[ Total Views: 247182 | Total Replies: 672 | Thread Id: 68967 ] |
Pages: 1 .. 20 21 22 23 |
Performance Upholstery
Threads: 10
posted on January 14th, 2014 at 08:19 PM |
Sick
Cars, boat seats, furniture and more!
0439002870
performanceupholstery@live.com.au
Mt Gravatt east Qld.
essex
posted on January 14th, 2014 at 08:30 PM |
Not far off starting it up by the sound of it.
Motors looking the part.
Stanley
Threads: 270
posted on January 14th, 2014 at 09:10 PM |
Thanks guys...one thing I need to do is hook up the alternator. Can anyone tell me what needs to be done to get the alternator to work correctly.
Threads: 10
posted on January 14th, 2014 at 09:43 PM |
Take it to an auto electrician! Wiring sucks the big one .
0439002870
andrewmurphy
Threads: 22
posted on January 15th, 2014 at 05:58 AM |
What brand and model?
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on January 15th, 2014 at 08:56 AM |
Looking forward to hearing this fire up Andrew
dangerous
Mood: 591
posted on January 15th, 2014 at 10:26 AM |
Quote: | Originally
posted by Performance Upholstery
Nah, its just electric string!
Quote: | Originally
posted by westi
That's mad Alan.
Threads: 10
posted on January 15th, 2014 at 11:14 AM |
I've spent way to much time getting myself in trouble with wiring! The old Vw trick of putting a new loom on top of the old loom and leaving them
both connected gets me every time!
0439002870
modnrod
Threads: 50
Mood: Old School Volksies!
posted on January 15th, 2014 at 07:50 PM |
Trailer cable, fixed.
1 cable for the front of the car, 1 for the back, and 1 more for the engine. Jobs done. You still need fused battery feed for relays at each end, but
that's it really.
Mr Stanley, if your alternator is of the internal regulator "one wire" type (only has one single post on top, without another spot for a single
blade connector), then use battery cable (welding cable is good) to connect from that one connection bolt to your starter motor "large post", which
should be connected to your battery, then you're good to go and your alternator will then charge your battery fine.
nasty
A.k.a.: Michael Nash
Threads: 4
posted on January 15th, 2014 at 08:21 PM |
Quote: | Originally
posted by modnrod
that's it really.
Also you could add a self resetting circuit breaker (like the modern cars have) to protect from over current.
Some of the battery isolate switches have another terminal or pair of terminals so it disconnects the alternator before (i think it's before) the
battery disconnects.
Stanley
Threads: 270
posted on January 16th, 2014 at 06:35 AM |
Thanks guys....good info and much appreciated. Alt is from Suzuki swift and does have internal reg.
Stanley
Threads: 270
posted on January 25th, 2014 at 05:14 PM |
Managed to get engine fired up yesterday and ran pretty nice. Just minor things to do like throttle return springs and hook up cable for fuel shutoff
which has been moved since video. Special thanks to DB for guidance and help and Henry for the bits. And yes breather will be changed for something
more substantial.
Here is a short video. http://youtu.be/T37FR1dZJEM
Error |
vassy66T1
A.k.a.: Marcus Vass
posted on January 26th, 2014 at 07:55 AM |
Awesome!!
Love the old skool
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on January 26th, 2014 at 08:01 AM |
Sounds great
modnrod
Threads: 50
posted on January 26th, 2014 at 09:17 AM |
YEAH!!!
That's just cool as crap!
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
posted on January 26th, 2014 at 05:23 PM |
Gotta love the sound of an alcohol motor.....
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on January 28th, 2014 at 11:52 AM |
Quote: | Originally
posted by Doug Sweetman
I don't know about that!! I've heard Ben Robinson with a gut full of alcohol and it didn't sound pretty lol
Threads: 10
posted on January 28th, 2014 at 01:31 PM |
Oh, did you get that Australia Day phone call too brenndan?
0439002870
Stanley
Threads: 270
posted on February 16th, 2014 at 09:52 PM |
Results of TnT...only managed two runs on the night due to other peoples issues.
First run was easy take off through 1st and 2nd and nailed in 3rd to shift light at 6800rpm to make sure for one that belts stayed on but mostly to
check AF which was reading way rich. Next run was normal launch and run, although not the cleanest, to set a baseline for tuning. Next outing will
change the pill and hopefully crack the 11's. Mine is car 3.
Error |
andrewmurphy
Threads: 22
posted on February 17th, 2014 at 06:23 AM |
Nice mph
essex
posted on February 17th, 2014 at 05:02 PM |
Nice one Stanley, shame its not going to be at Sydney,
Stanley
Threads: 270
posted on February 17th, 2014 at 07:43 PM |
Thanks Andrew and Barry...I wanted to go to Sydney but needs a bit more tuning and a couple of small tidying up things.
Drained the oil yesterday and apart from the tell tale signs of methanol use all was good. Fuel system now cleaned waiting for next TnT.
Stanley
Threads: 270
posted on March 30th, 2014 at 08:34 PM |
Couple of minor changes since last outing mainly the new breather. Was set for a TnT Wednesday but wasn't happy with my brakes. So will fit a new
staging brake that works and fittings that don't leak. Hoping for the 9th.
Error |
Error |
andrewmurphy
Threads: 22
posted on March 31st, 2014 at 06:08 AM |
Nice
20bkombi
Threads: 26
posted on March 31st, 2014 at 06:25 AM |
Cool breather and very clean set up Andrew.
I love how basic it is.
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
Stanley
Threads: 270
posted on June 28th, 2014 at 08:29 PM |
I've had the gearbox out to have some new gears fitted by DB so decided to do an 1 1/4" trans raise. I also wanted to brace the frame horns which
meant adding a passenger side intrusion to stiffen up the cage for support. Also cut a lot of tin from the rear for clarance as well as some of the
parcel shelf where the box poked through. Pretty happy with the stance now, although this was only one of the reasons. Finally got it back on the
wheeks today.
Error |
Error |
Error |
vassy66T1
A.k.a.: Marcus Vass
posted on June 29th, 2014 at 07:51 PM |
Looking good !
humpty
Threads: 139
Mood: Totally boosted!
posted on June 30th, 2014 at 07:17 PM |
Nice work Andrew!
dangerous
Mood: 591
posted on August 1st, 2014 at 12:23 PM |
First 11's!
Sweet dude!
Quote: | Originally
posted by westi
That's mad Alan.
humpty
Threads: 139
posted on August 2nd, 2014 at 07:40 PM |
Woohoo!
