[ Total Views: 118338 | Total Replies: 1116 | Thread Id: 85894 ]
 Pages:  1  ..  32  33  34  35  36  ..  38
Author: Subject:  Steves 1303 buildup, found lots of kilowatts
Threads: 733
posted on August 23rd, 2017 at 08:15 AM
:tu:
Great stuff Steve
Threads: 561
posted on August 26th, 2017 at 10:21 AM
A bit of a delay with the tuner, he's had a few headache cars to deal with and he asked me to delay bringing the car up.
this is what was done to the motor
Block has been doweled to prevent cylinder wall splitting
14 mm head studs fitted
Manley forged pistons
Argo I beam rods
Race bearings
New EJ257 crank
Full blue print of motor
Genuine 11 mm oil pump
New genuine water pump
MemberFlintstones
Threads: 69
posted on August 26th, 2017 at 11:03 PM
Some serious gear there Steve, what rwkw are you aiming for this time?
D
Threads: 561
posted on August 27th, 2017 at 12:03 PM
The engine builder put a limit of 8000 rpm, 30 psi and 400 kW, it will be up to what the turbo can handle. you can really feel the difference the stroker crank makes, it should bring everything on sooner, turbo is GTX30/76 with a .63 rear housing and I don't want to do this again
MemberFlintstones
Threads: 69
posted on August 27th, 2017 at 09:27 PM
Nice souvenir :lol::tu:
Threads: 561
posted on September 1st, 2017 at 09:10 AM
Car is still at the tuner, the tuner has issues in the past getting the variable inlet cams to make any difference in the the way the car runs, Adaptronic have now supplied a new ECU which is their latest version in the Modular series
Threads: 561
posted on September 5th, 2017 at 06:00 PM
I picked up some motor insurance today, an Accusump. I had one years ago but my son used it on his drift car so I had to buy another one.
They give you pre oiling before starting the motor and also make up for oil surge causing the motor to drop oil pressue
posted on September 6th, 2017 at 07:12 AM
Accumulator
Threads: 561
posted on September 7th, 2017 at 07:18 PM
Originally posted by vw54
Accumulator
yep
Threads: 561
posted on September 25th, 2017 at 11:46 PM
Red blue green 3 boost settings
Pink is old setup
it made 305 kw on 29 psi, the smaller rear housing is hurting the top end but it also made 200kw at 4,500 which is really impressive, catching the train up tomorrow to pick it up
I also fitted an intercooler temp gauge, the intercooler is working fine
Memberwaltermitty
Mood: Hungry for mor
posted on September 25th, 2017 at 11:57 PM
W
oW!
23 windows ...8 too many!
Threads: 561
posted on September 26th, 2017 at 08:00 AM
thanks
posted on September 26th, 2017 at 12:06 PM
305kw that's 410hp give the V8s a run now
MemberFlintstones
Threads: 69
posted on September 26th, 2017 at 10:44 PM
Steve, even with that housing it's 305kw at 6100rpm!!
That would be soo streetable to drive.
Looks like you're going to have a grin from ear to ear when you pick it up :)
Threads: 561
posted on September 27th, 2017 at 06:58 AM
Thanks Dino, its a blast to drive, I could chase more horsepower with a different rear housing or bigger turbo but I think what I have now is more usable
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on October 3rd, 2017 at 03:00 PM
Thats some sweet power mate!!
I popped mine on the dyno the other day to play with the off boost/around town tune and turned my boost down to 14psi as I have had some traction issues in first and second and made 204kw atw.
Benefits of having a dirty big box in front of the engine for your power!!
Love your work..
Threads: 561
posted on October 4th, 2017 at 02:27 PM
Thanks Boof I will have to take you for a spin in it, the noises coming out of the air intake are so good, I thought the air filter would dampen it out
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on October 7th, 2017 at 08:58 AM
Intake looks sweet!
Threads: 561
posted on October 11th, 2017 at 09:21 AM
thanks
Threads: 561
posted on November 16th, 2017 at 05:13 PM
I've been driving the car around and having fun. I need to do a little body work where it meets the pan, it didn't line up properly with the hoop over the transmission. As soon as I get that done I will start doing some speed events, carefully.
I got my Accusump hooked up, that was a lot harder than I expected, the line wanted to run into everything. I relocated the oil filter under rear mudguard and the Accusump is under the back seat.
Threads: 561
posted on December 14th, 2017 at 08:47 AM
I was driving past a weighbridge yesterday so I thought I would pop in to get the car weighed, it came out at 1160 kg the same as when I weighed it ready to race at WISID, I emptied the boot but forgot the scissor jack and it still had almost a full tank, so about 20 odd kg there so I think it is lighter.
Threads: 561
posted on July 3rd, 2018 at 08:31 PM
Motor has been out of the car for a bit now, going back in this weekend.
I just put my entry in for the Gunnedah 1/2 mile race on Gunnedah Aerodrome in September, I hope I get a start.
I need to sort a few things like the launch control and get some Ks on the motor.
Threads: 733
posted on July 5th, 2018 at 08:11 AM
Originally posted by 1303Steve I need to do a little body work where it meets the pan, it didn't line up properly with the hoop over the transmission.
Sounds great Steve
Did you get the body work sorted?
(Love this car! :love::crazy: )
Threads: 561
posted on July 8th, 2018 at 10:12 AM
Entry is confirmed for Race Revolution at Gunnedah on the 1st of September, I need to get my finger out.
Glad you approve Barry, body work issues all fixed now
Threads: 561
posted on September 2nd, 2018 at 05:47 PM
Just got back from running at Gunnedah, I won my class and finished 37 out of 80 cars
ran at 231 kph
Membernbturbo
Threads: 89
Theme: UltimaBB Powder
posted on September 2nd, 2018 at 06:04 PM
Kin awesome.
Memberhulbyw
Threads: 131
Mood: I'm OK, RU?
posted on September 2nd, 2018 at 06:06 PM
Cool. Very well done!
MemberFlintstones
Threads: 69
posted on September 2nd, 2018 at 10:12 PM
:tu::tu:
Threads: 561
posted on September 3rd, 2018 at 08:20 AM
Thanks guys, the runway at Gunnedah is very bumpy near the end, I think Im going to look at some front aero, it was getting a bit hairy at about the 700 metre mark and the car squatted the rear the whole length of the track
not sure if this video will play https://www.facebook.com/davejcarter/videos/10157671811864908/?t=0
I put a new radiator in the week before the event, it worked perfectly, I used one from a 944 Porsche, really nice fit, thanks to boys at Westside for helping out again with fan mounts.
with my intercooler temp gauge I was able to keep an eye intake temps, we used the ice box again, at the finish line intake temps were 90c after the turbo and 22c after the inter cooler, I was leaving the line with after coolers temps of around 18c
We setup the launch control and on the first run I fried the clutch, I nearly put it on the trailer but I let cool down and then I granny shifted it from then on
Threads: 561
posted on September 9th, 2018 at 11:43 AM
This is the Porsche 944 radiator that I used, I bought it on eBay $199 delivered, the brand is ASI, I have one in my 180, my son has one in his drift car and he also had turbo Ford Laser with one as well, no failures.
Westside welded on mounts for the fan and intercooler radiator
(C) 2001-2024 Aussieveedubbers
