[ Total Views: 20179 | Total Replies: 232 | Thread Id: 74498 ] |
Pages: 1 2 3 4 5 .. 8 |
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on April 5th, 2009 at 12:32 PM |
Thanks Pete
The legacy of PC lives on (my ex-mates initials)!!!
You would think after all the s%$t that he managed to do I would have paid some attention to the work he had done?? My bad!! Same guy lost one half of a pair of twin 36dcnf webers, lost
untold numbers of bolts and parts and never completed the work he was paid for. No bitterness from me though (I am serious) as it is old water under
the bridge. It does crap me to have one last show of his stupidity, sloppiness and incompetence though. What a kn*b!
A good lesson though to make sure I pay careful attention to previous work and make sure it is correct. When I saw the posts from last night it only
took ten seconds of logic to know it was wrong. Oh well ... haven't had too much in the way of setbacks up till now so I'll suck it in and get on
with it
cnfabo
Threads: 140
posted on April 5th, 2009 at 01:46 PM |
so what engine combo have you decided to go for ??
vassy66T1
A.k.a.: Marcus Vass
posted on April 5th, 2009 at 02:05 PM |
Hi Chris
It will be a 1999cc. Am going for 94mm pistons (Mahles I have) with a 72mm stroke which will most likely be from a de-stroked 74mm crank. The crank I
don't have yet. The case will be an AS41 (already have) and the heads 043 (already have) that will be ported and fitted with 42 (or possibly 44mm)
intakes and 37mm exhaust. The cam is yet to be decided. Will be running on premium pump gas. The carbs are the 45 dellortos mentioned earlier in the
thread. I would like to do the porsche colling but budget may well tell the story for me there.
Cheers for asking. Takes my mind of the two steps forward and one step back.
cnfabo
Threads: 140
posted on April 5th, 2009 at 03:43 PM |
same crank and heads as me.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on April 5th, 2009 at 04:10 PM |
yeah, ive cut and turned those adjusters before........just did it a out little wider than they are originally.......damn dude , i noted it earlier in the thread and never got round to mentioning it,
until i saw last nights up date
quick steer on "hellnotch" is custom made and machined to re-align tie rod ends with the lowered front end ........there are off the shelf ones available which are a bit smaller so don't provide the "reduction"
that ours does....i'll send one up with the parts for you to work off
but for racing, i would rate this as a must do after experiencing the difference, almost considering it as a safety item for the control it gives back
to the driver.......it's no coincidence WRC drivers have to put very little input into the steering wheel to make BIG and constant corrections
extension block on steering pitman arm.....
BEST descriptions to find the cam you need for where you want to run your engine are here.......you can work out the equivelent in engle brand from
these lists..........
with out ratio rockers....
http://www.geneberg.com/cat.php?name=Camshaft%20only&cPath=2773
street/race cams with ratio rockers.....
http://www.geneberg.com/cat.php?cPath=6_166
BIG, race cams with ratio rockers........
http://www.geneberg.com/cat.php?name=All%20Cams%20Below%20Require:&cPath=167
full list from all companies here.........
http://www.actionimport.com/Tech_Files/cam_information.htm
555bug
WRX Bug Boy
Threads: 79
Theme: UltimaBB Vintage
Mood: turbo charged
posted on April 5th, 2009 at 07:01 PM |
any one details on the quick steer? if anyone has a bit of a ballpark sketch I have a mate with an cnc router.St
Stephen
vassy66T1
A.k.a.: Marcus Vass
posted on April 5th, 2009 at 07:46 PM |
Thanks Daimo for the info!
The gear to sort out quick steer will be excellent thanks.
Trev (my brother in law) will be down in your direction over easter so I am wondering if that may be a good time to get some gear or otherwise link up
with someones trip to Brisbane.
For the cam I am thinking we are somewhere around the K10 to Fk87. I am pretty sure the FK89 would be going too far for our uses but I could be
wrong.
Hey daimo, don't let Matt see those disc rotors ... he'll hate them
Turbo54
Mood: Boost'n
posted on April 6th, 2009 at 10:55 AM |
Hey Vassy,
Looking great. Good it is getting somewhere. Are you painting it silver?
T54
C'mon kids gather round,
vassy66T1
A.k.a.: Marcus Vass
posted on April 6th, 2009 at 03:50 PM |
Most likely not.
The exterior colour is still up in the air. I was settled on black for a long time, and from an aesthetic point of view I would still like it, but
after such a hot and long summer the idea of rivers of sweat in my eayes on the start line seems like a bad idea. (I think I must have been born with
twice the number of sweat glands to average )
So part of me wants to do it in an original oval colour (also hence the black) and the other half could go for anything.
It is nice to have the choice to make though.
Must have photos of a hundred beetles on my hard drive to try to help me make the choice.
Here is a few of my favouite samples.
I know I will be told I am a bit nuts for going for something 'pretty' in a race car but ... I don't care
I only have one oval and want it to be the way I will appreciate it (even if I bend and/or scratch it and have to repair it)
Turbo54
Mood: Boost'n
posted on April 6th, 2009 at 04:46 PM |
Check out the USA 54 factory colour called saturn silver, Like a dark matallic purple/ blue that sparkles into a brightish silver in the light.
I was going for it for a very lng time before I wrapped my head around something else. I would also consider something flat (non metallic) cause it is
a lot easier to touch up if you have a mishap.
T54
vassy66T1
A.k.a.: Marcus Vass
posted on April 6th, 2009 at 07:19 PM |
Thanks turbo54 I will have to check that out.
cnfabo
Threads: 140
posted on April 7th, 2009 at 10:07 AM |
daimo, this quick steer , does this give better steering response and better steering lock ?? if so where could i get one or maybe get a mock up to go
off.??
JVLRacing
Threads: 30
posted on April 7th, 2009 at 08:10 PM |
use escort rack
hellbugged
A.k.a.: Daimo Pell
posted on April 7th, 2009 at 08:14 PM |
Quote: | Originally
posted by JVLRacing
use escort rack
........for bumpsteer........or show cars
JVLRacing
Threads: 30
posted on April 7th, 2009 at 08:43 PM |
Quote: | Originally
posted by hellbugged
Quote: | Originally
posted by JVLRacing
use escort rack
| hhhmmmidiot
hellbugged
A.k.a.: Daimo Pell
posted on April 13th, 2009 at 05:57 PM |
modified spring plates.......
vassy66T1
A.k.a.: Marcus Vass
posted on April 14th, 2009 at 09:03 AM |
One metal holesaw coming up
matberry
posted on April 14th, 2009 at 11:04 PM |
You want to buy a good hole saw Marcus, them be pretty hard steel if using og spring plates. Note also the fastening holes have been enlarged.
cnfabo
Threads: 140
posted on April 14th, 2009 at 11:26 PM |
JVL, WHATS A ESCORT RACK ???
mactaylor
Mood: even my dog is german
posted on April 15th, 2009 at 04:15 AM |
use a slug cutter they are much nicer to use and will cut thru most things! any body got some adjusters lying around they want to sell me?
EVERLAST CONCRETE TANKS
1800 552 123
hellbugged
A.k.a.: Daimo Pell
posted on April 15th, 2009 at 07:52 AM |
Quote: | Originally
posted by chris fabian
ford escort........why would ya!
matberry
posted on April 15th, 2009 at 08:34 AM |
Quote: | Originally
posted by mactaylor
I can get em for you, pm or phone 0408 704 662
vassy66T1
A.k.a.: Marcus Vass
posted on April 15th, 2009 at 08:37 AM |
Hey Matt
Might take it to my sheetmetal friend for that attention.
Mactaylor I have a secondhand set of adjusters only fitted once upside down by someone I once knew
The only rack I am interested in isn't on an escort
matberry
posted on April 15th, 2009 at 08:41 AM |
Quote: | Originally
posted by vassy66T1
Hey Matt
| mmmm rack of lamb
JVLRacing
Threads: 30
posted on April 15th, 2009 at 11:11 PM |
| out of a escort car......
JVLRacing
Threads: 30
posted on April 15th, 2009 at 11:12 PM |
JVLRacing
Threads: 30
posted on April 15th, 2009 at 11:14 PM |
| looks like a pair of scissors used on them....hellodamo
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on April 18th, 2009 at 09:27 PM |
Just dont let the scutineers see the Quicksteer...........your're not supposed to use them !
Craig Torrens
Threads: 347
posted on April 18th, 2009 at 09:36 PM |
you should also grind the top of the shock towers back so when you run neg camber the tyres don't scrub....its also worth stitch welding the towers
as the spot welds tend to let go.
colonel mustard
Threads: 51
posted on April 18th, 2009 at 09:37 PM |
Fords are fords.... vw's are not fords...... YAY.
