[ Total Views: 2186 | Total Replies: 52 | Thread Id: 72065 ] |
Pages: 1 2 |
jsheppard64
Threads: 19
Theme: UltimaBB Psyche Red
Mood: Akiba-Spec
posted on October 20th, 2008 at 08:43 PM |
I've replaced my ball joints along with sway bar rubbers i put nolothane stuffs in the steering is better but i think i need a steering box and a
good wheel alignment... also i changed my front springs i put erm springs out of the back of VS commodore in they're pretty good a bit stiff it's
pretty good on a flat road with tiny bumps or pot hole... handles a bit better as well..
and yes i'll go with the helical gear... although straight cut is very tempting... the price isn't
and one more question to you experts... should i go big valves head?? would they be worth the price?? i got quoted $550 for big valves head and $380
for standard opinion please
thank you
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on October 20th, 2008 at 09:15 PM |
Standard heads.
jsheppard64
Threads: 19
Mood: Akiba-Spec
posted on October 20th, 2008 at 10:03 PM |
that's what i thought and my budget supports that decision as well..
i bought another progressive manifold because it was like cheap so i grabbed it.. anyway the hole where heater pipe goes wasn't drilled thru... was
it meant to be blocked in the middle?? i mean there are holes on both sides just that the hole wasn't drilled thru... should i drill it thru so that
the exhaust gas would flow and actually dissipate some heat onto the manifold or should i just leave it?? and see if it would somehow miraculously
work
Joel
posted on October 21st, 2008 at 05:04 PM |
preheat will be fairly useless anyway but better than nothing
they never work like stock once u put headers on u only have to look at the design to see why
its probably a carbon blockage. thats what happens when u feed from 2 ends
if u just want straight cuts for the noise then get some cheap empi ones
generally its play in the gears where most of the noise comes from
quality gears are abit quieter cos they have closer tolerances
ive got scat straight cuts in mine, u can tell there straights but there not offensively loud
but beware cheap ones are cheap for a reason
even good ones can do this
Turbo54
Mood: Boost'n
posted on October 21st, 2008 at 06:18 PM |
you need to buy westi's turbo setup
C'mon kids gather round,
matberry
posted on October 21st, 2008 at 07:14 PM |
Quote: | Originally
posted by Joel
I dont think they would be called "good" or "quality" if they do that.
What backlash was set on those two lovely examples I wonder?
Joel
posted on October 21st, 2008 at 08:46 PM |
bottom were allegedly magnums
jsheppard64
Threads: 19
Mood: Akiba-Spec
posted on October 21st, 2008 at 09:09 PM |
i was going to make a bypass tube that doesn't go straight to the flange that connects to the muffler so that exhaust would actually flow is that a
good idea? and if i do that i would just drilled the manifold thru... it's a new manifold so it didn't have any carbon build up.. it just wasn't
drilled thru
jsheppard64
Threads: 19
Mood: Akiba-Spec
posted on October 22nd, 2008 at 09:24 PM |
i bought an aluminium cam gear yay
unfortunately mine was a dish type cam gear abd the one i bought is a flat type so the guy said 100 for a new oil pump and i replied "next pay" stupid low paying job
matberry
posted on October 22nd, 2008 at 09:46 PM |
Quote: | Originally
posted by Joel
Ok, did they have backlash??
Joel
posted on October 23rd, 2008 at 09:36 PM |
i got NFI
i just grabbed the pics from the same topic we having on thesamba to demonstrate what can happen
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on October 23rd, 2008 at 09:43 PM |
yeah thanx for that Joel..............NOT!.........that gear looks just like mine (without the warpage thank god)
previous magnum model had round holes around the edge and as such more meat to it........
jsheppard64
Threads: 19
Mood: Akiba-Spec
posted on October 23rd, 2008 at 10:35 PM |
i put the block together. torqued it up and everything
and then i realised i didn't put the cam followers in
hellbugged
A.k.a.: Daimo Pell
posted on October 23rd, 2008 at 10:38 PM |
Joel
posted on October 25th, 2008 at 04:20 PM |
dont worry ur not the first bloke to screw a bottom end together only to look over and see a lifter or cam bearing, something small and stupid still
sitting on the bench
matberry
posted on October 25th, 2008 at 05:54 PM |
Quote: | Originally
posted by Joel
i got NFI
My point exactly.
Not having a go at you Joel, but it just pi55es me off to here this is now good or whatever, when there are so many facts missing in such a
complicated issue.
No one knows except possibly the guy who broke it, what actually caused the faiure, and/or the specs at assembly... what backlash, end float, valve
spring pressure, rocker geometery, cam, spring harmonics, engine rpm............
jsheppard64
Threads: 19
Mood: Akiba-Spec
posted on October 25th, 2008 at 09:18 PM |
i was wondering what is the easy way to fix the built in rear camber?? out of superbug IRS i replaced the rubbers that helped a bit .....
and setting the torsion bar was a real pain
Joel
posted on October 25th, 2008 at 10:49 PM |
point taken mat, i was more trying to make the OP relise they do nothing in a stock engine
but anyway heres what happened to the one in the 2nd pic
"As far as the story goes, i lost a flywheel in the burn out box, and the sudden twist of the crankshaft when the flywheel let go smashed the gear,
resulting in some MAJOR damage to EVERYTHING but the case."
its a real PITA job to decamber a IRS
u gotta flip the trailing arms and weld the shock mounts back on the right way
most ppl just live with the camber all it does is wear ur tyres quicker
jsheppard64
Threads: 19
Mood: Akiba-Spec
posted on October 26th, 2008 at 11:36 PM |
i guess i'll just live with it then
hmm i wonder with the rear disc conversion how do u run handbrake? does it have to have separate hydraulic pump?
how much would the conversion cost?
matberry
posted on October 27th, 2008 at 08:22 AM |
Quote: | Originally
posted by Joel
Cool Joel, that does explain a few things....ahh knowledge.
You dont need to worry now Daimo, just keep the flywheel firmly attached, especially during burnouts.
Craig Torrens
Threads: 347
posted on October 27th, 2008 at 09:30 PM |
Quote: | Originally
posted by jsheppard64
Its actually very easy to adjust............if you know how.
I will PM my number to you to discuss.
Regards
Craig T
jsheppard64
Threads: 19
Mood: Akiba-Spec
posted on October 28th, 2008 at 08:20 PM |
let me guess....
something to do with trailing arms??
jsheppard64
Threads: 19
Mood: Akiba-Spec
posted on November 2nd, 2008 at 01:22 AM |
what's the best thing to use to seal the engine up??? a guy at vw garage told me to use hard setting Loctite engine sealand No 4 and my dad told me
to use standard vw compound which is softer. when i sealed the engine up for the first time forgot about the lifters i used loctite No 4.. i don't
want my car to make a mark everywhere it goes... altho that's normal with old VW
Pages: 1 2 |
