[ Total Views: 52462 | Total Replies: 453 | Thread Id: 50353 ] |
Pages: 1 .. 4 5 6 7 8 .. 16 |
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on July 31st, 2011 at 05:36 PM |
Thanks-I see from your work that the 5'' angle grinder has become your best friend as well.If my plans come together as I am hoping-I will be able
to have a run with you at Portland next Feruary.I plan on getting to Warwick to catch up with all you Blokes again.
nbturbo
Threads: 89
posted on August 24th, 2011 at 10:46 PM |
Fitted a few bits to the body and put 1 door together.Roll cage / pan has been Teched and it's away being painted.Pan will be back early next
week-then the fun begins.
Error |
Error |
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on August 25th, 2011 at 06:30 AM |
awsome!
been waiting to see what happens from the doors back
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
posted on August 25th, 2011 at 09:39 AM |
Maybe it will be a different car - that is how Herbie did it in one race. lol
From your ole' mate Jeff
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on August 25th, 2011 at 05:06 PM |
Amazing.
Where's the rest of it, Gary.......or are you just a 'Front man'?
nbturbo
Threads: 89
posted on August 25th, 2011 at 05:16 PM |
You know me Greg-" tail " end Charlie - so be alert.
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on August 25th, 2011 at 05:27 PM |
Quote: | Originally
posted by nbturbo
I'm not sure if I want to be a 'lert'. What is a 'lert', anyway?
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
posted on August 25th, 2011 at 06:05 PM |
I thought you must have got that far, then ran out of money. :-)
nbturbo
Threads: 89
posted on August 30th, 2011 at 06:27 PM |
I have everything now except the fuel injection-let the assembly begin.
Error |
Error |
debiasi4
Threads: 51
posted on August 31st, 2011 at 11:17 AM |
Looks fantastic Gary.
Cheers Adam
JVLRacing
Threads: 30
posted on August 31st, 2011 at 11:26 AM |
popcorn eating VERYNICE
nbturbo
Threads: 89
posted on September 9th, 2011 at 12:20 AM |
Been in Sydney for a week-got home late last night,so not much action.Put all the front suspension,steering, brakes,pedals and shifter on tonight and
finished the beading in the front guards.What do all you Blokes use for shockers front and rear-anything fancy or just standard stuff?
Error |
matberry
posted on September 9th, 2011 at 08:10 AM |
Cars looking the part, good work
Shocks depend on budget.....for drags tho, I tend towards Koni rear for adjustability and very worn out stock fronts, the type with no oil left in
them for the front .....or Koni's in the front to, but you'll need to
get them revalved, but then you get adjustability in the front too.
20bkombi
Threads: 26
posted on September 9th, 2011 at 09:56 PM |
Could also try rancho 9000's, 5 point adjust by a knob or in cab. I've used them in my bus for over eight years, tuning them as my power
increased.
Looking very cool!!!
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
nbturbo
Threads: 89
posted on September 10th, 2011 at 12:06 AM |
Thanks fellas-will chase that info up.
dangerous
Mood: 591
posted on September 10th, 2011 at 07:37 AM |
I use stock oil KYB at the front and KYB gas offroad for the rear.
Adsjustable is good if you need to dial it in,
and your extra rear weight will require some interesting spring rate,
and thus a shock that can control it.
Quote: | Originally
posted by westi
That's mad Alan.
whathaveidone
Threads: 98
Mood: Heading for 10.99
posted on September 10th, 2011 at 03:55 PM |
Ive got LJ torana 90/10s on the front. Off the shelf from pedders. They have very short travel so no need for limiting straps.
nbturbo
Threads: 89
posted on September 10th, 2011 at 05:12 PM |
Thanks- do the Torana ones fit a Link Pin beam?
whathaveidone
Threads: 98
posted on September 10th, 2011 at 07:19 PM |
Yep, you just have to drill the spacer out on the shock and the go straight on. Will get some good pics for you tomorrow.
whathaveidone
Threads: 98
posted on September 17th, 2011 at 07:23 PM |
Here the promised pics. A little late!!!
Thats at almost full extension and wheel is still on the ground
humpty
Threads: 139
Mood: Totally boosted!
posted on September 17th, 2011 at 07:28 PM |
Now there's a good tip!.... Have been looking into 90/10's for a while now.... You wouldn't have a part number would you?
Cheers for that Ben....
whathaveidone
Threads: 98
posted on September 17th, 2011 at 07:43 PM |
There LJ torana. Pedders had them on the shelf. No ordering in. Cant remember price. maybe $250-$300
humpty
Threads: 139
posted on September 17th, 2011 at 07:49 PM |
Cool....
nbturbo
Threads: 89
posted on September 17th, 2011 at 10:31 PM |
Thanks for the pics-that makes the choice real easy for me now.
essex
posted on September 18th, 2011 at 06:58 AM |
I have chosen the same, they were less than $200.00.
this is an old pic, i havent got any rears yet either
[img][/img]
nbturbo
Threads: 89
posted on September 21st, 2011 at 05:50 PM |
Ben-fitted the headlight decals,very nice.I buggered the first one up-couldn't get all the air bubbles out.So made a weak soap solution and sprayed
the area-went on like a dream-thanks for organising.Will fix you up in Warwick.Started on the panel to go across the body-done the lower bit.Fitted
all the rear end now-brakes and hoses,drive shafts,torsion bars etc.Bought this 12volt solenoid valve to go in the suction line to the dry sump
tank-will be energised with the ignition switch.
Error |
Error |
Error |
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on September 21st, 2011 at 06:04 PM |
outstanding job Gary !! very impressed indeed . thanks for the updates mate and see you at Warwick
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
nbturbo
Threads: 89
posted on September 21st, 2011 at 06:05 PM |
A few more
Error |
Error |
Error |
nbturbo
Threads: 89
posted on September 21st, 2011 at 06:11 PM |
This is the breather box finished and painted.Yes starting to count the sleeps.
Error |
humpty
Threads: 139
posted on September 21st, 2011 at 07:02 PM |
Love those headlight decals..... Very cool.... Hadn't noticed the steering column placements before.... Did you lift the beam/framehead up on the
pan?
