[ Total Views: 20202 | Total Replies: 232 | Thread Id: 74498 ] |
Pages: 1 .. 3 4 5 6 7 8 |
cnfabo
Threads: 140
posted on March 12th, 2010 at 06:29 PM |
are those still the 043 heads marcus? and who did the work on them?
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on March 12th, 2010 at 06:45 PM |
Quote: | Originally
posted by cnfabo
they are 044 wedgeports.
Unless you are building an over 2lt stroker or a stock 1600 the 043 are not worth using.
cnfabo
Threads: 140
posted on March 12th, 2010 at 07:27 PM |
craig, can u explain why the 043 are not worth using on a 1916cc??
Craig Torrens
Threads: 347
posted on March 12th, 2010 at 07:42 PM |
because you can't machine the combustion chamber depth any lower to increase the compression ratio.
the 043 casting only goes down 3 fins deep, so you can only machine the head for "clean up", not to remove any material.
Whereas with an 040 head,the combustion area's casting goes down 4 fins deep.....so you have more "meat" to play with, which means you can remove
more to decrease cc's in the combustion chamber and therefore raise the compression.
The 044 heads are cast all the way down.
Because stroker motors usually have larger cc capacity (over 2lt) the combustion chamber doesn't need to have a lower cc capacity to raise the comp,
so 043's are good for that. And well 1600's are just low comp anyway !
The other negative with 043's is that they have a smaller exhaust valve than an 040, and the valve stem is 9mm (from memory) which are bloody hard to
buy when replacing!
Hope that answers your Q ?
cnfabo
Threads: 140
posted on March 13th, 2010 at 01:16 AM |
exactly what stan told me.. cheers craig....
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on March 13th, 2010 at 06:33 AM |
Yes the 043's have been put aside to go on the wife's 1600cc kombi engine.
They would have been stretched to their limit or beyond to do what I want.
vassy66T1
A.k.a.: Marcus Vass
posted on July 23rd, 2010 at 08:18 AM |
Well with study and other things (like two new motor and gearbox builds and installs for a couple of kombis) work has been only progressing slowly.
The body is however getting quite close now.
Below are some photos of where it is at. The fuel tank area had been bastardized by a previous owner (who also had a fetish for freakin fibreglass
) so a new front clip has been installed. Will still have to fabricate
and install the back edge of the fuel tank surround.
Firewall is almost ready to be replaced as you can see from unpicking below. The only thing that will leave will be the mod to have the rear apron
removable from the firewall back for engine access and easy in/out.
On the engine front, the Scat have finally delivered the custom crank that I ordered (and paid for) last October. It is a 72mm forged 4340 superlight,
knife edge counterweight crank with lightened journals.
It will be partnered with some re-furbished Carillos that passed all there tests with flying colours.
One of the next jobs is finishing off suspension including fitting front end adjusters, (the right way up) rear camber adjusters, and then making a
new pedal box/cluster.
A butchered oval fuel tank area
Another photo of the same
Firewall in need of replacing
Donor firewall almost unpicked
New front clip fitted
The body as it is now
oldskl60
Threads: 28
posted on July 23rd, 2010 at 09:16 AM |
You are a talented man Marcus! Great work
dangerous
Mood: 591
posted on July 23rd, 2010 at 07:40 PM |
Any pictures of the new crank Marcus?
What journals did you choose?
Quote: | Originally
posted by westi
That's mad Alan.
vassy66T1
A.k.a.: Marcus Vass
posted on July 24th, 2010 at 12:11 AM |
No pics yet Dave.
Matt is picking it up at Valla from Rodney.
Stuck with T1 journals I am fairly sure. (ignorant driver/owner talking)
matberry
posted on July 24th, 2010 at 11:37 AM |
Yep Marcus, T1 mains, VW big ends. Edit: whoops...type 4 center main
Good to see some progress on the body Marcus keep it up .
vassy66T1
A.k.a.: Marcus Vass
posted on August 20th, 2010 at 10:27 PM |
So a Scat counter weight knife edge crank (custom made/ordered) has arrived!!
The centre main journal is type 4 : my bad from last info Mr DB.
Thanks to Rod Penrose and Matt Berry for their part in this
Looks strong
dangerous
Mood: 591
posted on August 21st, 2010 at 05:30 AM |
Mmmmm!
Salubriuos crank!
Are you going dry sump Marcus?
Magnesium or aluminium case?
What is your planned completion date?
Quote: | Originally
posted by westi
That's mad Alan.
johny rotten
posted on August 21st, 2010 at 07:00 AM |
odd shaped counterweights
interesting hole drilling
vassy66T1
A.k.a.: Marcus Vass
posted on August 21st, 2010 at 08:04 AM |
Quote: | Originally
posted by dangerous
Mmmmm!
Salubriuos crank!
Hey Dave
Not going dry sump, just using a deep sump (size to be confirmed), a magnesium case (rules if read strictly would seem to indicate I need to have an
original "block" (the rules say block not case obviously) not an aftermarket and/or performance one). Rods are standard length Carillos with vw
journals.
Completion date .... hmmmm ; not this year I don't think. (If I talk down the finish does that mean it might happen sooner?) Early/mid next year is
realistic for time and money
johny rotten
posted on August 21st, 2010 at 08:38 AM |
what is the bore and stroke size
vassy66T1
A.k.a.: Marcus Vass
posted on August 21st, 2010 at 09:03 AM |
72mm stroke and 94mm bore = 1998.6cc
Under 2litre Improved production
DieSchnelleKafer
Threads: 22
Theme: UltimaBB Pro Brown
Mood: hungry for metal
posted on August 21st, 2010 at 06:08 PM |
hi, when you say you got the car sand blasted does that mean actual sand or some other mdeia like bead or soda? if not what did you use. both my doors
fenders W decklid and hood have been sanded back and over the years formed deep surface rust. what would you recommend?
cheers,
blair
oh by the way great build porn.. i mean pics. i wish my oval was coming along this quick
vassy66T1
A.k.a.: Marcus Vass
posted on September 27th, 2010 at 05:26 PM |
Hey Blair
Sorry I had only just noticed your post oops
I wish my oval was coming along quick ... I did have it sand blasted. The guys were reasonably careful. If you wanted to be sure then some media that
would heat the panels less would be advised.
I will go look for your thread now.
vassy66T1
A.k.a.: Marcus Vass
posted on January 13th, 2011 at 04:35 PM |
Well a little spare time and some funds have meant some progress on the Beetle. Not massive but positive nonetheless.
First pic is of a nice front end that has now been fitted with adjusters (right way up and in the right position )
Next pic is the shock towers trimmed and seam welded
The other pics are of the rear end going together with the type 3 bars in place and the camber adjusters
Bought some gear for the workshop (shed) which has made life easier and more things possible. A 20 ton press (just a baby), die grinder, vernier
calipers, SP tools spanner set 8mm to 19mm, dawn fabricated offset vice 5", and some other bits and pieces.
Hope to have it on its wheels with front sway bar in place by Saturday evening.
Aussie Dubbin
Threads: 90
posted on January 13th, 2011 at 05:04 PM |
Looking good
vassy66T1
A.k.a.: Marcus Vass
posted on January 14th, 2011 at 06:36 PM |
Cheers Aussie Dubbin
Down on its wheels today.
Most things went reasonably well.
The fitting kit for the front sway bar was in need of modifications.
All seems good. Front end feels quite compliant and the sway bar does its bit when you jump on just one side.
In the midst of making up the intermediate gear box mount at the minute.
Hydraulic handbrake is a cool solution for the rear discs for me.
Currently also making brake lines.
vassy66T1
A.k.a.: Marcus Vass
posted on January 15th, 2011 at 03:29 PM |
Last one for the moment
Finished off the intermediate gearbox mount. Lot of stuffing around for a little mount
Am starting on the pedal assembly next and will be going with a hydraulic clutch setup.
bat69
There is no status
Threads: 84
Mood: I'm EXCITED!
posted on January 15th, 2011 at 05:15 PM |
Looking good Marcus. Do you have an estimated completion date? That is a massive front bar. What size is it?
White Knuckle Racing Team
"Drive it like dirt"
Aussie Dubbin
Threads: 90
posted on January 15th, 2011 at 05:20 PM |
marcus where did you get that front bar? What is your recomendation bat69?
vassy66T1
A.k.a.: Marcus Vass
posted on January 15th, 2011 at 05:29 PM |
Front bar is a 22mm (I do have a 20mm front bar also in case I need to go down in size/stiffness. I think that will be likely)
The rear that I have is a 24mm. Am hoping for a balanced feel not too much oversteer. Time will tell.
I am hopeful for middle of the year now for the car to see the track. It is nice to see it get this far now.
Cheers for your interest.
matberry
posted on January 15th, 2011 at 10:55 PM |
Looking good Marcus
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on January 16th, 2011 at 07:01 AM |
66deluxe
Threads: 139
posted on January 16th, 2011 at 08:26 AM |
Looks great love the shocks and the handbrake
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
cnfabo
Threads: 140
posted on January 16th, 2011 at 12:59 PM |
hey,marcus, where did u purchase the hanbrake from ??
