[ Total Views: 135272 | Total Replies: 1114 | Thread Id: 67327 ] |
Pages: 1 2 3 4 5 6 .. 38 |
dangerous
Mood: 591
posted on November 28th, 2009 at 07:47 PM |
Sounds good Simon.
Gee that is a really small restricion in your supply line....it makes sense though, that the ball bearing deals need very little oil flow.
Sounds like you are heading in the right direction.
Look forward to hearing what you do with the jetting.
Quote: | Originally
posted by westi
That's mad Alan.
humpty
Threads: 139
Mood: Totally boosted!
posted on November 28th, 2009 at 10:39 PM |
Cheers Dave... After having seen so many fast turbo cars come out of the Hellbug Garage all those years ago, it feels good to have finally built
something like this.... Not that my other performance projects haven't been fun, it's just that I have always wanted to build a car like this....
The full tilt turbo efi stroker is still in the works, but this little draw-through 'mouse motor' has been a massive learning curve...
As you say, the carb will be a challenge.... This carb was on one of Nick's previous cars I believe... Not sure to what level it has been developed,
but hopefully he can shed some light on it... If it proves to be a hassle, it's not too much of stretch for me to fit efi...
Now comes the challenge to make it work....
seagull
Threads: 752
posted on November 28th, 2009 at 11:50 PM |
Bring it on Humty
You up to running the liberty down the 1/4 yet ?
I hear the street was full of smoke down your way
humpty
Threads: 139
posted on November 29th, 2009 at 12:11 AM |
Your right, there was plenty of smoke, but not in a good way.... Will be chucking it down the quarter in the new year... Got a lot of tuning and
learning to do before then.... But when I do, you be sure to bring your Subi buddies!
matberry
posted on November 29th, 2009 at 01:11 PM |
Give em heaps Humpty.
Good to turn the wheels hey....
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on November 29th, 2009 at 01:33 PM |
Nice work man. It is always a good feeling to finally get the thing started and it makes all the right noises even with a few small glitches. Ask Troy
he can sympathise with you on the smoke issue and small drama's!! He had plenty of them but the end result is well worth the effort...
humpty
Threads: 139
posted on November 29th, 2009 at 09:55 PM |
Cheers for the comments guys.... Tomorrow the engine comes out and I'll tear into pulling the intake and exhaust off.... Will draw file the exhaust
flanges in an attempt to fix the exhaust leaks... I have scored some CB graphite exhaust gaskets to use in place of the WBX ones I have at the
moment... Also gonna have a go at the pinhole leak in the top of the 'T' manifold.... And another thing.... That bloody front seal is leaking
again!!!!... Been having a real bad run with those of late... I've been using Elring FW seals for years, but for some reason I can't get a nice seal
up front????
Gonna drop the rear of the car too.... Just for the show you understand... Will source some more suitable rear rubber in the new year... Anyone have
some 26" slicks they want to part with?
reub
VWRX is gone...
posted on November 29th, 2009 at 11:00 PM |
...and you call me a nut bag...
Reub
humpty
Threads: 139
posted on November 30th, 2009 at 12:38 AM |
Quote: | Originally
posted by reub-revhead
And I still have drum brakes!!!!
colonel mustard
Threads: 51
posted on November 30th, 2009 at 12:43 AM |
might be wise to upgrade those..'
Stanley
Threads: 270
posted on November 30th, 2009 at 06:51 AM |
Top stuff Simon....and welcome to forced induction.
look forward to some pics or even video.....
Boostn
Threads: 28
posted on November 30th, 2009 at 06:58 PM |
Hey Simon,
sounds good.
did you get the pm?
give me an e-mail
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
dangerous
Mood: 591
posted on November 30th, 2009 at 08:43 PM |
Happy Birthday Simon!
Quote: | Originally
posted by westi
That's mad Alan.
humpty
Threads: 139
posted on December 1st, 2009 at 12:43 AM |
Haha.... Cheers Dave.... For a present for myself I pulled the engine from the car tonight!... Gonna fix those leaky exhaust flanges tomorrow and seal
the pinhole in the intake 'T'....
Fun times....
PM sent Nick.
humpty
Threads: 139
posted on December 3rd, 2009 at 01:06 AM |
Got a bit more done these past two days.... Chasing the leaks in the intake and exhaust.... Pulled the engine once more... Tore it all off.... Began
draw-filing all the flanges yesterday.... RPITA!!! :shock:
Took the 'T' intake and complete exhaust to work today.... Re brazed the manifold and fabricated and brazed a new/larger MAP port on the intake, and
linished all the flanges flat.... Gotta love industrial belt sanding tables!.... A whole lot ezr than draw-filing!!... Made two new cable clamps to
connect the two accelerator cables... The last one was pain to fit...
Got home at 4.30.... Fitted one of the versions on.... Works a treat... Fitted up the complete the intake and exhaust systems and used all new
hand-made gaskets and those fancy exhaust gaskets I got from one of the 'Collective'.... Re-fitted the engine and hooked it all up....
Turned the key at 7pm tonight.... Sounds much better.... Lovely note!
Noticed a few problems still....
The oil is still leaking a little from the turbo.... Fitted another restrictor at the top banjo fitting.... That's three restrictors now... The
factory one (1.5mm) in the turbo cartridge, one in the top banjo (.8mm), and one (.5mm) at the main oil gallery..... Are turbo's assembled with any
sealant on the mating surfaces?.... Carb is running way off.... Doesn't seem to be running on idle circuits... And it's seems to be flooding fuel
(cheers for the tips Nick).... I think the floats are set incorrectly... And the accelerator pedal/linkage is cactus... Gonna rip the pedal off and
make a roller pedal up using a skateboard wheel and tweak the cable support on the carb base... The cable seems to be binding a little....
Getting there....
humpty
Threads: 139
posted on December 3rd, 2009 at 11:51 PM |
Its all but done....
http://www.youtube.com/watch?v=e-58dK5FQLY
reub
VWRX is gone...
posted on December 4th, 2009 at 01:23 AM |
Nice work dude.
Reub
humpty
Threads: 139
posted on December 4th, 2009 at 09:17 AM |
Cheers Reub.... I'm pretty stoked with it.... I can't believe how well it all fits.... Only one thing didn't work out as planned... The waste gate
actuator just touches the closed engine lid!!!!!.... So I'll make up a lower engine cover prop to make it work.... Better for cooling anyway....
colonel mustard
Threads: 51
posted on December 4th, 2009 at 10:54 AM |
nice video. good to see it running good work mate!
Boostn
Threads: 28
posted on December 4th, 2009 at 02:01 PM |
Awesome going dude!?!?!?!?!?!
Memories, I feel young again.
Video of a spin inside please. 15+ psi please
VOLLKOMMEN ART
Speed and Style
humpty
Threads: 139
posted on December 4th, 2009 at 05:42 PM |
Big thanks to you Nick.... I really appreciate the help you have given me.... Not to mention the inspiration... I first realised I wanted to build a
car like this when I saw those pics of your old blue bug picking up its wheels in Fast Fours (I think it was Fast Fours?)... Then I got to hang out at
Hellbug back in the day.... There was no hope after that!!!
Some fun video will surely make its way to youtube once I get a handle on the old girl... Stay tuned!
reub
VWRX is gone...
posted on December 4th, 2009 at 06:41 PM |
Will have to come and have a looksie - at this stage I'm in Perth the week of the 18th Jan...
Reub
humpty
Threads: 139
posted on December 4th, 2009 at 07:26 PM |
Quote: | Originally
posted by reub
More than welcome Reub.... I'll be here.... Prolly prep'ing for Portland!!!!
Maybe...
humpty
Threads: 139
posted on December 10th, 2009 at 09:48 PM |
Today was the big day.... I took the car to school (Im a high school teacher for those that didn't know) and the machine went pretty well.... It
really does run better when it warms up.... Has a stutter when its cold.... Sorta like a rev limiter but at around 2200prm... No clue what rpm yet as
my laptop has a crook battery and I haven't got a tacho yet.... But once the POS warms up the stutter is all but gone.... It is running a little on
the rich side, so have ordered a range of main jets... I think the stutter could also be because of the slightly rich mixture....
Also.... It starts fine, and idles well.... The idle problems I had before were mostly down to a very tight accelerator cable/linkage.... And possibly
because it was all little dry and tight from lack of use.... All good there now....
Now for the ignition.... Still not sure how it is going.... As I haven't been able to do any data logging, I really have no clue if the map is even
close.... I based mine on a map I found on the Autosportlabs Forum, but I reduced the initial a little... I know this is all a bit dangerous since I
haven't done any logging, but what sort of things should I be aiming for when it comes to load v rpm?... Currently the 500rpm stage is set at 8, 600
at 9, 800 from 11 to 15, 1000 9 to 18 etc.... That last one looks a little odd to me... 9 seems wrong given that at 800rpm, the advance is at 11 for
load point 10 and 20... I'm prolly not making myself clear here, but I hope you guys can steer me right....
In closing.... It's got some poke!
Turbo54
Mood: Boost'n
posted on December 11th, 2009 at 08:38 AM |
What size is the exhaust? Is it loud when you open it up?
Cool trigger. I have seen a similar thing off a new FG Falcon mated to VW stuff.
Very Cool.
T54
C'mon kids gather round,
fish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
posted on December 11th, 2009 at 09:08 AM |
awesome work Simon, glad to see all the gremlins sorted, I've decided to use a locked out Magneto with some semi hemi heads, will do some work over
the break.
where's the in car video mate?
humpty
Threads: 139
posted on December 11th, 2009 at 09:28 AM |
Hahhaa.... Cheers guys.....
The exhaust primaries are 1 5/8 merging into a much modified 2.5" collector.... The dump and muffler is 3" all the way.... Its pretty tame and mello
at idle and cruising, but it does have a nice note when the revs come up... So I've been told.... I don't know for sure what it actually sounds
like, cause I'm driving, there's no interior and the drivetrain is solid mounted!!!! As for the ignition... It is in fact a Ford item (US/Europe
80-90's Escorts).... Some Oz spec Fords used a similar system.... As far as I can tell, only the timing wheel and the VR sensor are the same.... All
the other parts need to be source OS.... You can get the complete EDIS4 system used on ebay for less than 100bux!!!!.... The brain that drives it is
Megajolt unit that I bought in kit form.... Its an awesome little project by itself!.... And the spark is amazing!
And don't worry Fish.... As soon as I get a handle on the tune, I will be posting another flick on the tube.
Turbo54
Mood: Boost'n
posted on December 11th, 2009 at 02:39 PM |
So are you still running a dizzy just for advance? I want to run no dizzy and use this for the timing.
T54
humpty
Threads: 139
posted on December 11th, 2009 at 06:17 PM |
Nope.... No dizzy..... The EDIS and Megajolt do everything....
humpty
Threads: 139
posted on January 14th, 2010 at 08:35 PM |
Wow its been a longtime since an update.... Loads has happened in these past weeks.... Got the POS going in late November.... Been having a blast ever
since.... Still got loads to do.... Working the tune, making changes and all that stuff..... But here's a little vid of the start up....
Got it all together just in time for the DoVW-WA.... Had over 20 VW's turn up at my place for the drive out to the show.... Here's a video I made of
the day....
http://www.youtube.com/watch?v=r2fNuNFrDo0
As I said earlier.... The tune is way off, but it getting ever closer.... The ignition is awesome... The car starts so easily it amazing!!!!...
Cruising is a little rough, which I think is down to a few things... too lean on the pump jets and way rich on the mains, and I'm pretty sure my
ignition map is not right.... To help with it all I have just bought one of these....
http://www.innovatemotorsports.com/products/db.php
Should be here in the next week or so...
And a new battery for the laptop.... So real datalogging can commence... Best guess tuning is not a good idea!!!
Still waiting on the jets and emulsion tubes (turbo modified)....
And then the fun will really start.....Slowly, slowly....
