[ Total Views: 114965 | Total Replies: 1280 | Thread Id: 60666 ] |
Pages: 1 .. 40 41 42 43 |
gerggl
Threads: 33
Mood: It is what it is !
posted on June 29th, 2011 at 09:36 AM |
Great job ..I am looking at doing some minor strengthening for my car ...especially for the centre pillar .....some engineering and fabrication will
be in progress shortly ...can give you an idea of what I propose to do if you are interested!
This looks awesome!
Greg Gordon-Lane
Brisbane
Vw's are part of life's journey .... get on board!
VW Safari / Thing 1976 - "A work in progress"
Ducati St4s - "Poetry in motion"
westi
what the
Threads: 28
Mood: not blue, pink
posted on June 29th, 2011 at 12:01 PM |
awsome stuff dave.
i was gona go 5.300 11/32 2.0 inlt 1.625 ex 250'from top step groove.
i will start looking up some more stuff.
what about studs.
i am only going to use 4 per barrel for now.
down sharon.
dangerous
Mood: 591
posted on June 29th, 2011 at 07:09 PM |
Yeah the ones in my heads are 5.35 long.
But that is with a different rocker system.
http://www.cvproducts.com/ProdDet.aspx?PN=XIV2150-5340-3412-R
If you don't want to spring for autocraft studs,
you can use VW 10mm studs.
They come in many lengths from 36hp right up to 1600,
so you should be able to find some the right length.
Have some covers for you courtesy of Ross Freestone!
Quote: | Originally
posted by westi
That's mad Alan.
essex
posted on June 29th, 2011 at 07:32 PM |
Hi Dave, you mentioned not using lash caps earlier, provided valve length is good, is that OK with all motors or just Westi's engine build?
dangerous
Mood: 591
posted on June 29th, 2011 at 08:43 PM |
Quote: | Originally
posted by essex
Hi Barry,
if the valve stem has a hard tip,
and the geometry is such that the 'wipe' is small,
you can leave the lash caps out.
Most titanium valves come with hard tips, so this is best when using a roller tipped rocker.
Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
posted on July 1st, 2011 at 12:14 AM |
thank's for the link dave.how cheap is the ti.
that's unreal.at those prices i could afford to have a spare set of head's set up.lol
i had already paid for the cover's buy the time i read the post,but thank's for the offer.
as for the stud's i will dumby up the engine next week sometime .i don't mind buying autocraft's.i jumped in the deep end so i may as well go the
whole way and buy what ever it need's.
dangerous ,how did you come up with the math's to get the srping pressures so high.is it the lift,rpm,duration or abit of everything.
i would like to know if you don't mind sharing.
down sharon.
dangerous
Mood: 591
posted on July 1st, 2011 at 05:22 AM |
No real maths to my choice of springs!
My old set up with the Pauter heads was pretty sweet with the 9935 Isky endurance springs,
and so, with the increase in lift by stepping up to a 1.7 rocker, I knew that I would want another 100 or so lbs.
Roger Crawford told me to use the Manley's that I went for.
I have since tracked down a PSI spring that is a couple hundred LBS less, that may have been a better choice,
but for now I will see how these things go being that they cost me so much!
My gut feeling was that I did not need that much tension,
but he said that more is better,
and I will be able to "set and forget" for a whole years racing.
My old set up was limited to 8400 rpm, and had .687" lift cold.
The new set up has only .710" cold and I would like to be able to use 8600 rpm if I need to,
but not too keen on doing that at this stage.
With these things shimmed right up Roger uses over .800 lift and over 10,000 reliably.
Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
posted on July 1st, 2011 at 09:47 AM |
far out ,that's nut.thank's for sharing mate.
i'll give you a ring when i nut out these heads alittle more.
down sharon.
westi
what the
Threads: 28
posted on July 7th, 2011 at 11:02 PM |
still waiting for part's to arrive,man waiting suck's.
what size is rodger's engine.
down sharon.
dangerous
Mood: 591
posted on July 8th, 2011 at 05:43 AM |
Quote: | Originally
posted by westi
2497cc.
96.7 bore and 85 stroke.
Look at 1.35 mins:
http://www.youtube.com/watch?v=AkxHveFeSi4
Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
posted on July 10th, 2011 at 12:07 AM |
That's cool
Cheers Dave.
Man that thing is awsome
down sharon.
westi
what the
Threads: 28
posted on August 4th, 2011 at 06:43 PM |
Finally got my bits today so I will post up some pic's as soon as I can.
Got some new additions for some more pony's.
I can't wait.
down sharon.
westi
what the
Threads: 28
posted on February 5th, 2012 at 10:36 PM |
Ok sharing time.please.If you want to I guess.
I have bought alot of new parts and have gone over all the old.
What cranks is everyone using.in there different set ups and what bearings are being used.
And a hp figure for what you have.
The reason for asking is all about oiling.
Grooved bearing v's flat. And how is the crank oiling holes drilled.
Just finally nutting out the junka's short falls and hopefully helping others.
Oh and if I get a chance I will take some pic's.
Cheers guy's
down sharon.
dangerous
Mood: 591
posted on February 7th, 2012 at 08:44 AM |
Most the Chinese cranks have an oil hole system that is copied from the German Okrasa....copied badly.
This issue CAN be addressed, since it is to do with the position of the oil holes in the FW main journal.
In most cases the index between these holes still worked with the later non grooved bearing, but
Okrasa did theirs when the KS and VW bearings were fully grooved internally,
so if you can find some grooved bearings, that will help.
The oil holes are also in error in an axial plane on Chinese cranks,
so the oil groove in the bearing may need to be widened with those cranks.
Chinese flanged cranks are excellent value,
but about half the price of the next best, which i think is the Scat.
I think the Scat oil hole system is the best,
but newer cranks from them, have reduced the number of oil holes, and made them larger.
This is not ideal, since cracks can appear, over time, from the oil holes,
but this is long term,
and I still think the Scat crank is a step up from the China ones even though some Scat cranks are Chinese, well, the forgings are anyway..
The next rung up are the cranks from Pauter, Roger Crawford or VW Paradise.(Sonny Bryant).
These are in the price range of $2500 to 3000.
I think all flanged cranks should use split shell bearings and a separate thrust that uses decent oil supply.
This can be done with either VW centre main bearings, or BMW "adapter" bearings, and Toyota or bronze thrust washers...
depending on what journals you have.
Pauter cases use VW, Chrysler(for type 4 journal) or Ford351 main bearings, but the Chry/Ford do not fit the VW style cases.
Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
posted on February 7th, 2012 at 08:53 AM |
I should add that the reason the oil hole can be a problem,
particularly on the main journals,
is that if incorrectly positioned, it interupts the supply of oil to the rod bearings.
Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
posted on February 19th, 2012 at 08:20 AM |
Yeh thanks Dave.
Thanks for the info.as alway awesome amounts of knowledge .
That's were the conversation needed to be.
I never, after all these years with the same $250 Chinese combo.
Bothered to look or check, How sad is that. I was wondering if it had caught anyone else out .
Oh well we finally got her back together and running last night.with new temperary fillin engine.
Geez louise. It sounds tuff as nails.!
And snappy . gave me and the boys a shock how it doesn't sound any different to the old 2386.
Can't wait to have a crack at the drags.
down sharon.
dangerous
Mood: 591
posted on February 19th, 2012 at 12:20 PM |
Sounds Good Westi!
Some times those "interim" engines go pretty good.
"back in the day" that was my intentions with the 1775cc blower engine.
I used it to learn the ropes, and it ended up being better than the previous bad tune-2180.
It ultimately ran a 10.65 after about 100 runs, before finally upgrading to a stroker again.
With N2O the sky is the limit.
Bring it on!
Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
posted on October 8th, 2012 at 07:41 PM |
finally going to get back into the swing of things,
got the thing almost sorted after way to many sleepless nights,got some good fuel organized.
got her sitting on the dyno ready for some testing.
school holidays have finally finished so if all goes well should have some starting numbers to play with before we change it back to injection ,then a
quick re-wire as it's starting to get alittle messy,time to tidy it all up ,
all then hopefully some machining on the bigger engine.
dangerous has my block getting it ready for the new crank and then away we go.
so i will get the fat man to post up some pic's.no sqirells here.
i am keeping busy with someones heads,so don't worry i haven't forgotten you.lol
it was great seeing you all again ,it's been to long between drinks for the junka,and it's time to get motivated again.cya
down sharon.
dangerous
Mood: 591
posted on October 8th, 2012 at 07:56 PM |
Send those thru bolts for your case dude!
Will PM my address.
Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
posted on October 8th, 2012 at 08:02 PM |
got it
down sharon.
Stanley
Threads: 270
posted on October 8th, 2012 at 08:13 PM |
Good to see the fires back Westi. I always thought Warwick was a long drive just to do a service on your car.
Look forward to seeing the wheels in the air soon.
westi
what the
Threads: 28
posted on October 14th, 2012 at 06:04 PM |
It never ends,there is always some shitty reason why you can,t work on ya car,
First excuse.last weekend wedding anniversary .10 year.
Second excuse. Lost a worker ( my main man) just had his first child,happy and health.
I am gona have to get struck buy lightening to miss next week,
down sharon.
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on October 14th, 2012 at 06:46 PM |
I hear ya ... 2 days for work and a 5 day weekend would help
Thanks for working on mine
westi
what the
Threads: 28
posted on October 15th, 2012 at 08:57 AM |
had to start sooner or later.
2 day week sounds mad.if only.lol
down sharon.
dangerous
Mood: 591
posted on October 15th, 2012 at 09:23 AM |
Quote: | Originally
posted by dangerous
Will PM my address.
Forget the bolts, job is done.
How do you want to collect it?
Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
posted on October 15th, 2012 at 03:58 PM |
sweet.
down sharon.
westi
what the
Threads: 28
posted on October 17th, 2012 at 06:36 PM |
got a point to prove now,got the team organized for friday's for work on the junka night,can't wait.
lighter, fast, stronger,it's the 6million dollar man(junka)stone cold steve austin.
down sharon.
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on October 17th, 2012 at 07:25 PM |
How'd you go with the bus Brad? I was hoping no news was good news
westi
what the
Threads: 28
posted on October 18th, 2012 at 12:53 AM |
waiting for a cable,i didn't have the right one for this ecu.
definatley a temp thing though,won't do it under normal idle or light driving.
a bov will heap the rev's to come done quicker under free rev's,but not realy a concern.
one of the fuel pump's is werring,which he said has only just apeared(noise wise).
but i don't think it will be anything mayjor set up wise,it's gona be a sensor setting in the ecu .
i should hopefully get the cable tommorrow.
what a car though all great job with everything,looks much better in person.
i'll keep you posted.
down sharon.
westi
what the
Threads: 28
posted on October 19th, 2012 at 10:08 PM |
1200 pounds anyone.hahaha.
hitting it hard tonigh.helps when you have a few freinds helping.
why ohh why do we do these things.
down sharon.
