[ Total Views: 243846 | Total Replies: 672 | Thread Id: 68967 ] |
Pages: 1 .. 16 17 18 19 20 .. 23 |
Stanley
Threads: 270
posted on December 20th, 2012 at 11:49 PM |
Since I've gone to the bigger catch can and even sucking in the gaskets haven't seen any oil in catch can. Sucking gaskets happens with NA engines
too which is why some chose to glue and weld tabs to prevent.
Only reason previous breather filled up was due to holes in pistons. I hope I'm passed that now with the Nissan pistons I'm running.
Stanley
Threads: 270
posted on January 4th, 2013 at 04:51 PM |
After my accelarator jammed on at Warwick I thought it was time to do a pedal upgrade as the old ones were showing their age with plenty of slop in
the shaft and bushes.
I got a late model set of pedals (thanks again Dave R) thinking they would pretty much go straight in. However after a trial fit I discovered that
apart from different mounts the hook for the clutch on the late set is offset 66mm. (sorry for blurry photos used my phone). Also had to modify the
pedal stop as well.
Only one thing to do....
While I was at it the cable hook was looking a bit worn.
so fixed this as well
so after it was all fixed I now have a good set of pedals that are also lighter than the old cast ones.
1916baja
Threads: 176
posted on January 4th, 2013 at 05:40 PM |
And they look like race pedals with the speed holes!
humpty
Threads: 139
Mood: Totally boosted!
posted on January 4th, 2013 at 06:43 PM |
DavoBuggy 1641
Threads: 12
Theme: UltimaBB Pro Orange
posted on January 4th, 2013 at 10:47 PM |
Your welcome Andrew, they look the goods in there. Glad to see them going to good use!
1916baja
Threads: 176
posted on January 4th, 2013 at 10:55 PM |
Quote: | Originally
posted by DavoBuggy 1641
go to bed knob!
dragvw2180
Threads: 33
posted on January 5th, 2013 at 12:14 AM |
Having never seen a right hand drive pedal assembly I was wondering how it mechanically looked , thanks for posting the pics. If it isn't too much
trouble can you post the throttle cable hookup ? Nice job by the way. Thanks, Mike McCarthy
Stanley
Threads: 270
posted on January 5th, 2013 at 02:08 PM |
No trouble at all Mike. It also has a cover which i don't have fitted.
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
posted on January 5th, 2013 at 07:23 PM |
Are you still using the old wire throtle cable ? They drag like crap and twist too , Stainles for me .
Stanley
Threads: 270
posted on January 5th, 2013 at 09:24 PM |
Never had an issue with it. Runs nice and smooth.
dragvw2180
Threads: 33
posted on January 6th, 2013 at 06:06 AM |
Thanks for the picture , pretty cool how it works. Usually I put a thin coat of teflon grease on the cable from the FORD dealer I worked at , very
slippery stuff. Mike McCarthy
Stanley
Threads: 270
posted on January 19th, 2013 at 08:17 PM |
Turbo engine back in and runing with a new fuel pump and some new fuel lines.
Minor issue with the advance on the mitsubishi dissy so might revert back to the 009.
TnT Wednesday night weather permitting.
westi
what the
Threads: 28
Mood: not blue, pink
posted on January 20th, 2013 at 07:27 AM |
Why change from the aspo big fella
down sharon.
Stanley
Threads: 270
posted on January 20th, 2013 at 07:33 AM |
Aspo engine is for Jambo. Still keen to see how much I can squeeze out of a 1641. I and other people have invested time into it so keen to see it
through.
I must admit i've enjoyed the aspo engine though.
dangerous
Mood: 591
posted on January 24th, 2013 at 08:40 AM |
Got that data on your spread sheet yet dude?
12's at 100mph is a great start, and no burnt holes or oil downs!!
Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
posted on January 24th, 2013 at 08:53 AM |
Why stop there dave. Up the boost baby.
Stan's got a back up engine.
down sharon.
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on January 24th, 2013 at 09:33 AM |
Quote: | Originally
posted by dangerous
So you got out last night to TnT ... well done
The magic 100??
Stanley
Threads: 270
posted on January 24th, 2013 at 12:07 PM |
Yep finally got the 100mph....just. Best time for the night was last run 12.99 @ 100.08mph (with next to no brakes). My fastest time but not best ET.
12.63 is PB with turbo engine. Had 3 other fairly consistant runs at 98ish mph.
Prior to going out I changed out the Mitsubishi dissy for a 009 because it was hard to start while trying to maintain 24deg full advance. The 009
cleared this up and I went for a conservative 22deg full advance. I had also backed the boost off a couple of PSI hence the lower ET. Had an issue
with a huge flat spot with the carb under load but seemed to clear with some revs. I'll fix this before Sydney.
Had 5 full passes (including the one where I missed 2nd) one with a good wheelie and no issues with rocker gaskets or oil in the catch tank. In Sydney
I'll turn the boost up a couple of PSI snd see he we go.
Thanks to DB and Pagey, Dave R and Mick for the encouragement.
Error |
humpty
Threads: 139
posted on January 24th, 2013 at 12:28 PM |
Wow Andrew.... I love the et's your getting with that lil' beastie..... That's great to see.... Really looking forward to seeing you run in Sydney
next month....
fish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
posted on January 24th, 2013 at 05:09 PM |
Andrew, got any vids of it running 1/4
FROSTY
Threads: 65
posted on January 24th, 2013 at 05:31 PM |
Bummer I missed it
essex
posted on January 24th, 2013 at 05:44 PM |
Good going Stanley, gotta be pleased
Any truth in a third engine?
westi
what the
Threads: 28
posted on January 24th, 2013 at 07:48 PM |
way to go stan.
now it's time to get greedy.
http://youtu.be/6oKqSLvbj0M
this thing is a machine.
go stan
down sharon.
Stanley
Threads: 270
posted on January 24th, 2013 at 08:05 PM |
Thanks all...Dave R had some vid of the wheelie run and some incar i think.
You've heard Barry....I just hope they have a 240 volt outlet at Warwick....
Thanks for the link westi....bit shiny though....mmmm nitrous.
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
posted on January 24th, 2013 at 11:16 PM |
1.7 60ft times look pretty nice too.... Any car running 12 s is fast in my books !
Turbo54
Mood: Boost'n
posted on January 25th, 2013 at 08:17 AM |
Well done Stanley, great times out of such a little motor.
T54
C'mon kids gather round,
Stanley
Threads: 270
posted on February 3rd, 2013 at 08:40 PM |
Put a kit through the Holley during the week to try and get rid of the flst spot off idle. Also adjusted the acc
elerator pump and seems to be better (sorry neighbours didn't go over 50).
Spent today modifying trailer to strenthen draw bar for Sydney drive and added a winch.
Stanley
Threads: 270
posted on June 2nd, 2013 at 08:24 PM |
Well with Sydney less than a month away the time has come to part ways with the turbo....so after Sydney, which will be the last run for the turbo
engine, the complete turbo system will be up for grabs.
Setup includes draw through T02 turbo, 600 Holley with custom manifold, intake, exhaust, boost gauge and spare wastegate actuator and some other bits
and pieces. NOTE....my engine is 8mm per side narrower than a stock motor so some tweaking of exhaust and intake would be required. Have a look back
at this thread and you'll see what you get. If anybody from Sydney in interested I'd be happy to unbolt it and leave it behind. Does not include
engine....
Thinking $500 for everything. Send me a pm if you're interested.
And for those interested the plans are to put the motor in my streeter with the IDFs and eventually fit some mechanical injection on the 2276
currently under construction. NA all the way
humpty
Threads: 139
posted on June 2nd, 2013 at 08:30 PM |
WHAT?
Stanley
Threads: 270
posted on June 2nd, 2013 at 08:31 PM |
