[ Total Views: 325036 | Total Replies: 1582 | Thread Id: 58055 ] |
Pages: 1 .. 49 50 51 52 53 |
mactaylor
Mood: even my dog is german
posted on May 27th, 2015 at 09:39 AM |
It is always something simple! the hard part is finding it!
EVERLAST CONCRETE TANKS
1800 552 123
dangerous
Mood: 591
posted on June 2nd, 2015 at 08:02 AM |
Time to replace the axles and upgrade the stubs.
Found some NOS bus stubs which are 35mm compared with bug at 30mm.
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on September 1st, 2015 at 08:09 AM |
The 2015 Jamboree was awesome! 8 Volksies entered, and 5 in the All Motor Class.
I had no opportunity to test before hand, due to work and weather,
but the car went well,
although still trying to solve some supply issues in the fuel tank,
which resulted in an inconsistent car.
I Did, get a personal best though, on Saturday Arvo, before the rain came.
10.664 @ 126.09, with a 6.770 @ 100.26mph on the 1/8 mile.
1.435 sixty.
Car weighed 1843lbs after that run. (837kg)
I thought I had been leaving the line at 7500, but turns out the wire fell off the switch
8400 launches were a bit brutal.
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on September 1st, 2015 at 08:11 AM |
ETs:
10.804
11.530 hand slipped off the knob in 3rd
10.664 PB!
10.985 cold engine
10.814 hot engine
10.730
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on September 1st, 2015 at 08:12 AM |
MPH:
123.95
118.58 lean
126.09 (on the 10.66)
121.47 cold
124.05 hot
124.64
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on September 1st, 2015 at 08:14 AM |
SIXTY FOOT TIMES:
1.458
1.492 bogged lean
1.435(on the 10.66 run)
1.456
1.436
1.440
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on September 1st, 2015 at 08:16 AM |
1/8 mile data:
6.849 @ 99.30
7.331 @ 92.67 lean and missed 3rd.
6.770 @ 100.26 (on the 10.66 run at 126mph)
6.953 @ 97.26
6.856 @ 98.77
6.796 @ 99.63
Quote: | Originally
posted by westi
That's mad Alan.
mactaylor
posted on September 1st, 2015 at 08:40 AM |
very cool dave! Hate it when your hand slips off your Knob!
1800 552 123
debiasi4
Threads: 51
posted on September 1st, 2015 at 09:00 AM |
I'd be pretty happy with a 1.49 60 while still bogging!!
modnrod
Threads: 50
Mood: Old School Volksies!
posted on September 1st, 2015 at 12:24 PM |
Quote: | Originally
posted by mactaylor
Hee!hee!hee!
Good stuff Dave, Jamboree sounds like it was fun.
morgan
A.k.a.: morgan smith
Threads: 30
Mood: excited
posted on September 2nd, 2015 at 11:54 AM |
8400 luanches were awsome
mactaylor
posted on September 2nd, 2015 at 12:27 PM |
must be some footage around dave?
1800 552 123
choppa
Threads: 42
Mood: Itchy
posted on September 3rd, 2015 at 09:07 PM |
Hi Dave
Have you run those new axles
I would be keen to hear your opinion on the lack of sholders.
My aftermarket axles slide through the CVs and grind the stubs and the seals on the outputs. Yuk!
I am thinking of going back to stock axles and machined T2 inner CV races.
dangerous
Mood: 591
posted on September 4th, 2015 at 09:22 AM |
The lack of shoulders is a good design as far as 'point of failure',
but means you need to get the axle length correct.
If they hit the seals, they are too long.
Good thing with all that spline, you can shorten them and re-do the circlip groove.
Quote: | Originally
posted by westi
That's mad Alan.
dragvw2180
Threads: 33
posted on September 7th, 2015 at 10:10 PM |
Some great numbers Dave !
choppa
Threads: 42
Mood: Itchy
posted on September 10th, 2015 at 08:49 PM |
Yes I did shorten them and seems to have solved the problem (tho I havent looked in there for a while). I havent had a failure .
NUG637
Threads: 24
posted on September 10th, 2015 at 09:02 PM |
was awesome watching you flog it down the 1/4 at jumbo... i think i remember saying to you your launches were looking brutal
dangerous
Mood: 591
posted on September 11th, 2015 at 08:49 AM |
https://www.facebook.com/SiggyEichholzPhotography/photos/a.700135576786642.10...
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on September 11th, 2015 at 02:27 PM |
https://www.facebook.com/terry.dale.39/videos/10207489053242408/?pnref=story
Quote: | Originally
posted by westi
That's mad Alan.
mactaylor
posted on September 13th, 2015 at 06:50 AM |
Quote: | Originally
posted by dangerous
If I did not have the rugged good looks,
the only thing that would be left to help with my self esteem
would be my enormous genitals.
Just been re reading your stuff on gearbox mods and I read this and laughed so I had to share!
1800 552 123
STOCK
Threads: 12
Mood: OK
posted on September 29th, 2015 at 07:31 AM |
Nice sixty footer times , Alan.
Super consistent!
Warwick should be awesome!
STOCK
dangerous
Mood: 591
posted on October 15th, 2015 at 05:11 PM |
Been a bit slow updating progress.
Warwick was excellent as usual,
and despite major carnage on the Sunday, (see below) I had some great results on Saturday.
After Jambo, but before Warwick,
I decided to fast track a change to the fuel system,
in an effort to solve a tank/supply issue that I had.
I added some more tank volume to act as a sump within the fuel tank,
and changed to a smaller pump and nozzles.
My old pump was tired, and drew 3 times the fuel (at high rpm) from the tank, than was needed at the engine,
and so put a lot of demand on the line, and tank volume at high rpm.
I also reduced the nozzle size, and increased the fuel pressure in an effort to improve lower rpm atomisation.
I flowed the OLD fuel system, as it had been run, and gathered fuel volume data at 5000 and 8000rpm.
I then chose the smaller nozzles, and pills and adjusted pressures to get the same volumes, so now the system pressure is over 100psi,
instead of around 60 with the old setup.
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on October 15th, 2015 at 05:22 PM |
I had no time to test, or dyno before hand,
and with my 1/8 mile gearing installed (1.33 3rd gear and 4.86 diff:100mph at 8400rpm),
it was time for Warwick!
Must have gotten the fuel system pretty close
because off the trailer it went 6.88 @ 100.13mph hard on the rev limiter,
on what was a pretty untidy pass. (1.497 sixty)
I had never run better than 99.70mph at Warwick, even when the car was 50lbs lighter!
Each pass from then on,
I leaned off the engine and snuck up the rev limiter to run the following:
6.762 @ 100.53 (1.455)
6.761 @ 101.53 (1.471 not enough launch rpm)
6.723 @ 101.98 (1.446 - 8000 launch)
The last run is, by far, a PB at any track altitude, so showed a lot of promise.
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on October 15th, 2015 at 05:27 PM |
Three out of the 4 runs on Sunday had ET's and MPH better than the 10.66 from Jambo.
Unfortunately on Sunday things started to get sad.
My guess is that the sump capacity could not stay with the 8600rpm that I was using,
(way too much for a 91.5mm stroke anyhow!),
and after a slow first round 7.01 at 96.56mph,
the engine let go in the second round at the finish line.
Here is the rpm when it let go:
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on October 15th, 2015 at 05:32 PM |
Hind sight is wonderful.
But the end result was that the sump capacity is just not enough for my application,
so its time to go for a dry sump system.
Enough rambling, here are the carnage photos:
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on October 15th, 2015 at 05:33 PM |
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on October 15th, 2015 at 05:43 PM |
Quote: | Originally
posted by westi
That's mad Alan.
coletrickle
Threads: 34
posted on October 15th, 2015 at 05:50 PM |
Awesome and sad all at once!
dangerous
Mood: 591
posted on October 15th, 2015 at 06:41 PM |
The bump spot this year for the Top 10 was my 6.72, so it was the fastest field ever! :O
I was THE ONLY NORMALLY ASPIRATED CAR in the top 10 line up!
Quote: | Originally
posted by westi
That's mad Alan.
tayloredvw
Threads: 39
Mood: make love not war
posted on October 15th, 2015 at 08:10 PM |
oh man!! Thats a bummer.
