[ Total Views: 66005 | Total Replies: 633 | Thread Id: 78092 ] |
Pages: 1 .. 15 16 17 18 19 .. 22 |
1303Steve
Threads: 556
posted on September 2nd, 2010 at 11:14 PM |
Hi Colonel
I sold them on eBay, the engineer wouldn't let me use them, I kept the accelerator pedal but.
STIDUB
Over it.
Threads: 57
posted on September 3rd, 2010 at 12:30 AM |
mustard - yes please, the more the merrier
boss dear, i made sure i turned it off before i left, cant afford to waste gas like that
steve - were they knocked back because of the dual brake MC's or something else? if you like i can send you the pics of these pedals if your chasing
a hydraulic clutch setup, would probably be worth updating on GL thread too i guess, still have all the measurements/drawings in a notepad if your
keen
Volkswagen Drivers Club of Queensland - member
Mick058
posted on September 3rd, 2010 at 07:56 AM |
hydraulic clutch is awesome
1303Steve
Threads: 556
posted on September 3rd, 2010 at 09:24 AM |
Hi Dave
The engineer didn't want non OEM masters and adjustable bias is a big no as well.
I'm doing the same setup as you, moving the stock master over and fitting a clutch master next to it.
The drawing would be useful, my body is still on the pan now so its awkward to work on.
I have an incentive now to get mine on the road, NSW rules may change soon and my engineer will retire when they do.
STIDUB
Over it.
Threads: 57
posted on September 4th, 2010 at 05:31 PM |
notice something missing??? the creeper! the engine/box are now attached to the pan!!!!!!!!!!!!!
and another...
its gotta drop about 100mm in the back yet, believe it or not that keeps it above legal still & the sump will be 40mm higher up than the stand
thats on it now
water/oil thingo has to say bye bye but thats no major issue, departure angle shouldnt be an issue either and theres room to squeeze in an exhaust
thats more than 3ft long after all, but only just, lots of metal work now....
or perhaps put all the stuff back on the engine with new seals etc & fire it up..... maybe
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on September 4th, 2010 at 06:01 PM |
Good to see some more progress mate - look forward to some full side on or front/rear 3/4 shots at some stage once you get the height sorted out.
Al
trickysimon
A.k.a.: Simon Azzopardi
Threads: 43
posted on September 4th, 2010 at 07:26 PM |
Nice work dude, too bad it will never beat the Bora
ian.mezz
Threads: 280
posted on September 4th, 2010 at 08:09 PM |
whats that blue thing under the motor????
colonel mustard
Threads: 51
posted on September 5th, 2010 at 01:01 AM |
Quote: | Originally
posted by trickysimon
Haha. Good one Simon!
I challenge you to go lift the rear of your Bora..... Does tht give you a better idea of how fast this is going to be..?
STIDUB
Over it.
Threads: 57
posted on September 5th, 2010 at 02:12 AM |
ian - blue thing? as in the oil filter bit or the weird bits of RHS? the rhs was to sit it flat on the garage floor for awhile attached to the gearbox
to work out heights of things, if you havent noticed the sump on an EJ isnt exactly flat/stable enough for it to sit on, so i just slapped that
together, worked a treat
spose i need to replace it with a shortened sump now
Al, its going to need alot of TLC & the odd patch work before anyone sees some nice/clean angles, rear pillars for a start ( got a tig welder i
can borrow for a few hrs??? ) oh and rebuilding the body around the
engine so it all fits nicely and protected from the road/wheels and possibly the odd bit of delaminating tyres
simon, bora i wouldnt know for sure, but your beetle wouldnt stand a chance anymore :P i smell a conversion coming on hehe, sell u my leftovers &
some drawings/sketches & such to help out.
steve - still looking for the right note pad, its amongst legitimate work stuff somewhere, may have a spare undrilled section somewhere too, gotta
rummage through the toolbox at work & the bits & peices at the mothers and find where everything has ended up at the new place
trickysimon
Threads: 43
posted on September 5th, 2010 at 12:36 PM |
Haha nah i refuse to go subi on this Beetle. We will see whos laughing when I supercharge the Bora
All jokes aside though, this thing is gunna hammer!
STIDUB
Over it.
Threads: 57
posted on September 13th, 2010 at 08:42 PM |
steve, still havent found the drawings or the unfolded/drilled section yet, not impressed!
and for the conversion guru's...
can i delete that line from the pump to the cooler & into the block completely without any adverse effects or not, and is that the way it would
flow or is it the other way around?
STIDUB
Over it.
Threads: 57
posted on October 22nd, 2010 at 11:36 PM |
wow, looks like ive beeen slack heres a pic of
something thats coming together slowly...
can anyone smell fuel vapour?
STIDUB
Over it.
Threads: 57
posted on October 27th, 2010 at 10:10 PM |
fuel rails modded slightly....
shopping for more fittings & bits tomorrow, they didnt have enough of what i needed last week
coming up next, coolant lines & sump
STIDUB
Over it.
Threads: 57
posted on October 30th, 2010 at 10:39 PM |
as for the other end...
weld on fitting from tank to this....
lil bit of other stuff after that...
used hard fittings to get the rough idea, might change some parts to braided hose soon, still gotta fit water lines in there somehow
may also change the tank to pump section to a big dia rubber hose just so its easy to get on/off, not much room for swinging spanners to tighten
everything up in there unfortunately bt it goes with the whale into sardine tin theme i guess.
oh, can anyone tell me, how hot will the 044 get when running? it will be insulated from coolant lines & radiator heat but i wouldnt mind slapping
my battery in a box just ahead of it where the spare wheel was, ill bit of sheetmetal work needs to be donee here... should be solid & look neat
when done pics to come
STIDUB
Over it.
Threads: 57
posted on October 31st, 2010 at 04:51 PM |
weld on fitting for tank to pump & return line to tank done, gotta love the original drain hole & body hole to match, mirrorred on the other
side for the return fitting, now just need a tiny lenght braided hose so i can do the fittings on everything up tight while its all in the car, idea
being to leave the hose lenghts on the tank as its put in, then attach the rest thru what was the rear panel of the wheel well, all to be re sheeted
in a more suitable fashion soon pics later - hurt my neck now gettting some tlc from boss lady
1303Steve
Threads: 556
posted on October 31st, 2010 at 05:53 PM |
Looking good. I had a tap on the tank outlet on my old bug and I've put one on Davids bug as well. It make it much easier when you pull the tank out
to be able to turn the flow off.
STIDUB
Over it.
Threads: 57
posted on October 31st, 2010 at 08:59 PM |
pics as promised, welds arent sexy enough to boast about so your not seeing them
anyway for the purpose of the pics theres an extension peice from the weld-ons down to the 90deg & 45deg fittings, will be replaced with about
2-3" of braid on the pump side & the return will be straight from tank to hardline nut
the other part of the fuel tank will be in tank baffle, will be fun to do with the level sender still needing to be put in/taken out, grey matter
nutting that one out to work out the best option before i cut anything
steve, thought about doing that but would need to cut out all of the flat area where the steering column goes through, that & theres not a whole
lot of room to fit anymore, water lines are snaking between the steering box & fuel line & fuel line/idler on the otherside obviously, leaves
enough room to throw a battery box infront of the pump and still leave enough room to let air escape out from the radiator wonder if i could fit a weeks shopping and a spare tyre too
STIDUB
Over it.
Threads: 57
posted on November 15th, 2010 at 01:10 PM |
gotta love birthdays & attachments that get hints
something special is coming my way....
im pretty sure its the one thing my bug will have that no other in the country will have, for now anyway
-oh, anyone got a suggestion for flaring fuel lines, the stuff i have from trade tools just wont cut the mustard, tube cutter is awesome, flaring -
not a chance- would love suggestions so i can finish my fuel lines...
Craig S
A.k.a.: Craig
Threads: 83
Mood: In the mood for change
posted on November 15th, 2010 at 07:10 PM |
Mmmmmm love the mirrors
http://www.ne.jp/asahi/jeffreys/vw/fr_top.html
That's exactly what I'm after, like the 1303RS at the nationals, but without me having to have any skill
How do you order??? Not a lot of clues on their website.
1969 Beetle - June
1974 L Bug - Gwendolyn
2002 Bora V6 4Motion - Anita
STIDUB
Over it.
Threads: 57
posted on November 15th, 2010 at 07:56 PM |
Well the way i did it was study japanese while on breaks at work... That lasted till about chapter 4 then asked everyone i knew if they spoke
japanese, then asked the importer i got my engine from, then asked boss lady to do it for me thru a guy that imports cars from japan, he have her an
email of a guy who knew a guy that lived in japan, osaka i believe, then they spoke & organised it all, in short a lot of effort + finders fees
& favours. Oh not to mention the 3 yes 3friends that went to japan this year! Oh its a suprise, i dont know they are coming lol. Ill let u know
what quality is like, mite be getting more stuff soon& mite be able to help u out :-)
Craig S
A.k.a.: Craig
Threads: 83
posted on November 15th, 2010 at 08:23 PM |
Look forward to hearing, the other option I'm considering is the side blinkers from a current model statesman to go where the trim currently sits,
and just keep the mirrors simple
1969 Beetle - June
colonel mustard
Threads: 51
posted on November 15th, 2010 at 08:32 PM |
Quote: | Originally
posted by STIDUB
why are you cutting me?
STIDUB
Over it.
Threads: 57
posted on November 16th, 2010 at 12:19 AM |
relax mustard its just a saying, if your not working tomorrow & i take the woman to work ill come visit & see what the L's problem is
h
posted on November 16th, 2010 at 04:32 AM |
I'm looking fwd to seeing this being driven
keep up ur tireless effort
STIDUB
Over it.
Threads: 57
posted on November 16th, 2010 at 01:12 PM |
H - tireless is about right, 1000s of times ive been tempted to throw the lot in the bin, but when i have a free few hours i try to make some
progress, its about a year overdue for completion now anyone
wanna clone me so i can work to make the $$ and work on the car at the same time id be greatly appreciative
Craig S
A.k.a.: Craig
Threads: 83
posted on November 16th, 2010 at 08:30 PM |
Quote: | Originally
posted by STIDUB
anyone wanna clone me so i can work to make the $$ and work on the car at the same time id be greatly appreciative
If it's costing anything like most restos/modifications then you'll need to be cloned twice, so that there's three of you:
* One to work on the car
* One to earn the money to live
* One to earn the money to pay for the car parts you buy.
1969 Beetle - June
STIDUB
Over it.
Threads: 57
posted on November 16th, 2010 at 08:47 PM |
...or do shift work with overtime paid at 2x your decent rate, tho, 2x ppl on my pay could be handy...
Craig S
A.k.a.: Craig
Threads: 83
posted on November 16th, 2010 at 08:59 PM |
Overtime??? What's that??? I'm a salary slave. Working extra hours is all part of the deal.
You obviously don't have money sucking kids yet either!!
1969 Beetle - June
STIDUB
Over it.
Threads: 57
posted on November 17th, 2010 at 12:37 AM |
ahh yes, salary jobs- couldnt think of anything worse myself
and kids, yeah the theory i started with was either do something crazy now or later, figured if i did it pre-family etc then at least i SHOULD be able
to enjoy it into the later, wont be able to do something this silly again till im retired, thats another 40+yrs or big lotto winnings away,
considering i dont gamble much... heres to hopefully finishing the car before i retire
oh craig nice choice on the wheel, looks like mine though that
will probably be changing soonish hehe
