[ Total Views: 52512 | Total Replies: 453 | Thread Id: 50353 ] |
Pages: 1 .. 5 6 7 8 9 .. 16 |
Flintstones
Threads: 69
posted on September 21st, 2011 at 09:28 PM |
Looking real good now Gary
D
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on September 21st, 2011 at 10:16 PM |
Yes Humpty-grafted another frame head on,but lifted it 3 inches and laid it back 10 degrees.You can see where I had to cut the body to get the column
through.
Error |
Error |
Error |
miccro
Threads: 4
posted on September 30th, 2011 at 12:05 AM |
good work, should be fun.
- interested in the 90/10's - are they rated for vw beetle weight. as most 90/10's are set for front ended v8 tolerances. you can easily get front
lift at the end of the 1/4 when letting off the gas. in the UK we lost 2 cars going through the gates at over 115mph. i know the american guys often
still use them but alot only run 1/8 miles. all the uk guys stopped using them quick.
should put the wheels up for you at the lights tho
mike |
nbturbo
Threads: 89
posted on October 25th, 2011 at 08:39 PM |
After my trip to Warwick and some discussion with Wayne Penrose,he suggested my fuel rails are too small with -6 fittings,so made some new ones to
take -10 fittings and hose.Have done another order for ally fittings and Methanol resistant hose from the US-should be here early next week.Still
waiting on CB's new fuel injection to be done so I can get a system sent out.Starting to get close now to needing it.Finished mounting the glass
bonnet and had to make a few of the fittings.
Error |
Error |
Error |
Turbo54
Mood: Boost'n
posted on October 26th, 2011 at 08:53 AM |
I was talking to Mike at MV and he said he was building your box for you. Top Bloke Mike, been helping him do some stuff for the Ute.
Car is looking great, love the look of the front end.
T54
C'mon kids gather round,
nbturbo
Threads: 89
posted on January 7th, 2012 at 07:57 PM |
Seem to be spending hours on this with not much progress.Spent quite a few weeks sorting out the injection with Pat from CB's and he finally came up
with a good working system,which included the ECU,cam and crank sensors,coil packs and all the sensors needed for ECU inputs.I have also ordered
Aeromotive filters,1400HP fuel pump and a pressure reg.I have still got to buy some 120lb injectors,but they are readily available.Now that I will be
using CB's crank sensor,the main relief valve and piping that went behind the crank pulley has to go.It will get in the way,because the room is
needed for a bracket to hold the probe.I have made all new fittings and shifted the main relief valve line to come out the back and into the bottom of
the fitting on the pump.I had to buy some more slicks for the back-the 28x9's ran too close to the spring plates,so will try some 26x8's.Was going
to try some spacers to shift the wheels out,but it got too hard.
Error |
Error |
nbturbo
Threads: 89
posted on January 7th, 2012 at 08:14 PM |
Further to my discussion with Wayne about fuel requirements-and also with a bloke at Aeromotive,I have welded a -12 bung into my fuel tank and will be
-12 lines to the pre filter,the suction side of the pump and to the secondary fitlter.From there it will be -10 back to the pressure reg and the
return line to the tank.
Pork Sword
A.k.a.: Greg
Threads: 1
posted on February 5th, 2012 at 10:43 PM |
Hey Gary,
I sent an email to Ray for him to forward you about my car, I couldn't get my old username on here sorted out so had to make a new one.
Your car is coming together nicely, I haven't seen the pics of it since you painted it - couldn't log on... -12 fuel - massive!!
What are you doing with your 28x9 slicks? That's the size I want to use.
Greg
58 Beetle drag racer project
64 1500S Notch
69 Squareback
nbturbo
Threads: 89
posted on February 6th, 2012 at 03:23 PM |
Yes got the photos-top quality build happening there with the best bits available going into it.Tried to catch you over Xmas to have a perve on it.I
did a rework on the rear stub axles-machined the bearing/seal collars to move the stubs out 9mm each side and reshimmed the calipers and mounting
plates to suit.I think I now have enough tyre to springplate clearance.Will wait until I have it mobile to check it out.Bought another set of slicks
which I may now not need.Would like to come round next time I am in Town for a look.
Pork Sword
A.k.a.: Greg
Threads: 1
posted on February 6th, 2012 at 10:20 PM |
Yeah Christmas was a busy time, by the time I realised you had called you were gone, didn't check my work phone while I had those few days off.
Would be good to chew the fat next time you're in town!
Sounds like lots of work to get the clearance, hope you've got it nailed... This thing will be mental on the track! Can't wait till mine's all
shiny like this, will be a while
64 1500S Notch
69 Squareback
Turbo54
Mood: Boost'n
posted on February 7th, 2012 at 09:02 AM |
Pork Sword, nice new user name greg. Good to catch up the other day. Let me know when your free so I can come around and check out the beast.
Gary, what fittings are you using? Earls, Speedflow etc?
Heath
nbturbo
Threads: 89
posted on February 7th, 2012 at 05:16 PM |
Heath,have used all "Fragola Performance Systems" fittings in the Push-Lite 8000 series.I have also bought their hose to use for the fuel
system-methanol compatible.I have used hose from here for the oil side-also push on stuff.I have used the "O" clamps on any thing with pressure and
nothing on the suction side.Once you push the hose on,it will not come off-any mistakes it has to be cut off.
Turbo54
Mood: Boost'n
posted on February 7th, 2012 at 10:28 PM |
Hi Gary, where did you by them from? I am looking at speed flow fittings but would like a quote from another supplier for a comparison.
Thanks heath
nbturbo
Threads: 89
posted on February 11th, 2012 at 11:35 PM |
Flew over to Perth yesterday to go to the Motoplex Drag Racing today-what an unbelievable complex. Witnessing some awesome cars and a really slick run
show. Bit disappointed though-not one VW in sight. Only VW thing I've seen was a bloke with a VW T shirt.
reub
VWRX is gone...
posted on February 12th, 2012 at 12:02 AM |
LOL. Yeah, kwinana is awesome. I look forward to taking vwrx down there later in the year.
Reub
humpty
Threads: 139
Mood: Totally boosted!
posted on February 12th, 2012 at 10:49 AM |
Quote: | Originally
posted by nbturbo
No one here with a purpose built Drag Dub.... The only one that is here in WA hasn't run for a 20 years!.... And yes you are correct.... The
Motorplex is an amazing place.... We are incredibly lucky here in WA.
nbturbo
Threads: 89
posted on March 18th, 2012 at 08:32 PM |
A question for the experts out there-I bought some adjustable spring plates and the ally 4 bolt retainers with the bronze bushes-what do I use for the
inner bushes,standard VW rubber ones or something special? I have just finished modifying some rear suspension arms-done the swap from side to side to
give me less -ve camber,so decided to add some brackets if I need to make wheelie bars down the track.Wondering if they are on the suspension,will
they work OK? Got my exhaust back from having the heat proof coating put on,very pleased with the result.
Error |
Error |
whathaveidone
Threads: 98
Mood: Heading for 10.99
posted on March 18th, 2012 at 09:17 PM |
I used standed rubbers on mine but had to die grind the insides out so they fit on my spring plates. I couldnt find any urethane that would fit. I
have a set that im going to machine both inside and outside when i figure out how to hold them in the lathe without squashing them!!!
matberry
posted on March 18th, 2012 at 09:47 PM |
I generally use a stock rubber inside bush with the alloy springplate cover.
I wouldn't recommend mounting the wheelie bars to the suspension. I believe it will unload the tyre as the wheelie bars take up. Usually chassis
mounted.
cnfabo
Threads: 140
posted on March 18th, 2012 at 10:17 PM |
wow,really loving this thread...the colour combo works good too...
nbturbo
Threads: 89
posted on March 20th, 2012 at 10:25 PM |
Thanks fellas-I got on top of it. Used standard VW inners,but had to do a lot of work on them on the belt sander. Reduced their thickness to around
28mm and put a large chamfer on the inner diameter-all OK. I had to machine some spacers to go between the ally spring plate retainers and the
torsion bar tube. Without spacers it all locked up-is that normal?
matberry
posted on March 20th, 2012 at 11:10 PM |
Yes, the spacers normally come with the spring plates. Needto space out for the double springplate thickness.
nbturbo
Threads: 89
posted on March 21st, 2012 at 05:48 AM |
OK-mine didn't come with anything extra.It's all back together-waiting for my suspension arms to be painted then just play with getting the ride
height adjusted. Thanks for your help.
nbturbo
Threads: 89
posted on April 14th, 2012 at 05:09 PM |
Still plugging away at it.Rear arms are done and in.Got sick of trying to do up the pivot bolts a flat at a time,so bought some 17mm hex bar and
modified the bolts-so easy now.1400HP fuel pump,filters and pressure regulator arrived but still waiting on the O ring ally fittings to suit.Have
started on the rear guard to get it ready to do a fibreglass mould.Used the back half of 2 fronts and added 130mm flat to get the width to cover the
slicks.Almost finished welding the pie cuts then need to dress it all up and give it a coat of bog and primer.I found these exhaust nuts from the
US-8mm thread with a 3/8 AF outside-will fit the tightest spots.
Error |
Error |
Error |
nbturbo
Threads: 89
posted on April 14th, 2012 at 05:12 PM |
Some more
Error |
Error |
Error |
nbturbo
Threads: 89
posted on April 14th, 2012 at 05:15 PM |
And more
Error |
Error |
Error |
nbturbo
Threads: 89
posted on April 14th, 2012 at 05:28 PM |
Had a bit of drama with the drive shafts.When I originally set all this up I had a 74 auto trans assembly fitted.It was all mounted and I had a Forum
Member make me 2 new drive shafts to suit.When I stripped the diff to fit the new ally full spool,I couldn't get it in and after some confusion with
Dave Folts,discovered that I needed a later Vanagon trans.I quickly found one and had to slighty modify the front mount and left it at that.Went to
fit the drive shafts last week and no way they will go in.Did some measuring and found the Vanagon is much wider than the early trans.The same bloke
who did my first set of drive shafts is going to do another shorter pair for me-much appreciated.
hypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
posted on April 15th, 2012 at 10:21 PM |
Hi Gary , are you not able to trim the driveshafts shorter to fit them ? I purchased chromoly race axles from US which were 19.5" in length and I had
to shorten them to 18.5" to suit my application , and there is plenty of spline left for the CV joints .
Team
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
nbturbo
Threads: 89
posted on April 16th, 2012 at 01:14 PM |
No Wayne-there is only enough spline to get the CV's on. The extra long splines don't cause any issues with the CV staying centralised?
hypo-vw
Threads: 82
Mood: hypo cruis'n
posted on April 16th, 2012 at 08:56 PM |
Quote: | Originally
posted by nbturbo
I have never used them before Gary and I really dont know mate . Ben Ford is using them on his supercharged drag bug and has no issue at all with the
axles and Porsche CV's , but mine run at a very steep angle as the engine and tranny have been pushed 6" forward in the new circuit car .
BTW love the progress and the pics of your ute ...awesome mate !!
Team
