.Had an Australian flag put on the rear spoiler and the side wrap goes on this week.
Error |
Error |
Error |
nbturbo
Threads: 89
posted on July 28th, 2013 at 09:03 PM |
Ladder Bars--
Error |
Error |
Error |
cjbolt051
Threads: 4
posted on July 29th, 2013 at 12:06 PM |
Love the aussie sticker cant wait to see it on the track. Well done
mate
Winner best engineered vehicle 2011 @ Warwick & 2012 sydney
1/8 6.71 @ 100.9 mph Warwick 2011
1/4 10.17 @ 137 mph WSID
nbturbo
Threads: 89
posted on July 29th, 2013 at 04:28 PM |
Thanks Chris- you know that we will have to run together one day.
