[ Total Views: 21990 | Total Replies: 232 | Thread Id: 87953 ] |
Pages: 1 2 3 4 5 .. 8 |
lou0060
Threads: 30
posted on May 11th, 2011 at 06:25 PM |
try again....
Error |
Error |
Error |
1971 karmann ghia Cabrio - Cruising
1963 beetle Sunroof - gathering dust
1968 race beetle - twin turbo Subaru - stress relief
1960 beetle - old school low & slow
lou0060
Threads: 30
posted on May 11th, 2011 at 06:27 PM |
some more...
Error |
Error |
Error |
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on May 11th, 2011 at 06:36 PM |
Looking good Lou
ian.mezz
Threads: 280
posted on May 11th, 2011 at 08:12 PM |
put one of these toyota fitting in the top radiator hose so its make it easy to fill the cooling system up. As you need the filling point to
be higher than the radiator and the motor.
ian.mezz
Threads: 280
posted on May 11th, 2011 at 08:20 PM |
once you start moving the car around the rear end will drop even more .
Jak Rizzo
Threads: 67
Mood: Pastizzi eating
posted on May 12th, 2011 at 07:19 AM |
Just a couple of tips for u Lou that I learnt with mine.
Don't even bother with the type 3 torsion bars, they are just not stiff enough, even with my low 8psi boost setting, mine would drag the arse of the
car everytime it came on boost, I solved this by going to 28mm torsion bars.
Your front brakes, I had Type 4 calipers on the front with Green EBC pads, DOT 5 brake fluid, braided lines & cross drilled rotors. Was perfectly
fine for the street & on the track with a vw engine, even in the heavy Superbug, but, as soon as I went WRX powered, the brakes turned to mush
after a few laps with the increased top end speed they needed to pull up.
Changed to Nissan R32 4 pot calipers & 290mm ventilated disks & the brakes have never faded since.
regards
Jak
vw54
posted on May 12th, 2011 at 07:31 AM |
Jak what are they out of or did u have them made
Jak Rizzo
Threads: 67
posted on May 12th, 2011 at 07:35 AM |
Got them off Richard at V Force, think they were sway away, that was 6 years ago now so can't quite remember
Jak
vwsteve
A.k.a.: steve
karmann crazy
Threads: 200
Mood: Busy!
posted on May 12th, 2011 at 07:54 AM |
ah so this is the race car you told me about lou, wow, looks good, i will have to pop in one of these days and have a look
1 1963 356b porsche coupe
2 1960 karmann ghia cab
1 1965 karmann ghia cab
1 1966 karmann cab
1 1961 split ute
1 1967 split p/van
1 1952 standard bug
1 1963 ragtop
1 1960 ragtop
2 1954 ovals
1 1956 oval baja project
1 1957 oval flying flea
Aussie Dubbin
Threads: 90
posted on May 12th, 2011 at 01:12 PM |
I bought some 28mm torsion bars from richard a few months back... great service and advise. Give him a call. I think his numbe ris on his website or
vforce on ebay
Aussie Dubbin
Threads: 90
posted on May 12th, 2011 at 01:22 PM |
What shocks are you running and what is the plan with that extension? Good idea just wanting some info if you can share?
Who did your brakes too? Rotors look good
ian.mezz
Threads: 280
posted on May 12th, 2011 at 07:47 PM |
I think if you have to modify the twin turbos to fit. I would toss em and just go with on factory mounted single job, Heaps of power and more room in
and around motor and easy to work on.
lou0060
Threads: 30
posted on May 13th, 2011 at 05:29 PM |
thanks for the feedback guys.
Ian, yes like the idea of the Toyota filler. After some thought I am going to move the expansion tank and raise it to about level with the top of the
radiator.
Jack, I had thought I would need to go with the larger torsion bars so I'll give Richard a call, we go back a long way... I bought his old 56 oval 25
years ago and a Judson I bet he wished he had now....
As for the brakes time will tell but an upgrade is probably not far away. We'll see how it handles first, and anyway the wooden block under the
go-pedal should speed limit it to around 100kph....
Aussie Dubbin, the shocks are KYB gas shocks. the idea behind the gear lever extension was just to get the knob closer to the steering wheel. Plus I
had a spare afternoon and a lathe to play with..... The throw is a little bit longer but I have a short shift kit in it so it is still pretty good
and tight. The front brakes are Volks Conversion / JohnSherman from the Gold Coast. as far as I know he is the only one that uses a solid hub blank
so that the holes for the wheel studs are not weakened. the calipers are type 3 single pot but again we'll see how they perform. I know lots of
guys run big brakes up front and on the rear but there is a thing such as over braking a car and with hardly any weight in the front I am not sure I
need to go bigger, but as Jak has said he has had good results with the larger brakes so time will tell.
IAn, twin turbo is there to stay!!
vw54
posted on May 13th, 2011 at 05:58 PM |
Louie
the torsion bars are from Sway A Away
talk to u know who and he can arrange
lou0060
Threads: 30
posted on May 16th, 2011 at 09:39 PM |
Hey Steve, the gearbox for the ragtop is still sitting on the floor at the other end of the shop. Don't drop in this weekend - I'm off to Sydney
for the nationals.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on May 16th, 2011 at 09:53 PM |
yeah i'm with Jako on the bars and brakes.
lou0060
Threads: 30
posted on October 13th, 2011 at 09:35 PM |
lots happened since May! my son and I finished his Mk1 Golf just in time for VW Action Day and then we had 3 weeks to finish the racecar for Warwick.
I'll post some photos of the frantic build soon but the end result was we got the car to Warwick and despite getting a flat battery on Saturday we
got it charged up over night and ran 8 runs on the Saturday and the car didn't miss a beat. 2 weeks out and I am still grinning!
there's a couple of vids on youtube but you'll need to find them yourselves.
Current plan is to finish the trailer next week and then get the car to the dyno and make sure the twins are kicking in at the right revs and see what
power it produces so we have a reference point before we start playing around with settings.
stay tuned....
Jak Rizzo
Threads: 67
posted on October 14th, 2011 at 06:46 AM |
Well done Lou!
Do u have some pics & video of your runs? (links) do u know your exact time & mph?
As a refernce, mine did a lazy off the line 8.3 seconds @ 84mph, thats with 204hp @ the wheels & the car weighs 1020kg.
Will u be at next years Nationals supersprint?
regards
Jak
lou0060
Threads: 30
posted on October 14th, 2011 at 05:00 PM |
hi Jak,
here are the links to the videos Ian and Rose shot.
http://www.youtube.com/watch?v=JTPxbgC4NoI
http://www.youtube.com/watch?v=QPqLG7tgEtE&feature=related
http://www.youtube.com/watch?v=GX6ctL3q-og&feature=related
http://www.youtube.com/watch?v=55KQlVbL0PE
http://www.youtube.com/watch?v=DVaxiuLezv4&feature=related
I hope they work, otherwise just google v2 warwick 2011 and go to videos and look for the red and yellow beetle
as this was our very first run in the car, I didn't even have time to give it a blast up the road before we put it on the trailer, I was a bit
cautious as I didn't want to break anything on the first couple of runs. Anyway the best I did was a 9.97 and around 67mph so the car still has more
to give.
mind you this was on $100 very old (hard) second hand street tyres and the rears were at 34psi so not much grip. Also I didn't fit the 3 puck clutch
and went with the stock clutch so I was getting a bit of slip as well. And the driver could probably do with some practice! (geez I got beaten by a
new beetle driven by a girl.....)
and yes we will definitely be at the nationals next year and a big maybe for the February drags at Eastern Creek.
Error |
Error |
lou0060
Threads: 30
posted on January 1st, 2012 at 02:54 PM |
well after 1 year since my initial post I have finally finished the paint job. and Also finished the year with a squirt up the road.....
http://www.youtube.com/watch?feature=player_detailpage&v=OjT0QsIkxTo
http://www.youtube.com/watch?v=8hKOcWwg87k&feature=mfu_in_order&list=UL
Next is to build the new airbox for the intercooler and then it is off to the dyno, hopefully before the end of the month.
Error |
Error |
Jak Rizzo
Threads: 67
posted on January 1st, 2012 at 03:49 PM |
Well done Lou, it sounds alot more like a WRX than mine, I really like the sound. Are u coming to WSID in Feb for the VW drags?
Jak
lou0060
Threads: 30
posted on January 2nd, 2012 at 01:34 PM |
hi Jak,
yes it sounds really mean even at idle but once you hit both turbos spooling it just howls!! can't wait to get it on the track.
Feb is looking doubtful at this stage as I am planning to run at Morgan Park that same weekend for a 3 day race meet which includes some test and tune
and race driver training so will be a great kick off for the year and I can get a fair bit of track time there as opposed to 12 hours towing and then
probably a dozen squirts down the quarter mile for a total track time of about 2 minutes!!
Also I can't justify 3 trips south this year as I want to do VW Nationals and also VW Spectacular so I think I'll be missing WSID.
lou0060
Threads: 30
posted on January 3rd, 2012 at 03:18 PM |
quite day today so loaded up the entire video and some photos...
http://youtu.be/gtqMrI-s6H8
Error |
Error |
Error |
lou0060
Threads: 30
posted on January 3rd, 2012 at 03:23 PM |
more pics
Error |
Error |
Error |
lou0060
Threads: 30
posted on January 9th, 2012 at 07:13 PM |
made up the airbox for the intercooler over the weekend.
Error |
Error |
Error |
lou0060
Threads: 30
posted on January 26th, 2012 at 08:17 PM |
had a run at Lakeside on Sunday and enjoyed the 30 minutes of track time to sort out a couple of things. The car ran well but after a few warmup laps
to get some heat in the engine and tyres I found it wouldn't rev past 4100rpm before it started missing.
At 4100rpm it was doing about 140kph down the straight so it still has lots to give. another 2000 revs should see 200kph easy down the straight.
after we pitted we found a hose had come of the primary turbo which feeds the secondary pre-spool. Unfortunately we had run out of time and so
couldn't get back on the track to see if this was the culprit.
anyway, we found a small oil leak coming from the plastic plate behind the flywheel and so we are going to pull the engine out next week and fix the
oil leak and also fit hose clamps to ALL hoses.....
I've got hold of a Gopro camera so will post some vids next time we take it out.
the below link is to a vid taken by one of the watercooled guys on Sunday, I appear around the 1 minute mark...
http://www.youtube.com/watch?v=q3rz6WrlCX8&feature=related
Jak Rizzo
Threads: 67
posted on January 27th, 2012 at 01:54 PM |
Did u get it on the dyno Lou? I'd be interested to know what your air intake temps are like with that air to air intercooler setup on the track.
I thought u may put a big aftermaket intercooler in the rear wing?
Jak
lou0060
Threads: 30
posted on January 28th, 2012 at 07:20 PM |
no dyno yet Jak. I spoke to the guy up the road from my shop who has a dyno and he is keen to get my car on the rollers. First I am going to pull
the engine out again and fix the oil leak and sort out my hoses. Plus I am going to change my intake / filter set up as at the moment it is not
running any filter, just straight into the air meter.....
Once these mods are done it will be dyno time and hopefully make it in time to do a sprint round in Feb before heading to Morgan park on the 25th.
toey1984
A.k.a.: nathan kirkman
Mood: skittels
posted on February 29th, 2012 at 10:09 AM |
just a question,
what ecu are you running?, standard or aftermarket?
if ya dont mind me asking?
Nathan
iwantbus
Threads: 1
posted on March 11th, 2012 at 12:49 PM |
Could you tell me which toyota that hose with the cap is off of? |
