[ Total Views: 243909 | Total Replies: 672 | Thread Id: 68967 ] |
Pages: 1 .. 13 14 15 16 17 .. 23 |
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on May 25th, 2012 at 11:07 AM |
Hope your running a scatter shield and a big nappy to catch all the bits hahahA
Stanley
Threads: 270
posted on June 29th, 2012 at 07:30 PM |
guess what i'm doing this weekend
Error |
essex
posted on June 29th, 2012 at 08:28 PM |
Looks like your well sorted here Andrew,
Youve got those etra days too, your going to need fuel by then!
humpty
Threads: 139
Mood: Totally boosted!
posted on June 29th, 2012 at 09:13 PM |
Fun times ahead!
20bkombi
Threads: 26
posted on June 30th, 2012 at 07:58 AM |
Walk in the park for you stanly, hope there's no interruptions
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on June 30th, 2012 at 11:41 AM |
Look's like a great weekend
Stanley
Threads: 270
posted on June 30th, 2012 at 07:29 PM |
A good day....well afternoon
Error |
20bkombi
Threads: 26
posted on June 30th, 2012 at 10:15 PM |
Getting closer, have to book in a dyno very soon
Ph 0402 233 027
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
posted on July 2nd, 2012 at 07:29 PM |
Same engine size or bigger? Looking good!
Stanley
Threads: 270
posted on July 3rd, 2012 at 04:44 PM |
Quote: | Originally
posted by typethreeking
1915
Meant to post a pic yesterday. Just need a fan housing and I can finish assy.
I must admit the thought of running without a fan housing crossed my mind
Error |
typethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on July 3rd, 2012 at 06:13 PM |
1916baja
Threads: 176
posted on July 3rd, 2012 at 06:48 PM |
They look tough like that! Mine got pretty hot in sydney with the fan so i'd imagine the no fan option wouldn't be such a good idea
Stanley
Threads: 270
posted on July 3rd, 2012 at 07:44 PM |
Yeh I could imagine. Will definately be running a fan. Just like the look without it
typethreeking
A.k.a.: TROY ALDER
Threads: 9
posted on July 3rd, 2012 at 07:53 PM |
What fuel are you going to run, if you use methanol you could get away without the fan, bit more power without it.
Stanley
Threads: 270
posted on July 3rd, 2012 at 08:14 PM |
Will run pump gas. I thought about methanol but carbs have too smaller bowls.
1916baja
Threads: 176
posted on July 3rd, 2012 at 08:23 PM |
Any reason you decided to give n/a a shot? Just something different?
Stanley
Threads: 270
posted on July 3rd, 2012 at 08:42 PM |
All motor at the jambo
humpty
Threads: 139
posted on July 3rd, 2012 at 09:39 PM |
That looks tough as Andrew.....
westi
what the
Threads: 28
Mood: not blue, pink
posted on July 4th, 2012 at 01:18 AM |
cool another aspo car.better pull my finger out.
gona give it a run on the dyno when your done stanley.
down sharon.
humpty
Threads: 139
posted on July 4th, 2012 at 10:02 AM |
Quote: | Originally
posted by westi
Yes Brad..... I came all the way from Perth to see your car at Sydney, and you didn't run.... Better disappoint me again sucka!
whathaveidone
Threads: 98
Mood: Heading for 10.99
posted on July 4th, 2012 at 11:15 AM |
does that mean your comming humpty?????
essex
posted on July 4th, 2012 at 12:10 PM |
sounds like he is!
20bkombi
Threads: 26
posted on July 4th, 2012 at 02:11 PM |
Nice one!!! When does it go in and fire up?
Ph 0402 233 027
Stanley
Threads: 270
posted on July 4th, 2012 at 08:10 PM |
Quote: | Originally
posted by westi
I'd love to but depends on time and money.
Be a few weeks before start up. Gotta get my sons slant six running this weekend ready for Mopar Sunday and still need a fan housing.
Stanley
Threads: 270
posted on August 8th, 2012 at 06:41 AM |
Good news is the engine is in and running well.
Bad news is I have an oil leak from around the area of the top LH stud on the oil pump which looks to be coming out between the pump flange and case.
Doesn't start until oil (or case) warms up.
Pulled the pump and resealed with Loctite 518 and fitted a new cover gasket thinking oil was travelling down the stud. Still leaks.
I'm going to pull it again and have a good look to make sure there is no crack around the stud in the case. If it's ok i'll fit the pump from the
turbo motor to eliminate the pump.
Question....bought a pump puller but with the plug in the gallery the rod wont engage in the hole. Anyone have any tricks for pulling the pump other
than scrapers and screwdrivers. Don't want to damage any sealing faces.
thanks
humpty
Threads: 139
posted on August 8th, 2012 at 08:18 PM |
That's a bummer..... I made my own oil pump puller twenty years ago.... Fits perfectly.... Maybe you can mod the one you have to fit better?
Stanley
Threads: 270
posted on August 8th, 2012 at 08:42 PM |
It's an empi and broke first go so will need modding anyway
Stanley
Threads: 270
posted on August 10th, 2012 at 07:07 PM |
Well it appears leak has been fixed. What first appeared to be a crack running from pressure port in case ended up being a score from the plug in the
pump outlet created when pump was installed. Some careful blending seems to have sorted it. I still have one finger crossed though.
Just need to refit a decklid and hopefully a tnt in the coming weeks.
1916baja
Threads: 176
posted on August 10th, 2012 at 07:23 PM |
Got any pics of the na in there?
Stanley
Threads: 270
posted on August 13th, 2012 at 08:10 PM |
Yeh but it looks just like yours only faster.....
