[ Total Views: 21991 | Total Replies: 232 | Thread Id: 87953 ] |
Pages: 1 2 3 4 5 6 .. 8 |
Joel
posted on March 11th, 2012 at 09:15 PM |
Quote: | Originally
posted by iwantbus
Could you tell me which toyota that hose with the cap is off of?
I was checking the levels in a friends Yaris yesterday and noticed it has the same cap fitting as in Ians pic.
It looks to be small dimater hose though about 28-30mm.
lou0060
Threads: 30
posted on March 19th, 2012 at 09:10 PM |
Quote: | Originally
posted by toey1984
just a question,
what ecu are you running?, standard or aftermarket?
if ya dont mind me asking?
sorry, been off line for a while. I'm running dead stock engine and ecu. The only change I have made is the air intake and I am still playing with
this but due to finish third layout this week.
1971 karmann ghia Cabrio - Cruising
1963 beetle Sunroof - gathering dust
1968 race beetle - twin turbo Subaru - stress relief
1960 beetle - old school low & slow
lou0060
Threads: 30
posted on March 19th, 2012 at 09:15 PM |
thanks for covering for me Joel. Ian will know what car the cap assembly came of. I didn't go with it as my set up moved the standard Subi
expansion tank up higher than normal.
CAr is currently on blocks and waiting for the engine to come out to replace the oil plate behind the flywheel which has developed a slight oil weep.
However, things are busy at work so not much time to play.... Aiming to be at Lakeside mid April and Wakefield in MAy so need to get back to it soon.
Currently working on an engine trolley similar to what Joel made to make engine removal easier...
tar76
Threads: 95
posted on March 19th, 2012 at 09:35 PM |
Let us know when you guys are hitting Lakeside, luved to come down and watch the beetle cut some laps
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
NTsuperbug
Threads: 7
Theme: UltimaBB Pro Powder
posted on April 3rd, 2012 at 11:52 AM |
Thanks for the reply Lou..... just came on to check for the uploaded pics????? nearly there we will be back on the track in no time...
lou0060
Threads: 30
posted on April 7th, 2012 at 11:34 AM |
finally got some time together to replace the oil splash bracket on the back of the block. So much pain for such a small job, but now done and back
in the car.
the first photo is the old plastic plate and the new one is metal. Seems might have been a common problem with Subaru as the old plastic one used
counter sunk screws which eventuallu split the plastic and caused the oil to weep. the new plate comes with new flat head screws and no gasket so
used plenty of Permatex sealant.
Lakeside sprints are on this weekend coming 14th and 15th I think so at this stage planning to be there on the Sunday.
Error |
Error |
Error |
lou0060
Threads: 30
posted on April 7th, 2012 at 11:35 AM |
Also while it was out I fitted a turbo blanket to try and keep the heat of the starter motor....
Error |
lou0060
Threads: 30
posted on April 17th, 2012 at 05:50 PM |
Just an update, things didn't go as planned for last weekend as the car is still in the garage. anyway got the engineback in and everything is
bolted back together now just need to sort out a fuel leak in the return line which leaks when I start the car after its been sitting for a while and
once the pressure builds up it stops???
While the engine was out I redid the air intake and here is what it looks like now.
Error |
Error |
Error |
lou0060
Threads: 30
posted on April 17th, 2012 at 05:52 PM |
and with the tail on...
Error |
Error |
vw54
posted on April 17th, 2012 at 06:20 PM |
louieeeeeeeeeeeeeee
Jak Rizzo
Threads: 67
Mood: Pastizzi eating
posted on April 18th, 2012 at 07:31 AM |
I still think u should put the intercooler in the wing, not only would it function better but would look friggin cool ala Porsche 930 turbo.
Are u definantly coming down for the Nationals? I want to see u smack me with that twin turbo setup!
Jak
lou0060
Threads: 30
posted on April 18th, 2012 at 05:56 PM |
Hi Jak,
semi slicks for the front arrived this week.
downloaded the paperwork last night and all filled out. Will be posting tomorrow with the cheque attached....
can't wait; 38 sleeps to go..............
ian.mezz
Threads: 280
posted on April 18th, 2012 at 08:18 PM |
best to travel past Sydney on friday morning , because the arvo traffic is a bitch.
lou0060
Threads: 30
posted on July 10th, 2012 at 05:25 PM |
after the overheating problems in Goulburn, despite the near blizzard conditions, I have made some refinments to the intercooler and also the
expansion tank.
After I got back from Wakefield I made up a radiator pressure filler to get the air out of the system as I felt this was where my main problems were
at. After 2 laps the car was running at 120 deg and jumping into limp mode. I was surprised at how much air I was able to get out of the system.
Anyway I then decided to take jak's advice and move the intercooler.
So now after moving all the bits out of the way and extending the rear bracket I now have the intercooler under the vents on the back wing and the
coolant expansion / filler tank up higher than the radiator. All is back together and I plan to run the engine tomorrow before taking the car to the
dyno. Next outing is July 22nd at lakeside sprints so plan to have dyno completed by early next week and hopefully I have cured my limp mode issue.
Error |
Error |
Error |
lou0060
Threads: 30
posted on July 10th, 2012 at 05:27 PM |
a few more.... including a view from inside the parcel shelf area.
Error |
Error |
Error |
Jak Rizzo
Threads: 67
posted on July 11th, 2012 at 01:22 PM |
Cool dyno time!
My guess is 245 rear wheel hp on 16psi boost!
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on July 11th, 2012 at 07:33 PM |
Well done Lou
Always some troubleshooting to do once you stray from a stock car
lou0060
Threads: 30
posted on July 11th, 2012 at 08:51 PM |
started the engine tonight and spent about a hour bleeding the cooling system and pretty happy with the result. Ran it up to temp and cycled through
the fans a couple of times with temps settling down nicely. Water ranged between 90 and 100 and oil got to around 80 and maintained. Amazing how
much air bubbled out using my home made bleeder. I reckon at least an extra 750ml of coolant went into the system which means 750ml of air came out.
Anyway pretty much ready to go back on the trailer and off to the dyno on the weekend. Will post results next week all going well.
20bkombi
Threads: 26
posted on July 11th, 2012 at 09:31 PM |
Nice work! Can't wait for the weekend.
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
Jak Rizzo
Threads: 67
posted on July 11th, 2012 at 10:20 PM |
I also found that once it's cooled down, take off the radiator/coolant cap & let it sit over night, next day it needed more coolant
1303Steve
Threads: 556
posted on July 12th, 2012 at 08:24 AM |
Hi Lou
Once you start driving the car air will work its way out again.
Joel
posted on July 12th, 2012 at 10:39 AM |
Quote: | Originally
posted by Jak Rizzo
also a good idea to retighten all the hose clamps after a couple heat/cool cycles, the hoses always seem to move around abit, probably why most modern
cars come with spring loaded clamps now.
ian.mezz
Threads: 280
posted on July 12th, 2012 at 10:47 AM |
did you get rid of that charcoal canister.
tweety
Threads: 68
posted on July 15th, 2012 at 12:42 PM |
A great project and write up Lou.
thanks for all the pics.
I also had heaps of issues with air bleed with my Alfa radiator at the front of my trike. I used as Hyundai i30 diesel expansion tank and hooked it
up to the heater hose to the water pump. The tanks outlet is heater hose size and there are two very small outlets also on the tank that can be hooked
up together with transperant hose to make it easy to sight the level (one outlet high one low) Also a bleed at the radiator, air pockets still exist
for a while.
Me thinks a bleed on the ea81 opposite the thermostat housing at the small hose used to heat the manifold is another one needed. So several wont hurt
and could save some heart ache. Bleeds were purchased at ENZED of the brass type that lock hard so they wont accidentally open.
lou0060
Threads: 30
posted on July 23rd, 2012 at 05:52 PM |
I almost feel embarrassed to post this but got my car off the dyno today after a week of hell and best we managed was 116hp at the wheels at about 9
psi boost. Sooooo, something is not working!
Possible causes that we are going to check are the wastegate seats to ensure there is no leakage past them, hoses to the blow-off valves, and hoping
not to have to go there but check the turbos for wear.... When we pulled the hoses off the vacuum actuators the boost didn't change so must have a
leak somewhere.
We had to fit a new airflow meter and at least the car did not overheat and ran pretty constant over the 4 hour session. Just not getting the power I
was expecting.
The engine now revs well above 4000rpm and does not have the limp mode/miss fire issue at 4000rpm we had before so some good news there I guess.
back to the drawing board......
toey1984
A.k.a.: nathan kirkman
Mood: skittels
posted on July 25th, 2012 at 09:19 AM |
what exact motor are you running ? (g, r or h.......) or ecu model / code?
are all the vacume lines clean?, no cracks or leakes in lines?
the twins made a min of 150kw ( as to what i know) with the ej20g ( 183- 190 with the non gtb motors then 190 - 206kw with the gtb yellow injectors
eith the h's)
all the solinoids are working?
The love hate relationship of the tt.
hope you get it sorted out mate, all the best. keep us posted!
Nathan
Joel
posted on July 25th, 2012 at 09:43 AM |
Hi Lou, you may be losing boost with that valve setup that brings the 2nd turbo in not opening properly, you know if the gauge is reading spot on?
Where abouts is the gauge connected?
Other issue you may be having is on the dyno the intercooler wouldn't be getting much air flow through it.
toey1984
Mood: skittels
posted on July 25th, 2012 at 10:05 AM |
("Hi Lou, you may be losing boost with that valve setup that brings the 2nd turbo in not opening properly, you know if the gauge is reading spot
on?
Other issue you may be having is on the dyno the intercooler wouldn't be getting much air flow through it.")
The second motor i have here nearly out of the donor car has the boost gauge linked into line 10 if that helps
If you are not sure if your vaccume lines are connect to the right portal, i could cross reference them with mine?
are you running the standard vaccume tank? as they do use more vaccume than i thought and may not be pulling the valves open in the correct manor or
hard enough?
just looking at a tt dyno graph it makes 110bhp at 3000 rpm and 155 - 160 at 4000 just before the gate fully opens ( on a standard jap spec 280ps
motor)
Nathan
vw54
posted on July 25th, 2012 at 11:12 AM |
LG
i know a good VW engine bulider
1303Steve
Threads: 556
posted on July 25th, 2012 at 07:56 PM |
Quote: | Originally
posted by vw54
LG
just need a good VW engine then
