| [ Total Views: 130719 | Total Replies: 1116 | Thread Id: 85894 ] |
| Pages: 1 2 3 4 5 .. 38 |
ricola
Threads: 9
| posted on November 22nd, 2010 at 09:26 PM |
Getting into paint is a great motivator!
1303Steve
| posted on November 28th, 2010 at 06:25 PM |
In a previous life this car was sports sedan running a 12a rotary motor
I've been busy on the pan.
I had to call on expert help from Brad a Westside mufflers to weld up my alloy mirrors after I cut the attaching legs off. The mirrors need to be
painted with rest of the car so Brad kindly fitted this fiddly job into his busy schedule. It was made fiddly because these early Falcon GT replica
mirrors appear to be die cast and were bitch to weld.
I'm using the stock mirror mount holes and using cutdown stock mirror stalks, this way I can change mirrors without having to drill new holes in the
door, I ran the same mirror stalks on my old yellow bug but with XA falcon mirrors.
| Error |
| Error |
| Error |
Camo
A.k.a.: Kev
Threads: 209
| posted on November 28th, 2010 at 07:56 PM |
You are definitely a thinking man Steve, good idea. Great to share all these little tricks with others and with a smear of filler the mirrors will
look like they were factory made for the car
Kev
GTMac
A.k.a.: Andrew
Threads: 246
Mood: Always asleep
| posted on November 30th, 2010 at 08:46 PM |
Looking good Steve, cant wait to see paint. How many times you changed your mind now?
Are they Simmons V5's your running?
Cheers, Andrew
1971 Type 3 Fasty - EJ20T
I love 242HP sleepers.
How many sets of lights does it take a $229k Carrera S to learn?
UPDATE: Cayman S, M3, B4 now added to the list.
STIDUB
Over it.
Threads: 57
| posted on December 1st, 2010 at 05:38 AM |
^^^ we will find out when the 100s of 4vent lids come out of hiding that have all been sprayed various colours
the mirrors look the goods steve
Volkswagen Drivers Club of Queensland - member
1303Steve
| posted on December 1st, 2010 at 07:18 AM |
Thanks for the comments guys.
I may have forgotten a few colours, black, Mercedes silver, apple green, CTs silver, vermilion fire, Suzuki GTi yellow, phantom purple.
The Porsche blood orange is very close to looking like vermilion fire that was used on Falcon GTs in the 70s
The wheels are Simmons OM or open mesh.
pic is a Blood Orange Porsche
PS forgot VW harbour blue and Holden Marine blue
| Error |
1303Steve
| posted on December 1st, 2010 at 09:34 AM |
Pissing down today, cant do much on the chassis because Davids bug will have to sit in the rain, so I went to visit the bug today. That's the problem
with a small garage.
I'm fitting air con to the car, so the inlet grilles were welded up as well as the LHD wiper holes. The extra holes in the bulkhead is where the
stock dash fan will draw in air.
Hows this for a rust free air box? I'm going to use the stock air box drain tube on the evaporator housing and I've fitted a smaller OD drain hose
in case any moisture gets into the air box.
| Error |
| Error |
| Error |
1303Steve
| posted on December 1st, 2010 at 09:38 AM |
Doors and bonnet waiting for paint, I treated the firewall area with rust converter
| Error |
| Error |
| Error |
1303Steve
| posted on December 4th, 2010 at 09:42 AM |
Still working on the pan, had a bit of a setback, the reinforcing that I planned to add to the lower part of the torsion bar tube makes it impossible
to get the gearbox in or out, I need to rethink this with maybe a bolt in section.
Had a win, I hooked up the shifter to the G50, apart from needing to slightly straighten preset bend in it it all fitted up without any shortening or
lengthening of the shift rod.
All the panels in are in primer now, the shell needs a few more days on it then it will all be painted. I had a test paint swatch made up in blood
orange, looks good.
| Error |
| Error |
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on December 4th, 2010 at 02:33 PM |
A bit hard to tell from the picture, Steve, but that looks a bit like my old Sports-Sedan colour. That was 'Tangerine'. It'll look good.
Cheers, Greg
1303Steve
| posted on December 4th, 2010 at 06:32 PM |
Hi Greg
It could be verging on old #92s colour, I held the sample swatch up against Dave Birchalls orange bug today and the swatch looked red next to his
car.
I think it will stand out.
1303Steve
| posted on December 5th, 2010 at 08:05 PM |
After I got back from Boris Picnic I did some work on the pan. I relocated the brake master cylinder 30 mm to the drivers (right) side, this gives me
enough room to fit a clutch master in next to it.
I now have to move the lever on the brake pedal over 30 mm as well and fit rose joint attachment to the clutch pedal to operate the clutch master
cylinder.
| Error |
| Error |
| Error |
STIDUB
Over it.
Threads: 57
| posted on December 5th, 2010 at 11:01 PM |
wonder where you got that idea from oh, shame all i can find of my
original idea is a rough, i mean rough layout in a notepad, i doubt many people would read it easily too, the pedals are the next fun bit, mine are
getting close-ish to finished for the last time, gotta love the evolutionary process of this stuff
oh, it looks like you may of but im not sure, did you drop the centerline of the MC's down about 10mm?
1303Steve
| posted on December 6th, 2010 at 12:36 AM |
Hi Dave
I think we came up with the idea at the same time. I kept the standard height for both the master cylinders.
I'm either going to weld on a lever for the brake master like you did or I was thinking of cutting 30 mm out of the horizontal tube and then
rejoining the 2 bits, this would move the brake master operating lever into the correct position and then run spacer between the clutch pedal and the
narrowed brake pedal, Im just going to run a simple clevis on the clutch pedal.
I kept the master cylinder centre line the same.
This would be a real pain job to do with the pan on.
ricola
Threads: 9
| posted on December 6th, 2010 at 06:17 AM |
What are the extra holes for Steve? I kinda wish I'd done this on mine after all the hassle I've had running new lines, balance bar etc etc!
1303Steve
| posted on December 6th, 2010 at 09:25 AM |
Hi Rich
Extra holes, I used this plate as template when drilling the others, that hole lined up with a stock master cylinder hole, this with clamps held in
place for drilling and welding, the big hole on the bottom is for the hard lines to feed back into the car.
1303Steve
| posted on December 10th, 2010 at 04:29 PM |
There is some paint on the bolt on panels, the body will be done next week.
| Error |
| Error |
| Error |
1303Steve
| posted on December 10th, 2010 at 04:30 PM |
some more
| Error |
| Error |
| Error |
Pickpocket
| posted on December 11th, 2010 at 04:21 AM |
How did you prep that little area below your rear window with the vents? I considered drilling out the spot welds (all 500), prepping and tacking it
back into place but that seems like alot of extra work. Not to mention that if I get that alignment wrong my deck lid won't ever sit straight.
1303Steve
| posted on December 11th, 2010 at 07:41 AM |
I had it soda blasted, that cleaned it up really well
Steve.
matberry
| posted on December 11th, 2010 at 07:53 AM |
Looking good Steve.....and very ORANGE.
1303Steve
| posted on December 11th, 2010 at 06:06 PM |
Thanks Mat, it looks much better in the flesh than the photos.
I nearly have the pan done, then its on with the body, then a hood lining and then Westi is going to do a 3 inch exhaust for it, then see the engineer
to get it ticked off before he retires.
reub
VWRX is gone...
| posted on December 11th, 2010 at 09:56 PM |
All happening very fast dude. Looks great
Reub
Camo
A.k.a.: Kev
Threads: 209
| posted on December 12th, 2010 at 12:20 AM |
Looking great there Steve and to think that you haven't down much work on it in the last 12 months and you will have yours on the road before me
Great work, Kev.
1303Steve
| posted on December 12th, 2010 at 08:55 PM |
Thanks guys, Kev you should ahead of me, your car is at home.
I'm having a bit of spurt at the moment, the engineer who has passed 3 other WRX bugs and has been looking after mine is retiring soon, so I just
want to get it up to blue slip stage and then finish it as time allows.
I have been neglecting all household stuff so I'm not popular, as they say the amount of of shit your in only varies in height, I'm nearly
drowning.
I did the ratio calculations on the Porsche G50 gearbox I'm using, they are nearly identical to my sons R31 Skyline, 1st through to 4th are nearly
identical, the G50 5th is little taller. The R31 has an excellent spread of ratios, 1st is very tall and all the others are very close so the G50
should work well.
Been doing heaps of work on the chassis, its nearly done, just fitting up the 944 handbrake cables, 944 rear sway bar mounts and I'm running a tube
through the tunnel for a Morse accelerator cable.
reub
VWRX is gone...
| posted on December 12th, 2010 at 09:22 PM |
I'll have to draw on some of your motorvation to get back into mine.... one day
Reub
Flintstones
Threads: 69
looks great Steve
D
1303Steve
| posted on December 17th, 2010 at 09:32 PM |
Thanks for encouragement guys.
Still working on the chassis.
I had Brad (aka Westy) weld some fittings on the tank. 1/2 outlet and and 2 x 3/8 return lines into the tank, while he was at it I got him to fill in
the LHD part of the tank for some increased capacity, I think maybe 2 - 4 litres gain.
I bought this tank from a wrecker in about 2002 for my yellow bug, it was a genuine VW German replacement tank that looked almost new.
| Error |
| Error |
| Error |
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on December 18th, 2010 at 09:24 AM |
Nice bit of TIG welding there.
1303Steve
| posted on December 18th, 2010 at 10:51 PM |
Hi Greg
Brad is the man for good welding, I always get him to do the important stuff.
