[ Total Views: 40722 | Total Replies: 578 | Thread Id: 89664 ] |
Pages: 1 .. 14 15 16 17 18 .. 20 |
Sides
A.k.a.: Dave Sidery
posted on May 24th, 2013 at 07:51 AM |
-8 all the way dude.
Doesn't cost or weigh much more than -6 really, and no harm in having more fuel flow capacity than you need.
Cry once basically.
My toys
dragvw2180
Threads: 33
posted on May 24th, 2013 at 09:16 AM |
I have never had a need to use a return line on my drag cars and have always had the regulator near the carbs . My fuel pressure always stayed pretty
steady wherever I set it from 2.5 - 7psi depending on which carbs I ran. I do consider the fuel pump a wear item that I replace every couple years and
I rebuild the regulator every year so that I can replace the diaphram and check the spring . If I was driving on the street for prolonged periods of
time I might think about a return system but only after I had a problem. I am NOT saying what you guys are doing is not needed for your cars , just
that I have been lucky not to need it all these years. Mike McCarthy
p.s. I use Holley pumps and regulators
humpty
Threads: 139
Mood: Totally boosted!
posted on May 24th, 2013 at 01:42 PM |
Quote: | Originally
posted by dragvw2180
I had nothing but problems with all the Holley products... But like you said, street cars are different animals.... Most of the fuel control problems
I had were with the DCOE (which turned out to be heavliy modified for meth by the PO!), and the need to run a boost refernced FPR with that carb....
Hence the full flow setup.... Most all Holley FPR's are designed to be used a 'dead head'.... But the pumps never lasted very long either.... I now
use the Carter pump which is an internally submerged pump that uses the flow of fuel to keep it cool, along with the Aeromotive FPR.... I now have
rock solid pressure to the 500dbl Holley, with plenty of flow through my 1/2" ID lines.
1916baja
Threads: 176
posted on June 21st, 2013 at 06:58 PM |
Finished making up a new weld in midmount tonight, also gave the gearbox a little love... it might even get a lick of paint tomorrow!
Error |
Error |
FROSTY
Threads: 65
posted on June 22nd, 2013 at 07:16 AM |
DON'T PAINT !!!!! You better hurry up Warwick is not far away.
1916baja
Threads: 176
posted on June 22nd, 2013 at 07:47 AM |
Tell me about it! Got 3 months after Sydney and my engine is still in a million pieces at daves place....
1916baja
Threads: 176
posted on June 22nd, 2013 at 05:54 PM |
Sorry frosty, had to be done! Painted my gearbox today and finally fitted the wing i've had sitting in a box here since warwick last year! it's been
good to finally get a bit of shed time the last couple of days!
Error |
Error |
20bkombi
Threads: 26
posted on June 22nd, 2013 at 08:46 PM |
Dude.... Your cars upside down!!!!
Nice to get some shed time, that wing looks cool
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
20bkombi
Threads: 26
posted on June 22nd, 2013 at 08:52 PM |
The bat mobile!!!
Ph 0402 233 027
1916baja
Threads: 176
posted on June 22nd, 2013 at 09:10 PM |
Wow! It is too! It's not on my computer....
1916baja
Threads: 176
posted on June 22nd, 2013 at 09:20 PM |
There we go, are they up the right way now? Stupid computer....
humpty
Threads: 139
posted on June 22nd, 2013 at 09:59 PM |
Quote: | Originally
posted by 1916baja
I've been seeing that pic issue a bit on here of late.... I suspect it's not the computer that the problem, but the forum.... Maybe time for an
update admin guys!
Anyway.... Good to see some progress on the car Mick.... Your not gonna know yourself when the boost comes on!
SuperOwen
Threads: 67
posted on June 23rd, 2013 at 06:29 AM |
My pics do that if I post them from my iPhone, that wing should hold a full buffet!
1916baja
Threads: 176
posted on June 23rd, 2013 at 07:34 AM |
The wing is actually gonna house 2 scoops and the fans to keep the sucker cool!
Sides
A.k.a.: Dave Sidery
posted on June 23rd, 2013 at 09:22 AM |
Heh heh - Upside Down Miss Jane !!!
Still planning on going with the bilge blower type fans ??? Be keen to have a look see at 'em if you are... could work in something else I'm toying
with...
My toys
1916baja
Threads: 176
posted on June 23rd, 2013 at 09:37 AM |
Is it still upside down? Yeah still planning on using 2x 235 cfm inline bilge blower fans mounted on top of the wing under a scoop ducting cool air.
Maybe you can check them out when you come pick up this damn fuel tank! I tripped over it twice yesterday!
1916baja
Threads: 176
posted on June 26th, 2013 at 05:33 PM |
Got a shipment from pierside today! Ignition,oil pump,teflon buttons,jaycee bling! Check out the features on the ignition!
http://www.cbperformance.com/ProductDetails.asp?ProductCode=2016
Error |
Error |
Mr Muppet
Threads: 6
posted on June 26th, 2013 at 08:40 PM |
Nice, if have been looking at the Digital for my other motor, are you going to have a crack at tuning it yourself?
1916baja
Threads: 176
posted on June 26th, 2013 at 08:46 PM |
Well, it's got pre set maps in it which you can modify. So well get it running and a close tune then take it to the dyno to tune under load on boost.
essex
posted on June 26th, 2013 at 09:36 PM |
Good stuff Mick, got everything you need now?
1916baja
Threads: 176
posted on June 26th, 2013 at 10:55 PM |
Ha ha! Not quite.... Still need cooling, charging, rods, fuel lines/fittings... That's off the top of my head.
1916baja
Threads: 176
posted on July 14th, 2013 at 09:11 PM |
Finally got things moving this weekend, we got off to a rocky start on saturday but nipped it in the butt today! We did a trial assembly of the whole
engine, everything seems to fit quite nicely...
Error |
Error |
Error |
20bkombi
Threads: 26
posted on July 15th, 2013 at 05:30 AM |
Good work guy's...
Not long now mick
Ph 0402 233 027
turboboy
Threads: 34
posted on July 15th, 2013 at 08:20 AM |
teflon buttons
Howdy
check the fit of the button's.
The ones I got where sloppy when fitted.
Richard
1916baja
Threads: 176
posted on July 15th, 2013 at 09:53 AM |
Yeah, we did... Turns out you can't use the Teflon buttons on the wiseco slipper skirt pistons, only Mahle. The pistons come with these spiro lock
things which are supposedly the next best thing.
55slug
Threads: 22
Theme: UltimaBB Psyche Red
posted on July 15th, 2013 at 05:22 PM |
FWIW I have used the Jaycee alloy buttons with wisecos in he past with success. Engine looks great !! Nice crank and case !!
66deluxe
Threads: 139
posted on July 15th, 2013 at 05:30 PM |
Not using straight cut gears?
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
1916baja
Threads: 176
posted on July 15th, 2013 at 05:31 PM |
Fwiw??? He he!
1916baja
Threads: 176
posted on July 15th, 2013 at 05:36 PM |
Nope, no straight cuts. I had planned to but being on a budget I was talked out of it by a reputable builder.
Stanley
Threads: 270
posted on July 15th, 2013 at 08:02 PM |
Quote: | Originally
posted by 1916baja
Why?
